01-21-2014, 04:24 PM | #1 |
Rep 91
Aftermarket suspension 101
I'm new to aftermarket suspensions, and I've been quite confused as to how certain suspension components benefit the performance and handling of a car. The concepts aren't really addressed directly in the posts here, so I was hoping some of you could educate me on how the aftermarket parts improve the car.
I understand some folks wish to lower their car mainly for aesthetic reasons, but I am really only interested in the performance aspect of the suspension. I have done two track days so far: Both times I noticed the massive suspension travel when I corner hard. In fact I saw a picture of my car where the clearance between the top of the inside rear tire and the chassis was over 6 inches... http://www.gotbluemilk.com/web130218...s/image29.html The roll was so extreme that I noticed the tire was rubbing against the chassis on the other side. What kind of upgrades would reduce this behavior? Is a set of coilovers going to solve it? Will the stiffer springs and damping settings essentially allow me to take those corners with very little roll? Do I have to add camber, or spacers to widen the track... etc? I've read a bit about suspension geometry but there are so many scenarios that we encounter in track driving that it's hard to wrap my brain around all of that at once. Also, my car has the adaptive suspension from BMW. I think it allows the damping to be adjusted, but even at it's max setting (Sport+ and DSC off) there's still a ton of roll. Are the coilovers going to work with this system? Last edited by abe12345; 01-21-2014 at 04:29 PM.. |
01-21-2014, 04:29 PM | #2 |
Rep 1,136
I'm getting the Dinan springs put on tomorrow on my sportline 335i non DHP. Will post review later in the week.
sent from bimmerpost Android app
01-21-2014, 05:57 PM | #3 | |
Rep 1,201
01-21-2014, 06:28 PM | #4 | |
Rep 91
01-21-2014, 07:25 PM | #5 |
Diligentia Vis Celeritas
558
Rep 1,477
Drives: 335i
Replacing the suspension with new aftermarket dampers and springs is a big step... coil-overs are inherently no better than a good set of traditional dampers/springs other than the ability to fairly easily adjust ride height, compression/rebound rates, and springs - which is why they are the logical choice for race cars that are adjusted for optimal performance on a variety of tracks.
In my opinion, the weak point of the F30 Sport suspension setup is the soft, progressive springs. Particularly with the electronic dampers (DHP), a set of firmer, linear springs like those that Dinan just released should match-up very well. (Post #125 in this thread provides a very positive first-hand experience from I think our first forum member on the new Dinan springs.) This is the route I have gone as well; my Dinan springs should be here in a couple of days. In the coming months, Dinan will also be releasing "Shockware", which will remap the EDC damping curves to change the "comfort" setting to what is currently "sport," and the "sport" setting to something entirely new... Steve Dinan feels that the OEM adaptive dampers are quite good, and all they really need is a bit of recalibration (and new springs) to dial-in the car's handling. If you get serious on the track, you may revisit the option of getting a nice set of coil overs from TC Kline, JRZ, Bilstein, KW, etc., but in the mean time, probably best to stick with the OEM dampers and upgrade the springs.
01-21-2014, 08:38 PM | #6 |
Rep 4,323
Or get the MPS with ARBs...literally flat around limerock, and unflappable.
01-21-2014, 09:40 PM | #8 |
558
Rep 1,477
Drives: 335i
If the OP were coming from a base suspension as you did, MPS would definitely be what I'd recommend. But starting with an M Sport (which already has the same thicker ARBs as what goes with MPS) and DHP, Dinan springs (and Shockware when it's available) are a much cheaper/easier way to go. Plus, he gets to retain the adaptive/adjustable damping for a softer ride while daily driving on the streets. As for whether the performance is similar... well my friend, you and I will have to sort that out if I make it up to Lime Rock this season : )
01-21-2014, 09:51 PM | #9 | |
Rep 4,323
You're correct, coming from an M sport is a different story...I missed that. I'd go straight bilstein cool overs then! The springs plus shock ware would be a great DD setup...
01-21-2014, 10:07 PM | #10 | |
Rep 1,201
01-21-2014, 10:34 PM | #11 | |
Rep 1,556
Coil overs are the best of both worlds. You are upgrading the shocks as well as the springs and you can control the height to your liking. Depending on how much you want to spend, you can get coil overs that are fully adjustable including dampening and travel. |
01-22-2014, 05:00 AM | #12 |
Rep 639
The only reason I am going with the MPS vs coil overs is the ride height. The minimum drop for coils is over 1". The MPS is .75"
Coming from a base suspension, new ARB was mandatory in my mind for any suspension upgrade. The best starting point is the msport suspension without dhp. Then you have the correct ARB and better shocks if you wanted a spring only change. Even MPS is more reasonably priced (less than a variant 2 kW coils). |
