11-21-2013, 08:17 PM | #45 |
Rep 688
All this talk about boost figures...how much boost is actually held to redline? 18.5 or 20 PSI or whatever is nice, but it means nothing if it's fading to half that near redline. All that torque doesn't help if it's not in the rev-range where you spend all your time at WOT. What's it running between 6000 and 7000 RPM...14 PSI?
But I'm a little jaded. I only used to run 10 PSI a car ago, set to come on gradually and creep to 11 PSI all the way to 7000 RPM...on nothing but 91 octane. That's what a proper boost-control system gets you. |
11-21-2013, 08:22 PM | #46 |
Rep 688
11-21-2013, 08:31 PM | #47 |
Law Enforcer
25039
Rep 22,275
Drives: '22 Chalk Gray Porsche C2S
I never heard of "charge pipe" until BMW's as well. I've always just called it intercooler piping.
11-21-2013, 08:36 PM | #48 |
Rep 1,975
There's an upper and lower IC pipe. Maybe that's where the confusion came in?
2013 F30 335i ///M-Sport
Forgestar/Challenge/BMS JB4 Wagner/Evo Race/M-Performance 2016 F15 50i ///M-Sport BM3/H&R/Borla |
11-22-2013, 10:04 PM | #49 |
Rep 4,323
Great #'s, although I don't see how this is useable outside of the strip or stop light drag racing.
That amount of boost on a track would result in limp mode in literally a few laps...
11-23-2013, 12:58 AM | #50 | |
Law Enforcer
25039
Rep 22,275
11-24-2013, 09:53 AM | #51 | |
Rep 665
11-24-2013, 10:20 AM | #52 | |
Rep 573
7000 RPM in 6th with the 8AT is 170mph Most BMW's are this way - geared too high by the rear end to dyno with the transmission at a 1:1 ratio Generally you dyno BMW's in 4th for a manual, and 5th for an 8AT If you're having a problem with the kick-down in the automatic, hold down the DSC button until it displays DSC OFF, slide the transmission stick to the left for sport then manually shift through the gears - when you get to 5th, floor it (through the kick-down) it will not shift down, and will not shift up when you redline This will also prevent the DME from cutting throttle if the wheels slip a little |
11-24-2013, 12:00 PM | #53 | |
Rep 1,252
Docrace 6266
11-24-2013, 01:45 PM | #54 |
Rep 4,323
They've already been proactive: air to water intercooler will immensely help, and I'm assuming double oil intercoolers will be standard (and probably larger than the M Sport ones)...it won't have issues with heat soak, they built in with the Ring in mind.
11-24-2013, 01:55 PM | #55 |
Rep 47
Thats the gear i dynoed in 5th.. But everyone seems to act like they know what they are talking about. And that day was warm it was 60 degrees out. And car was getting heat soak!
11-25-2013, 01:16 AM | #56 |
Rep 187
get the car to the track when the temp warms up and see what it runs/traps
if the average trap speed backs up the dyno numbers then that's really good news for the n55 cars |
11-26-2013, 09:18 AM | #59 |
Rep 1,997
