BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Tracking / Racing / Autocrossing > Schroth Quick Fit in my F-series
      10-30-2020, 10:56 AM   #23
FaRKle!
Originally Posted by gippy View Post
just saw your new vid and noticed the harness, was like NEED.
Did you just get the one for E90? not sure which one i need to select for F32. E92?
I have the ones for the E90. kreuz has an F32 and the quickfits. I don't remember if he got the E90 or E92 versions.
-My YouTube Channel for some of the best DIYs and in depth information
Please don't PM me for suspension recommendations unless interested in paid private consultations.
      10-30-2020, 01:15 PM   #24
jmg
jmg's Avatar
18659
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
I'm not sure if you read the rest of the posts, but these were not designed for the F30 because there is no pass through. All the homemade fixes haven't really been tested and I would be cautious taking them on a track and relying on them to save your life without a seat pass through. In the least I would get a proper racing seat then get the Quick Fit.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      10-30-2020, 05:35 PM   #25
FaRKle!
The F3X have pass throughs between the headrest posts the same as the E90, the F8X doesn't.
      10-30-2020, 05:58 PM   #26
jmg
jmg's Avatar
18659
2019 i3 BEV  [0.00]
The F3X have pass throughs, the F8X doesn't.
Oops my mistake. I was thinking of the F80.
According to Schroth they were designed for the E90 and the different F30 seat positions would change the angles of the belts outside of their functional range. Certain DE's, clubs, and organizations will not pass these belts for cars they are not designed for. I understand that some will pass them, but I would be more concerned why other don't and why the manufacturer of said product warns against it as well.
That being said, you won't really know until you really need it.
IG: Raging_G82
      10-30-2020, 07:23 PM   #27
npe
npe's Avatar
87
Drives: E46, F30
You make a big deal about using the QF/QFP in cars that the harnesses weren't designed for (which is warranted), but you also suggest pairing the QF/QFP with a "proper racing seat":
You know Schroth states that QF/QFP aren't approved for use with fixed back seats, right? There's currently only one fixed back race seat that Schroth has approved for use with QF/QFP.
      10-30-2020, 07:47 PM   #28
jmg
jmg's Avatar
18659
2019 i3 BEV  [0.00]
I would of course do the research first. If there is only one that is approved, I'd get that. That's what I mean by "proper". If you need to run a harness, I'd do that. My point was, the stock seats aren't approved. If you really want to use the quick fit, you have to get another seat that works with it.
Kinda defeats the point of a "quick fit" though doesn't it?
IG: Raging_G82
      11-01-2020, 08:01 AM   #29
gippy
Drives: F32 440i, pre-LCI, w/MPPSK
i trust @Farkle! and that's all that matters.
      12-20-2020, 08:55 PM   #30
jonathanvictory
Hi!
54
Drives: F80 ZCP, F15 X5e
Just installed a Schroth harness. Tossed the car around a bit and it felt extremely secure. Kept me well planted to my seat.
jmg18658.50
harkes1075.50
AmuroRay2267.50
Logicoeur989.50
      12-31-2020, 10:55 PM   #31
harkes
harkes's Avatar
China
1076
Drives: M135i, E39 M5, NSX and AE86
Especially good with your leather seats. Happy you like it
(A Dane in China)
      01-03-2021, 07:34 PM   #32
EstorilMSport
EstorilMSport's Avatar
Drives: 2014 335i M Sport
I am running this in my F30 no issues at all and glad to have HANS. Thanks for the post.
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection
      04-18-2021, 12:57 AM   #33
romemedrano
Drives: BMW F30
Some people might not like this but oh well:
Takata racing
Drift or race model
ASM 4 point harness .
Universal.
Takata racing bought Schroth racing a few years ago that's why they have ASM approval:
https://www.takataracing.com/item/ra...lt/race-series
Also for those who question schroth asm system. My friend rolled his focus st with the 4
Point ASM harness no issues. Schroth even asked for the video and offered to exchange his used set for a brand new one!
FaRKle!4006.50
      04-18-2021, 11:50 AM   #34
Logicoeur
Logicoeur's Avatar
990
Drives: F30 335i xDrive
Not much experience in this area but what is the corbeau 4 point so much cheaper?
https://www.ecstuning.com/BMW-F30-32..._Belt/Harness/
      04-18-2021, 08:40 PM   #35
harkes
harkes's Avatar
China
1076
Think the ASM is a big part of the product cost for Schrott/Takata
(A Dane in China)
      04-20-2021, 10:51 AM   #36
romemedrano
Drives: BMW F30
^ This. ASM is definitely the one to keep you alive....
      05-10-2021, 08:22 PM   #37
Logicoeur
Logicoeur's Avatar
990
Takata racing
Drift or race model
Universal.
Does the takata also use the standard buckles in the back? I don't see it mentioned
      05-11-2021, 03:53 PM   #38
nickf30
Drives: 2014 335i xDrive
Which club allow anti sub ASM points in NY tri state region? Closest I see in the writing is if the belt is certified for specific model (like E92 M3) which no longer apply to any F/G series BMW aka don't even think about 4 points.
      05-11-2021, 05:54 PM   #39
romemedrano
Drives: BMW F30
they have option for clips or eyelets!
Logicoeur989.50
      07-03-2021, 07:46 AM   #40
skier_du
skier_du's Avatar
Drives: 14 F30 335i xDrive
I've been using the E90 Schroth 4 points in my f30 with NASA for a couple years no problem. I also saw a listing in motorsportreg for an event recently that specifically said the only 4 point they allow is Schroth. Unfortunately I don't remember which club that was.
      09-06-2021, 10:01 PM   #41
EstorilMSport
I’m selling my setup if anyone is interested, this harness and Hans. https://f30.bimmerpost.com/forums/sh....php?t=1856432
