BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > OBD Flash Tune From Active Autowerke **No ECU REMOVAL REQUIRED**
      01-29-2018, 09:46 AM   #45
ceedawg
ceedawg's Avatar
468
Drives: 2k15 335i xdrive MSport 6spd
Originally Posted by mike@x-ph.com View Post
Their website needs to be updated, thats for their bench flash tune.
You do not have to remove the ECU.
Thanks for clarifying, as that's what my prior question was about.
2k15 335i Msport xdrive 6spd
Wagner Comp2 FMIC,FTP CP,stock exhaust. Fabspeed Sport catted DP, KW V2 coil overs,FBO BM3 Stg 2
      01-29-2018, 09:48 AM   #46
WajahatM
Drives: 2013 AW F30 335i xDrive
Can i get a PM of the pricing?
      01-29-2018, 11:06 AM   #47
XutvJet
Drives: 2011 Cayman Base, 2016 M235
The gains look great; however, given the infancy of the OBD flash tune on the N55, how can AA offer a reliable OBD tuning option when MHD and others are still in the beta phase?
What's their support network like for those that might have issues?
How are they addressing the OEM flash reinstall, flash counter, and other matters?
      01-29-2018, 11:12 AM   #48
mike@x-ph.com
mike@x-ph.com's Avatar
Done
https://x-ph.com/sale/
Phone number 702-494-9435
      01-29-2018, 11:15 AM   #49
mike@x-ph.com
Any customer that purchases this tunes get the same support like any other Active Autowerke product. AA have been around since the 1980s and their customer support is second to none.
You can call them with any questions about your map and you will get support from Carl, the guy who created all their maps not some customer service rep.
I already addressed the flash counter question. OBD solutions do not reset flash counters.
      01-29-2018, 12:23 PM   #50
enemigo13
Drives: F32 LCI 440xi citrineblack
really?
New Functions added:
added Restore ORI function (restore to original FLASH, does not modify EEPROM) – for warranty purposes
added Reading Secret key (ISN) for diesel engines* – useful function for recoding used ECUs
added FLASH COUNTER LOCK function* – now you can write as many times as you want your car on the dyno. Flash counter will remain always ORIGINAL.
source : https://www.magicmotorsport.com/bmw-...1-07-released/
      01-29-2018, 04:32 PM   #51
ceedawg
ceedawg's Avatar
468
This is the same with Bootmod3 as I was told I would have to send them my ECU. However this one posted above seems to allow you to reset flash counters thru OBD. Hmmmm interesting if its true.
      01-29-2018, 04:33 PM   #52
ceedawg
ceedawg's Avatar
468
Originally Posted by enemigo13 View Post
really?
Who are these folks I see they're at the boot strings of Italy!
      01-30-2018, 05:48 PM   #53
PabloK
PabloK's Avatar
looks like a solid option!
Nice
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
22 Ram Trx / 22 M5 CS
      01-31-2018, 05:27 PM   #54
F30-XP-DM
Drives: 14 335i xDrive
Sorry if this has been asked/answered but I haven't seen it
Is this compatible with apple products? If so, that would be a huge plus for me rather then purchasing a device just for tuning purposes
      01-31-2018, 06:27 PM   #55
mike@x-ph.com
You will need to run a VM
That being said, you will only need a laptop once.
After you upload the map, you are set you wont need to do any changes.
Instead of buying a new laptop, borrow one from a friend for a one time 20 minute use
      01-31-2018, 06:38 PM   #56
F30-XP-DM
Thank you. I will be interested in a month or so, please PM with pricing
Thanks!
      01-31-2018, 11:18 PM   #57
mike@x-ph.com
Thanks!
Pm sent.
Not sure i can honor the price in a month, we are doing an intro price for the first batch of tunes sold
      02-05-2018, 12:53 PM   #58
oceanview
oceanview's Avatar
Switzerland
207
Drives: 335i F31 RWD Autom.
Hi Mike
I'm interested as well.
please pm me if possible for Europe/Switzerland shipping of the ODB cable.
Any impact to emission? Will the car pass the emission test (no DP, all stock, cat)
thx
      02-12-2018, 07:30 PM   #59
mike@x-ph.com
Another customer review
      02-12-2018, 11:38 PM   #60
coolguy1o1
coolguy1o1's Avatar
Drives: BMW Activehybrid 3
Hey I've seen a bunch of tuning options come up for the n55. What options are available for the Activehybrid 3? Would love to get more power. Currently run a downpipe, chargepipe, and intake.
      02-13-2018, 02:23 PM   #61
j.badwal
Drives: 2013 BMW 335i
My car has a catted dp, intake, mpe exhaust, and intercooler. I'm currently running jb4 map 2. What are the benefits as to running this flash tune as opposed to sticking with the jb4? Aren't power gains similar?
      02-13-2018, 02:25 PM   #62
mike@x-ph.com
Smoother power delivery is the biggest advantage
Also burble tune, cold start delete, speed limiter removed
Best would be to get run both at the same time
      02-13-2018, 02:38 PM   #63
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
Drives: F32 435ix MSport
Mike - I have a question on this...
When I recently talked with Andrew I asked him if I could continue to run my current Active8 piggy back in conjunction with the flash tune (I know your reply to me earlier was that I could - that A8 would control boost & flash would control everything else)
But his reply was that I shouldn't because the flash tune already increases & controls the boost - if I used both I would run into an overboost situation (boost would be effectively doubled i.e +4psi from A8 + whatever boost flash is calling out) & damage my engine
Trying to understand the discrepancy
      02-13-2018, 02:41 PM   #64
mike@x-ph.com
Flash will do everything the Active 8 does even better.
With the Jb4 it is different since the Jb4 offers features that the flash cannot do on its own.
1QuikWS61621.50
      02-13-2018, 02:49 PM   #65
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
So next question is there a time limit to how long after I receive my cable that I request my flash tunes?
I would like to completely disconnect the A8 before flash, but it's pretty cold right now to be doing that outside I want to take advantage of your spring sale but wouldn't flash till 1 month or so till I had chance to uninstall A8
Unless it's good enough to temporarily disconnect harness from A8 brain and install Valet plug to harness - effectively bypassing A8????
Or I guess I could request tunes right away, download to laptop then simply wait to install
      02-13-2018, 02:55 PM   #66
1QuikWS6
No 55mph
1QuikWS6's Avatar
1622
I also understand that the new AA hi flow catted DP is in final test and will be released soon that according to Andrew is guaranteed No CEL as the Fabspeed, but at reduced price
This would be a nice combo deal DP+Flash to enable customers to go directly to Stage2 flash
Any concrete availability on DP? Combo deal possible?
