06-23-2024, 11:17 AM | #1 |
![]() 653
Rep 1,016
Gepfeffert KW V2 coilovers
Removed from my F30 before sale
These are designed to ride LOW, pic of my car running these attached They ride amazingly well, especially when considering their height. far more compliant on the road than the BCs I ran before these. Main bad points are: one of the camber adjustment bolts has been stripped, will need replacing does not come with KW toolkit ( c spanner and rebound adjustment key) these are currently ~€2000 new from gepfeffert £800 collected from east london (IG6) ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
08-13-2024, 07:32 AM | #4 |
![]() 653
Rep 1,016
08-22-2024, 03:04 PM | #5 |
![]() 83
Rep 116
Hey! Can I just check this suspension is for the slammed look only ? Can this not be setup normally where the wheels aren’t hiding in the arches! Possibly interested.
I’m after KW V2/3’s or B14’s |
08-22-2024, 09:37 PM | #6 | |
![]() 653
Rep 1,016
I have a similar setup now on my f80 albeit clubsports, and have spring spacers in the rear so it's not completely on the floor - without the spring spacers the f80 would've sat like this: View post on imgur.com |
08-22-2024, 09:43 PM | #7 |
![]() 653
Rep 1,016
anyway here are a few more pics of the f30 with these fitted for attention
the audi was bagged View post on imgur.com |
08-25-2024, 06:17 AM | #9 | |
![]() 653
Rep 1,016
![]() https://www.kwsuspensions.co.uk/shop/_/-/-/65030046 |
11-11-2024, 07:49 PM | #11 | |
![]() ![]() 765
Rep 1,472
I ditched them after bearing play was deemed acceptable, I moved to KW and the difference was huge.
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, B58tu HPFP, MHD Stage 2 HPFP 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
11-12-2024, 04:44 AM | #12 |
Rep 2,963
Drives: 2015 F31 325D & 2007 E81 130i
This After a few test drives on B14s and B16s (with a car on B12s in between) and knowing KW & ST suspension well; I'd go for them over the Bilstein's any day of the week My pals at Grinspeed have had plenty of issues with Bilstein suspension, serious corrosion issues and not that old either! Whereas KWs and STs they've had very little problems and when they have, they've been able to sort parts and get them rebuilt in no time etc
My car: 2015 F31 325D M Sport Touring in Glacier Metallic Silver - Keeping it OEM 'Plus'
![]() Project: https://f30.bimmerpost.com/forums/sh....php?t=1982298 |
fortythirtyfive764.50 |
