BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 6wb retrofit full instruction guide
      08-29-2018, 05:42 AM   #1
FRANKLINDEE
Italy
Drives: BMW F30 2016
Post 6wb retrofit full instruction guide
Hi all,
i would like to start and do myself the coding and the retrofit for the f30 6wb retrofit since they asked 200 usd for the coding
can anyone tell me the step by step guide to do it?
actually i have a normal one
thank you all
      09-04-2018, 08:58 AM   #2
kubax86
kubax86's Avatar
Drives: M2
You have to change eeprom data(vin,mileage) and then code it to car. You need to have programmer like R270 but I don't about chip inside 6WB.
      09-04-2018, 10:08 AM   #3
atzebmw
Drives: Tesla Model 3
If it's new there's no need to change the eeprom data.
Only coding is necessary.
Here's a guide for VO coding:
http://www.bmwesys.com/guides/VO%20C...ep%20Guide.pdf
At point 6 you have to change the 6WA to 6WB.
And at point 12 you have to code your HU and DKombi.
      09-11-2018, 10:58 PM   #4
andyt26
Drives: 2015 BMW 335i Msport
Stupid question does the 6WB cluster void warranty?
      09-18-2018, 07:04 AM   #5
Levanius
Levanius's Avatar
Spain
Drives: F30 20d M Pack
Originally Posted by FRANKLINDEE View Post
Hi all,
thank you all
Hi,
Finally did you code it??
      09-18-2018, 06:19 PM   #6
Jhnblckwood
Drives: F30 2014 320i xdrive
Only if the installation leads to problems specifically ur fault. They should have to prove that but overall no it does not.
      09-18-2018, 10:29 PM   #7
IK6SPEED
Drives: BMW M3 / AH3
In warranty work, you have it 100% backwards. It’s essentially up to you to prove the Modification DID NOT cause the issue if they decide to deny.
”They should” is not “innocent until proven guilty” in these instances.
      09-19-2018, 01:34 AM   #8
Jhnblckwood
Then I been hearing it wrong for awhile. Thanks for the correction.
      09-24-2018, 07:54 AM   #9
FRANKLINDEE
Italy
Hi i'm waiting for my 6wb to arrive, it has been virginized already the final cost is 825 € shipped and is a very good price.
as soon as it arrive i will have to code it i've purchased the cable and i will have to download the eysy but in order to do not make truble i will ask someone to code it for me and activate my shift paddle also
thanks for the guide it seems very dettailed
      10-01-2018, 04:19 PM   #10
rickynguyen
Drives: Bmw F30 320i sedan
FRANKLINDEE please pm me where to buy 6wb virginized 825euro, thanks
      10-04-2018, 10:11 AM   #11
FRANKLINDEE
Italy
you have a private message
      10-31-2018, 02:51 PM   #12
ramparts
Drives: M40i
can you let me know also please ?
      11-09-2018, 10:37 AM   #13
zeiesfirdaus
Drives: BMW X3 xDrive 30i 2022
see this
https://f30.bimmerpost.com/forums/sh....php?t=1553236
      12-13-2018, 01:33 PM   #14
Adamantio
Drives: bmw 420d G.C Msport
Hello, Does anyone know if it is possible to code a 6wa M3 / M4 kombi on an F36 diesel?
      12-15-2018, 08:01 AM   #15
FRANKLINDEE
Italy
Hi i've finally installed my 6wb but i have the red dot do you have a full instruction on how to remove it?
also do i need to change some setting into the navi to make it work i don0t have the possibility to set the time
i have a nbt evo retrofitted
thank you
      12-15-2018, 11:58 AM   #16
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
Originally Posted by zeiesfirdaus View Post
What a strange read, guy boasting about what a fantastic deal he got last year and then lessons from the forum police.
      04-03-2019, 02:18 PM   #17
RalF-BMW
RalF-BMW's Avatar
Drives: 2015 335i M sport
Hi,
The link to the document is broken, can you fix it or send me the coding guide?
Thank you!
      04-03-2019, 03:26 PM   #18
atzebmw
Originally Posted by RalF-BMW View Post
Hi,
Thank you!
I searched for the guide and didn't find it anymore but here i found another guide.
https://www.bimmerfest.com/forums/at...2&d=1377379630
      08-27-2019, 06:23 PM   #19
S6K
S6K's Avatar
166
Drives: 2020 X3M
Hello,
Has anyone installed a 6WB cluster on an F30 and gotten a "Cruise Control Malfunction" message upon start-up randomly every few start ups? Everything works fine including cruise control, I just happen to get this message every couple of start ups
      08-27-2019, 09:42 PM   #20
IK6SPEED
thank you
Obviously the person who virginized your 6WB did not do a complete and proper job.
Guess 825€ wasn't a great deal.
      09-12-2019, 10:41 AM   #21
Zorn
Drives: 2019 F36 430i xDrive
Is there a current guide from start to finish what needs to be done exactly for F3x with NBT_EVO? The PDF guide I have seen just has some generic stuff in it and doesn't explain where/what to find and change.
      04-26-2020, 09:39 AM   #22
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
thank you
Hi
I just bought a 6wb cluster, brand new with 0miles and never coded for any car or vin.
so is it just a matter of removing 6wa and vo code 6wb and code headunit and kombi or is it more than that? Also do you suggest to do the coding with factory headunit on and once the cluster is all set then install the retrofitted id5 headunit or i can directly code with retrofitted id5 headunit on?
Thanks.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
