10-07-2018, 03:36 PM | #1 |
Rep 7
VRSF, CATsim, ****** Catless DP Fix DIY questions. HELP
I have a 2014 435i M sport Pkg. it has a catless DP installed in it that triped the check engine light. I ordered the VRSF Catless DP Fix for N55 engines. I did hours of research before installing it. I decided to wire it on the 02 sensor side instead of into the harness. I connected it to the back 02 sensor. I spliced red wire to red wire. dp fix black wire to o2 sensor grey wire. cut the black wire on the o2 sensor. connected the dp fix yellow wire to the harness side of the black wire and the white dp fix wire to the sensor side of the black wire. no LED light was illuminated and the CEL still hasn't turned off after 2 days and 300 miles. also the glue on the dp fix is melting when the engine compartment gets hot and i smell burnt plastic. is my installation correct? why is the check engine light still on? someone please shine a little light my way. thanks in advanced!
10-07-2018, 04:51 PM | #2 |
Rep 167
I believe the DP fixes do not work with EWG engines. I have a 2015 335i and did research when installing my catless DP to find a way to eliminate a check engine light. I read that the DP fixes out there are only compatible with PWG engines.
I tried using a spacer when I installed mine and did not have any luck. I think that in some cases an L spacer can prevent the sensor from throwing a CEL, but it isn't guaranteed. I think the only way to reliably remove the light on a EWG engine is to have the car tuned at a shop with the ability to disable the check engine light/sensor reading. Doing so isn't exactly legal so I wouldn't expect a shop you have never dealt with to tell you over the phone that they can disable the light. |
LexLutheranM435i2.00 |
10-08-2018, 02:04 PM | #3 |
1296
Rep 3,533
Bootmod3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
10-09-2018, 06:45 AM | #5 | |
Rep 963
I suspect you're looking to pass emissions though. if that's the case, the tunes aren't going to help and the only completely fool proof way seems to be swapping back to stock DP unfortunately. from what i've read, the DP Fix from Area 74 and VRSF (same thing I believe) are hit or miss.
2018 Azurite Black F80 M3 ZCP
2019 Phytonic Blue G05 X5 2013 Glacier Silver F30 335i (sold) |
10-09-2018, 09:14 AM | #6 | ||
Rep 7
I went another route. I ordered an o2 spacer that has a mini cat in it. Basically cleans it enough before it gets to the second 02 sensor that it reads as normal. Fingers crossed! I'm hoping this works! I will update you guys! It should be delivered by today. |
10-09-2018, 11:14 AM | #7 | |
Rep 710
Drives: 23 M3 Competition
14 F30 N55 AWD SpeedTech EFR-8374, E70 MHD, Motive tuned
23 M3 Competition - Stock |
10-09-2018, 11:52 AM | #8 | ||
Rep 7
10-09-2018, 12:04 PM | #9 |
Rep 2,653
10-12-2018, 12:50 PM | #12 |
Rep 1,499
I've been doing extensive research on this as well and this is what I have learned...
1. If you just want to suppress the CEL due to catless DP in the cabin then go with a tune like MHD or bootmod3 2. If you need to pass emissions the VRSF or Area 74 DP fix doesn't work with EWG 3. In most states you can pass emissions with one monitor not ready. If you live in a state that allows this then you can pass with the catless DP and stock tune. There seems to be some driving process that you have to follow after switching back to stock tune that allows for all available monitors to show ready except for the catalyst monitor but won't trip the CEL. Cheers,
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids Last edited by JaredG_F30; 10-12-2018 at 03:08 PM.. |
aps335.50 |
10-15-2018, 09:47 PM | #14 |
Rep 7
12-17-2018, 09:36 AM | #15 | |
Rep 176
12-17-2018, 10:19 AM | #16 |
Rep 1,934
Yes the tune will do what you want. Found a couple users here who have gone through the process and passed inspection in MA. This is without doing anything illegal. So, if your state allows ONE checked monitor to show "not ready", this not the same as a FAILED readiness that throws a CEL, you should be fine.
So, hfc or catless, MHD or BM3 tune where the cat isn't monitored, and no other faults will allow you to pass. The stock tune will always throw a CEL so you will get a failed status, and you won't pass. At that point if the station reads the failed status you will no longer be able to get through with the not ready. In MA this case will force you to have to pass with a FULL READINESS status for that monitor. Note: the illegal act is setting the readiness to PASS or something else when it indeed isn't the case. Turning off the monitor, entirely, via tune is not illegal.
12-26-2018, 09:30 PM | #17 | |
Rep 262
Drives: 2013 BMW 335i M-Sport
12-28-2018, 04:21 PM | #18 |
Rep 152
Drives: 2015 435i Gran Coupe
04-03-2019, 08:10 AM | #19 | |
Rep 6
Has anyone confirmed this option #3 to work for OBD emissions testing only where 1 monitor is allowed to be "not ready"?....in this case the catalyst monitor? What is the best way to see/check your monitor readiness prior to testing? Does the BM3 dashboard give you that info? I'm going FBO w/ Stage 2 BM3 soon and just getting my ducks in a row. Thanks....I know this thread is a few months old but presumably some folks still interested in this topic. Thanks for the insights from everyone.
04-03-2019, 10:33 PM | #20 | |
Rep 167
Testing requirements vary by state, but I do know that Georgia does allow one sensor to be in ‘not ready’ status. However if the sensor returns a problem (this is different from not ready) that it can cause a failure. I believe in most states that a failure will require all sensors to pass before you can pass emissions. I think it is possible to pass an emissions test with a catless dp and people have done it before, but you must have all the right conditions to make it happen. Honestly it is probably easiest to just switch it out each year for the test. |
