BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > CIC/NBT FSC Generator - Windows/Linux/OSX
      03-08-2019, 08:59 AM   #155
nowunlocking
Drives: 2015 528xdrive
Jagaer
the generator is no longer generating correct "lifetime" codes as of 3 days ago. I have tried using mac and windows version without luck. any suggestions?
      03-10-2019, 12:49 PM   #156
livaditisd
Drives: f10
Hello Jagaer,
I have a problem I canīt FSC code generates my Map:
Road Map North America NEXT 2019-1
and my vin D479796
could you help me please?
      03-11-2019, 04:48 PM   #157
marcospoffo
marcospoffo's Avatar
Brazil
17
Drives: 320 F30 - 2013
ottobrill me chama no whatsapp 047-99110-7262
Originally Posted by ottobrill View Post
Hey dear friends,
Could anyone be kind enough and point out the way where I can find the South America 2019 NEXT maps for my X3.
I don't want to be an imposition but if anyone could also get me the FSC code for my bimmer (0g18094). I'm in Brazil and it is kind of hard to get by the Enet cable here.
Thank you guys so much
320 F30 2013.
      03-15-2019, 07:19 PM   #158
project_x
Drives: 328D F30
I had trouble today generating for KX95826 and North America 2019-1
On Windows
      03-22-2019, 05:30 PM   #159
jcortez75
Drives: 2015 BMW 428i xdrive F36
Originally Posted by ashikaitc View Post
TRY This
JXMG2EXFTE6BWAEIAD7Q
Hi, I am looking for fsc code
fsc gen not finding the correct code. I have tried everything. Please help.
Map type: Next
Region: North America
Map: Road Map North America Next 2019 -2
Vin: D415768
production date: 04/2015
      03-24-2019, 04:06 PM   #160
Omfgorz
Thank you, your program generated a lifetime code for my nbt, I will send you my fsc
      03-25-2019, 11:51 PM   #161
Lazygit
Drives: 320d SE Business Edition
Hi Guys, could someone send me a link for the 2019 Motion East / West maps please?
Many thanks.
      03-25-2019, 11:54 PM   #162
Lazygit
Code
Try this 5YJJQZA4FE2FIAFIAA7A or this lifetime code QII4WNCJ2KXIKAFIAD7Q
Originally Posted by jcortez75 View Post
Hi, I am looking for fsc code (year 20150309)
Map type: Next
Vin: D415768
      03-31-2019, 08:56 AM   #163
gyasih
Hello great tool!
Could I get some assistance.
Map type: Next
Map: Road Map North America Next 2019 -1
Vin: D085279
production date: 08/16
If you can generate codes regular and lifetime great, also what date would I select since there are only 2 options for 2016?
TIA
      04-08-2019, 06:21 PM   #164
slavc
Drives: BMW 520d
Hello please help...I need code for...
Map: Road Map Europe Next 2019 -1
Vin: G080095
Thank you...
      04-10-2019, 01:49 PM   #165
Georgy121
Drives: BMW 420
Hi all,
i'm trying to find the best software to download the 'DE' FSC file from my F32? I have an ethernet cable but I cant work out the dodgy software that came with it.
I dont need to code anything i just need the FSC code so i can install the maps ive downloaded.
Ideally some free software would be great!
      04-10-2019, 09:29 PM   #166
ddwind
Drives: BMW X5
I have generated both life time code and one time code, however none of them works. I am wondering if the code generator works for BMW X5.
Can someone help generate life time code and one time code for me?
VIN: 0C28434
Production date: Oct 31, 2013
Map: North America Next 2019-1
Thanks,
      04-11-2019, 02:11 PM   #167
rbenzer
Drives: 5.20d
FSC Code
Dear,
I downloaded Europe East Premium 2019-1
I need FSC code for CIC
My car VIN E854364
Could you send it life time please
Thank you very much for your help
      04-12-2019, 01:33 PM   #168
Curtiswg
Drives: 2019 330i X drive
Same issues as above.
I cannot get the 4 codes I tried to work properly.
