10-02-2018, 03:06 PM | #1 |
Rep 16
Brake pads?
I just had my front and rear brake pads replaced at around 56,000 km. Is this normal since rear brake pads usually last longer? The mechanic said the fronts were basically done, and the rears weren't too far behind. I paid $620 after tax from a local shop, was this a decent price? I drive a 2015 335i M Performance Edition.
10-02-2018, 04:02 PM | #2 | |
Rep 1,447
10-02-2018, 07:19 PM | #3 |
Rep 1,152
My 2014 328d would chew through brakes, 30000 and the rears where done. 60k the fronts and rears again.
Im at 35k with my ‘17 330i and the pads are showing I have 50k-60k to go before they need replacing... |
10-03-2018, 02:34 PM | #4 |
Rep 14
where did you purchase the parts? OEM or aftermarket? I need pads for both front and rear.
10-03-2018, 02:36 PM | #5 |
Rep 16
10-05-2018, 12:33 AM | #6 |
Rep 106
Drives: 2014 335i xDrive M Sport
2014 335xi auto... I'm at 62k on original brakes and was recently told by the dealership that my brakes were in "dire" need of replacement as they were at around 50% worn. Thing is our cars have estimates/calculations built in based on driving behaviours that will show under "Service" information in iDrive for how many KM are remaining on the current pads (different values front/rear). These cars also have pad wear sensors that indicate when they need to be replaced.
In all sincerity, unless you are getting a warning or having some type of braking issue, you're just playing into the money game with them. |
Wood11221.50 |
10-05-2018, 11:58 AM | #7 | |
Rep 397
insanecoder1410.00 |
10-06-2018, 05:04 AM | #8 |
Rep 3
Drives: 2009 BMW 323i
Brake Job Cost
I just had the brakes and rotors replaced on all four corners of my 2009 323i with 108,000 km on the odometer, I've owned the car for 15,000 km of that mileage. I paid $1250.00, done by a local shop using german parts. Just wondering how often others were having to get this done? Was this a reasonable cost? Thanks Bob
10-08-2018, 12:16 AM | #9 | |
Rep 19
10-08-2018, 05:11 AM | #10 | ||
Rep 1,447
Wood11221.50 |
03-19-2019, 05:41 PM | #11 |
Rep 2
I was just told by dealer that melybrear pads are done.
Car is 430 comb, 20 months old, 25k odo (!!!). Is it possible? I mean I guess the pads are gone but does it make sense? Or is this indicating something was wrong? They also replaced both rear shocks, leaking, under warranty (at least on that no one argued it’s normal. Should last 100-200k). Could bad shocks (probably manufacturing defect) cause somehow excessive ware in brakes? |
03-19-2019, 09:12 PM | #12 | |
Rep 479
03-20-2019, 06:55 AM | #13 |
Rep 2
Sorry I wasn’t clear: it’s 25,000 KM! (= 15,000 miles). And I drive 99% alone with a laptop and lunch bag...(no extra weight) and 60% on highway (usually on cruise control). Still seems reasonable?
03-20-2019, 07:10 AM | #14 | |
Rep 479
03-20-2019, 01:17 PM | #15 |
Rep 180
Drives: 2017 340i M Performance
The rear brakes will wear early if you drive hard, at least on RWD cars due to the brakes being used for traction control.
2020 X5 M40i, and 2017 340i M Performance
Previously owned 2009 128i, 2004 X3, 2008 128i, 2007 X5, 2012 328i, 2015 X3 35i, 2015 228i |
03-21-2019, 09:22 AM | #16 |
Rep 5,457
03-22-2019, 11:11 AM | #17 |
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
I replaced mine around 60,000km, they were pretty much done at that point Akebono pads on stock rotors (the rotors will definitely need replacing next time around). No more dust!
