09-19-2023, 01:51 AM | #1 |
Rep 5
Random Clicking Noise
Hi guys, first post here.
I got my f30 335i right before the summer, and brought the car to a ppi, mechanically perfect but there's this "click click" noise coming from rear passenger side. I'm currently running fbo mhd stage 2 but this noise has been around before the fbo which the previous owner installed a akrapovic exhaust. i suspect it's either the exhaust, transmission, suspension or just a random loose bolt/clamp. this noise only appears when gas pedal is pressed or released. also i noticed, not 100% sure, when i try to acclerated or break as smooth as possible, the "click click" noise doesn't show up as often. this is my first bimmer, I'm not sure if all akrapovic exhaust does this or it's something else. the "click click" noise it really just 2 clicks, after those 2 clicks there's no other noises. the noise is super random, but usually appears in scenarios mentioned above Thank you so much P.S. I'll try to record a video tomorrow, |
09-19-2023, 05:12 AM | #2 | |
Rep 1,372
09-20-2023, 10:18 PM | #3 |
Rep 5
Thanks for the reply.. unfortunately i checked all four tires.. no debris whatsoever around and inside the tires.
here’s a video https://youtube.com/shorts/qBLBtAfwi...pn05Ms1B8SV4hd i also realized sometimes shifting park to reverse or drive on a ramp rolling will have that noise |
10-31-2023, 12:57 PM | #6 |
Rep 221
It sounds kind of like the parking brake cables rubbing on the driveshaft. The plastic clip that holds the cables inevitably fails, causing them to drop down and rub on the rotating driveshaft, especially when the rear suspension loads up under acceleration. Which is why you don't hear it when you accelerate slowly like you said.
With just 1-2 clicks, your clip is just starting to fail, but it'll keep getting worse. You can check out this thread for some more resources: https://f30.bimmerpost.com/forums/sh....php?t=1676073 But basically, you can replace it yourself pretty cheaply with the original part, which will be a small-medium pain in the ass job. You could go super cheap and much easier with some zip ties. Or you can go all out and get a 3rd party fix that is a pretty easy job, will never fail, but costs over $100. The choice is yours. |