Vin: NP32613
2014 328i
North America NEXT 2019-2
I have the entire file loaded on to a usb successfully already.
      04-17-2019, 02:57 AM   #169
starmanbl
Drives: F30 318d Sport
FSC not generating FSC for Europe Next 2019.1 ?
Hi all,
I try to generate FSC code for Europe Road Map Next 2019.1 but no luck.
Anyone else have same problem, I try to generate Lifitime and normal one, same thing, all codes are incorrect.
If someone else could try to generate
VIN: G220934
Europe Road map Next 2019.1
This is first time in 4 yrs I need FSC for my retrofitted NBT.
Every time was only to update without code.
I have E sys and I done this couple of times, but now when I need it something is wrong
Maybe because is retrofit?
Any help is appreciated.
      04-17-2019, 02:59 AM   #170
ian simpson
Drives: BMW 4M
New member qualifying post reply
      04-17-2019, 03:44 AM   #171
starmanbl
Originally Posted by starmanbl View Post
Hi all,
VIN: G220934
After few incorrect codes I try to input now I can not start navigation without FCS codes, even I didn't update to new 2019.1 map and still have 2018.2 I need to type FSC code to use navigation. SO all be aware of this!!!
Navigation is locked now.
UPDATE: After reset all good, back to state before navigation locked... So I'm back to 2018.2
If someone find solution for Europe Next 2019.1 please let me know.
      04-18-2019, 01:41 PM   #172
leventince
Drives: BMW x5
Where can I download the latest version of FSC generator mentioned here? If someone posts the link here, I really appreciate.
      04-21-2019, 12:46 PM   #173
AK415
AK415's Avatar
197
Drives: 2015 F32 435i
Originally Posted by BackBlue View Post
Here is how to get the "open file":
You pull "1b" file from your vehicle via a usb stick.
ZIP LINK:
https://www.e90post.com/forums/attac...5&d=1518522964
1. Unpack the ZIP file (1b.zip) to the root of an empty USB stick
2. Power on your car (ignition on is fine, you don't need to start your car) and wait until the navigation system has started completely
3. Put the USB stick in the USB port in the glove box or console, depending on vehicle.
4. Wait for around 30 seconds
5. Remove the USB stick from the port in the glove box and put it in your (windows) computer
6. Check if the file 1b.hex is present on the USB sticK, THIS IS the "OPEN FILE", save this to your computer and point the code generator to it.
Credit to memeber portalseo@e90post...and of course to Jagaer for the code generator!
2 problems here.
The 1b file attached already had a hex file inside, and the content is different from OP's 1b.
The usb in the armrest didn't help pulling the hex file on my F32. I will try installing the usb in the glove box area to see if that makes a difference. If not, I at least have another usb port
      04-23-2019, 03:56 AM   #174
t4ure4n
Drives: 2016 BMW X3 xdrive 20d
Question
Hi
I have BMW X3 2016 (F25) with Professional Navigation. Using a VIN decoder I have found following which may relate to navigation system
  • 609 Navigation System Professional
  • 6AE Teleservices
  • 6AK Connecteddrive Services
  • 6AM Real Time Traffic Information
  • 6AN Concierge Services
  • 6AP Remote Services
Do I need CIC or NBT to generate FSC code?
Please advise me what type of maps shall I download for UK? I have seen CIC, MOVE, NEXT etc. and I am not sure which type of map will be valid for my car?
Does BMW provide OTA updates for maps and are they free?
      04-23-2019, 06:33 AM   #175
starmanbl
Originally Posted by t4ure4n View Post
Hi
  • 6AE Teleservices
You should download Road Map Next and you need to generate FSC for NBT...
When you download map, you will find out do you need FSC or you already have Lifetime code installed, or you still have free update from BMW... I did update mine 3 times for free now I need FSC... Hope this helps
      04-23-2019, 06:38 AM   #176
starmanbl
Originally Posted by AK415 View Post
2 problems here.
If you have NBT in car then you need DE File. You can pull DE with E-Sys...
1B is for CIC (Older unit) Most likely your BMW 4 series have NBT not CIC.
Hope this helps....
AK415196.50
