07-18-2020, 12:32 PM | #3565 | |
Rep 4
To summarize what I have done to start using wireless AA with my Galaxy S9: 1. Update System Software and MCU to latest version (Reply #3 on the 1st page) 2. Enable Developer mode for Anrdoid Auto. Enable wireless projection from Developer settings. 3. Your phone must have internet connection when attempting to launch wireless AA. 4. Turn on Bluetooth and connect to Carlink and wait for a few seconds 5. MMI recognizes your phone and a popup apears, which you have to confirm with the IDrive controller. 6. Wireless AA is launched. |
xmax314.50 |
07-18-2020, 12:46 PM | #3566 |
Rep 540
Just upgraded andream unit to latest version. All the bugs seemed to be resolved but I noticed that the menu button stopped working. Prior to the update, pressing the menu button would exit the app and display all the apps. Anyway to enable that again?
07-18-2020, 01:03 PM | #3567 |
Rep 63
Hi again, I continue with wireless carplay connection problems, it works more or less automatically 50%, the rest of ones I require to connect disconnect BT connection and usually works, sometimes I have need to restart MMI. Anyone with the same problem? I have the Andream unit with the last MCU and SW installed.
Regards |
xmax314.50 |
07-18-2020, 02:09 PM | #3568 | |
Rep 540
07-18-2020, 04:11 PM | #3569 | |
Rep 21
07-18-2020, 04:41 PM | #3570 |
Rep 364
Drives: F15 M50d / ex E90 335i / Panda
While I don't have the unit yet, you could try to drive off and wait for the phone to drop the WiFi access - shouldn't it connect to the mmi unit automatically as the next available network? Thinking out loud here.
07-18-2020, 07:58 PM | #3571 | |
Rep 1,700
Drives: 22 X3MC MBB - C-17 Globemaster
2. No as that is 2 different systems that connect speak because screen share is basically a passthrough mode for your phone to only display, and not interact with the unit. The tech just isn't setup for that. As far as using mirror link instead of AA, its great for the exact reasons you are saying, like watching a movie on a long road trip or using an outside app. The majority of people just want better navigation and song navigation with their in car controls out of comfort. Its like wanting a touch screen when you dont have one, to make your life easier. That all being said, mirror link is great for all aftermarket usage and is still being explored for greater potential. |
07-18-2020, 10:32 PM | #3573 | |
Rep 63
Regards |
07-19-2020, 02:53 AM | #3574 |
Rep 172
Drives: 2015 328i
So many people seem to be having issues. My install was 'it just works'. Every now and then (days) the iPhone will not auto connect. Solution is to go to paired devices and tap Disconnect then Connect. 3 sec fix.
Did I just get a lucky unit / sw version? |
07-19-2020, 05:01 AM | #3575 | |
Rep 128
I think that is the most hot feature people would like to know. I am also holding on the buying before i will able to use OEM BT for calling simultaneously with CarPlay MMI. |
07-19-2020, 07:47 AM | #3576 | ||
Matusov
Rep 43
I noticed another oddity, in mirroring Netflix won't output to the cars screen. Kind of defeats the whole purpose if some apps won't output. Any workarounds? |
07-19-2020, 09:12 AM | #3577 | ||
Rep 84
435i M Package, VRSF FMIC, VRSF CP, MHD stage 2+, stock cat
07-19-2020, 10:52 AM | #3578 | |||
Rep 53
07-19-2020, 12:02 PM | #3579 | |
Rep 1
Where did you get the official script from?
Thanks! Quote:
07-19-2020, 01:31 PM | #3580 |
Rep 5
There’s some great discussion here and I’m hoping to get some tips on my setup. I installed a box yesterday from AliExpress. Based on the menu, it looks like the Andreas variant. It worked beautifully for about half an hour, but since then it’s just a black screen.
The phone still connects, but beyond that nothing. If I hold the 8 or the Menu button, I can hear a click in the box switching modes, but nothing happens beyond that. The green LED is is on in the box and the blue flashing. I’ve tried to force a firmware update, alas also without success. Any ideas? |
07-19-2020, 01:35 PM | #3581 | |
Rep 1,217
07-19-2020, 02:18 PM | #3582 | |
Rep 5
Maybe just dead hardware? Seems odd after being fine for twenty minutes after install. Last edited by jhembach; 07-19-2020 at 02:25 PM.. |
07-19-2020, 05:02 PM | #3583 | ||
Rep 1,217
07-19-2020, 05:39 PM | #3584 | |
Rep 350
07-19-2020, 05:41 PM | #3585 |
Rep 350
It changed to back key. Hold it for a second or two and it does same as menu used to.
07-19-2020, 05:42 PM | #3586 | |
Rep 540
Tags |
andream, android, android auto, apple, carplay, mmi, retrofit |
