10-20-2020, 08:51 PM | #45 | |
Rep 210
View post on imgur.com Quote:
ZM22824.00 |
10-20-2020, 09:19 PM | #46 | |
Rep 3,699
Get that Dorch Stage 2 on, and you’ll be able to push some big power. My Stage 1 Dorch has been doing great. |
EstorilMSport83.50 |
10-21-2020, 06:04 AM | #48 | ||
Rep 210
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection |
10-21-2020, 06:37 AM | #49 |
Rep 364
Stage 2+ Racegas OTS map is now available per request from users who did not have access to E85.
Pussiwillow522.00 |
10-21-2020, 09:53 AM | #50 | |
Rep 84
Any plan for 93 (98 RON map)?
'14 F30 335i N55 EWG - Speedtech Stage 3 EFR 8374 - BM3 Custom Tune - xHP Flash - BMS Meth kit - Dorch Stage 2 HPFP - ER FMIC & CP
10-21-2020, 10:12 AM | #51 |
Rep 3,699
10-21-2020, 10:59 AM | #52 | |
Rep 142
kfardan51.00 |
10-21-2020, 01:09 PM | #55 |
Rep 3,699
The new Stg 2+ E30 map is what guys are using with an E47 mix, which is half 93 E10 and half E85 to make mixing simple. The added E content just gives a little extra bump & timing pull protection.
10-21-2020, 01:19 PM | #56 |
Rep 7,613
10-21-2020, 01:22 PM | #57 |
Rep 2,640
Think it's for the hybrid turbo PWG guys like myself, stock turbo PWG will not benefit nor would it be possible to make a stage 2+ map for them as the turbo is too small.
10-21-2020, 01:49 PM | #58 | |
Rep 196
10-21-2020, 02:07 PM | #59 |
Rep 2,640
Yes, stock pwg is essentially useless, first mod should be either a PS1/PS2 then you start doing fuel pump and custom tune.
10-21-2020, 02:16 PM | #60 | |
Rep 196
10-22-2020, 05:43 PM | #62 | |
Rep 1,288
10-22-2020, 06:03 PM | #63 | ||
Rep 210
https://www.bootmod3.net/log?id=5c37...90c666c88c37bf This is 3rd gear street log: https://www.bootmod3.net/log?id=5c31...90c679164a85b4
10-22-2020, 06:41 PM | #64 | |||
1297
Rep 3,536
I don't get how you're hitting boost targets at 6500rpm
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
10-22-2020, 07:00 PM | #65 | |
Rep 3,699
Guess it works for some dyno & street pulls, but I’d back off the custom tune if it were my car and was taking it to the track. Or, add an HPFP and some more ethanol to see if it helps with the timing pull. Last edited by ZM2; 10-22-2020 at 07:07 PM.. |
10-22-2020, 07:01 PM | #66 | ||||
Rep 210
