07-26-2021, 12:31 AM | #1 |
Rep 11
Looking for your advices/opinions on upgrading F30 brakes
Car: 2018 BMW f30 330i LCI
Currently the car has the base single piston brake calipers front and rear, the rotor sizes are: Front - 330x24 Rear - 300x20 I found a set of front M-sport blue calipers that takes on 340x30 rotors at a reasonable price locally. My question is - is it a good idea to just upgrade the front calipers only? After doing so, the front will be 4 piston (340x30) vs rear 1 piston (300x20). Will this have any implications on brake balancing etc. Thanks in advance guys Last edited by seirogan; 07-26-2021 at 12:48 AM.. |
07-26-2021, 12:56 PM | #2 |
Rep 1,934
Brake bias will definitely be affected. The 340mm setup comes with 330 rears. Ypu should be able to find those rears for really cheap. I have a set if you need them. $120 shipped CONUS.
07-31-2021, 06:22 PM | #3 | |
Rep 10,249
How many miles does your car have? |
08-01-2021, 03:22 AM | #4 | |
Rep 11
Would I also need to code anything after changing the brakes? |
08-01-2021, 03:29 AM | #5 | |
Rep 11
I've got the following parts on my shopping list: 1. Zimmermann 1 piece rotor 340mm and 345mm 2. TRW Cotec brake pads front and rear + bendix pad indicators Feel free to let me know if you have any other suggestions The car currently only has 15,000km on it, so I'm intending to slowly collect the parts first through sales etc. Still deciding on a good timing to swap the brakes.. |
08-29-2021, 06:13 PM | #6 |
Rep 170
I am going down this road as well. I have a 328i with the stock brake setup, I want the upgraded stock 4pot and 2pot setup as I will also be changing the wheels to 20" LM style ones and the smaller brake setup will also appear quite small behind them.
08-30-2021, 09:29 AM | #7 | |
Rep 10,249
08-30-2021, 12:41 PM | #8 |
Rep 29
Hello, all.
Would the M Sport calipers from an older (say 2013) M135i be the same size as the ones that were used on other cars with M Sport brakes? Trying to figure out waht I can use and what I can't... Thanks, in advance for any replies!
Estoril Blue 2015 BMW 435i X-Drive Gran Coupe
08-31-2021, 11:28 PM | #9 |
Rep 11
I actually ended up buying a set of M sport blue calipers from a M135i for my 330i. They should fit, the fronts I believe are the same across these models. But the rear comes in 2 piston sizes (40 vs 45), I think the newer models have the larger piston size (they both take the same brake pads though).
09-01-2021, 11:03 AM | #10 |
Rep 29
Nice, thank you, seirogan!
Does the rotor size stay the same as stock, or increase to 345? Any idea?
