04-09-2018, 05:38 AM | #111 |
Rep 631
08-05-2018, 02:10 PM | #113 |
Rep 262
Just did this to my M3. Problem solved.
Only issue is that the 15' roll cost $36 and was about 6" too short to do both sides with no waste. Despite this, the creaking is gone. |
Speedwell-Industries434.00 |
08-05-2018, 03:16 PM | #115 |
Rep 937
Idk man, I rather not get some wax build up on the felt trim that meets with the shadowline trim
Hi
08-05-2018, 08:08 PM | #116 |
Rep 257
I didn't feel like going back to the dealer, so I bought a spray can of 6% silicon spray, and just spray a paper towel with the silicon and wipe the trim above the doors from front to back.
The spray is expensive, but one treatment seems to last for weeks and lasts even after a wash. Just watch overspray because this stuff is slippery and hard to remove once it hits something.
2021 i3s AC Schnitzer BMW CCA #67486 |
08-05-2018, 08:23 PM | #117 |
Rep 43
I used this so far great!
nextzett 91480615 'Gummi Pflege... https://www.amazon.com/dp/B004B8GTQG?ref=yo_pop_ma_swf |
DL335D580.00 |
08-05-2018, 09:30 PM | #118 | |
Rep 257
08-05-2018, 09:31 PM | #119 | ||
Rep 43
02-20-2019, 09:49 AM | #121 |
Rep 616
I have a '18 M3 and have tried gummi and wax and the creaking always comes back after a month or so and a couple car washes.
Thank God I found this thread! I will tackle this project this weekend. Will not take my car to a dealer for this. They managed to scratch my trunk during the last oil change. Thank you OP for putting together the DIY!!! |
02-26-2019, 09:26 PM | #122 |
Rep 616
Bought the tape at Amazon for $6 and spent 15 min tops Saturday morning following OP's DIY.
Super happy with the result! Zero creaks and I'm sure they won't be back! |
02-27-2019, 07:08 AM | #123 |
Rep 260
Has anyone tried this on the convertible? Because it's a frameless door, and there's a rear quarter window which directly contacts the front door window glass.
02-27-2019, 09:12 AM | #124 |
Rep 370
02-27-2019, 12:07 PM | #125 | |
Rep 616
I went with 0.5" width and it's perfect. Good luck! |
03-24-2019, 06:43 PM | #127 |
Rep 446
does the bulletin applies to canadian cars? 16' 340i
Mod bug will bite you if you buy a BMW ================================= |
07-22-2019, 09:30 AM | #128 |
Rep 1
Does SIB 51 28 10 actually cover the F30. I took my car to the dealer last week, who told me it didn't apply. They just cleaned the seals which fixed the issue for about 4 hours.
Does anyone have a copy of the SIB they could post (or send me)? Thanks |
08-06-2019, 09:54 AM | #129 |
Rep 26
This creaking is comming from 2 parts:
1. The shadow line trim which can be fixed with the teflon tape. 2. The glass rubbing against the seals causing the sound. The only fix i think is changing door glass seals? Or put some material inside, where the glass is moving. I already applied teflon tape and the creaking is less but continue to have creaking from the glass and seal! Please help! |
08-06-2019, 04:43 PM | #130 | |
Rep 2,499
It literally takes 5 minutes to thoroughly clean all those seals and they will work better if kept clean anyway. I'd rather keep them clean then apply tape to the car. |
07-28-2020, 10:05 PM | #131 |
Rep 102
Sorry for the bump, but I searched and couldn't find anything solid on this -- did anyone get this to work on the convertible?
I have an 2020 F83 and the creaks and squeaks are worse than the 10 year old Honda I bought in high school. Dealer is claiming "the convertible top is operating as expected". |
07-01-2021, 08:24 AM | #132 |
Rep 1,369
If you are out of warranty and didn't plan on spending over $250 for magic tape the following solution might help. Fingers crossed
https://f30.bimmerpost.com/forums/sh...6#post27756776 The short version: 1) Clean all seals, especially between upper seals, with a microfibre towel + water, then clean again with silicone remover. 2) Lube between seals with the KSP 105. You can go insane spreading the KSP 105 all over the place but start by cleaning and lubing between the upper door seals. See how far that takes you then lube additional areas. Good luck.
340i xDrive (F30), 228i (F22), 320 (F30), 325i (E46)
