BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Oem led fog light upgrade?
      02-17-2019, 02:42 PM   #1
Astone22
Drives: F30 320 xdrive, f32 428
Has anyone done the led upgrade on their foglights for a f32. I want to buy the oem foglights that are fitted on the newer 4 series. Does the wheel need to be removed to take the fog light housing out? I know there is one bolt behind the wheel liner. I also wanted to see what coding will need to be done thanks.
      02-17-2019, 07:34 PM   #2
328iX
David
328iX's Avatar
Drives: 2015 328iX F31
Led fog light upgrade:
https://www.ecstuning.com/b-genuine-...63177315559kt/
Coding is required to remove the cold/warm bulb checks otherwise they will flicker, i know that's what's done with the led bulb upgrade, according to ECS the coding is required for " major light out put upgrade"
The frontal wheel arch cover needs to be removed to get good access, it's like 10 bolts if I remember correctly. Wheel does not need to be removed but helps with easier access.
Here is the manual guide to access:
https://www.newtis.info/tisv2/a/en/f...lamps/KVQAwOYb
Regarding coding here is what is required to be modified quoted from Billfitz off another post on the subject
"It's in the cheat sheets that come as part of the ESYS package.
Low beams
FEM Body > 3061 > AL_L_KALTUEBERWACHUNG > Nicht_Active
FEM Body > 3061 > AL_L_WARMUEBERWACHUNG > Nicht_Active
FEM Body > 3061 > AL_R_KALTUEBERWACHUNG > Nicht_Active
FEM Body > 3061 > AL_R_WARMUEBERWACHUNG > Nicht_Active
High beams
In FEMBODY 3061:
FL_L_KALTUEBERWACHUNG > Nicht_aktiv
FL_L_WARMUEBERWACHUNG > Nicht_aktiv
FL_R_KALTUEBERWACHUNG > Nicht_aktiv
FL_R_WARMUEBERWACHUNG > Nicht_aktiv
Fog lamps
NSW_L_KALTUEBERWACHUNG » nicht_aktiv
NSW_L_WARMUEBERWACHUNG » nicht_aktiv
NSW_R_KALTUEBERWACHUNG » nicht_aktiv
NSW_R_WARMUEBERWACHUNG » nicht_aktiv"
      02-17-2019, 08:04 PM   #3
Astone22
Low beams
High beams
In FEMBODY 3061:
Fog lamps
Thanks for the Info! Do you think it can be done without removing the whole wheel well and instead just folding it back? Also I assume I can just use bimmercode to do the coding for leds
      02-17-2019, 08:12 PM   #4
328iX
David
328iX's Avatar
It's not the whole wheel liner, it's sectioned off. You can just remove the part in front of the wheel, it's a lot of bolts but none are hard to access and the panel isn't that big.
I'd personally remove it, just a few minutes and it will be a lot easier.
I've never coded but yeah it doesn't sound very difficult to code. I'm just not that knowledgeable with coding.
      02-17-2019, 08:17 PM   #5
Astone22
Thanks for the feedback! I wonder if I have that extra cooler on a 428 sport
      02-19-2019, 04:41 PM   #6
Astone22
Do I have to remove a aux radiator? On a 428? Also do I just turn off warm and cold check with Bimmercode? I see a area that also lets me switch the fog lights to led vs a bulb.
      02-20-2019, 01:18 AM   #7
328iX
David
328iX's Avatar
Not sure tbh, i got a 328d and theres nothing behind the cover
      02-20-2019, 08:01 AM   #8
Astone22
I think it's just the n55 motors that have the extra oil cooler! I'm hoping this install is easy
      02-20-2019, 10:33 PM   #9
Astone22
I realized the light I bought has one broken tab on the bottom it still has the tab to screw it in with and one bottom tab. Do you think it will be sufficient to hold it in?
      02-21-2019, 12:14 PM   #10
JDTX
Drives: 2016 428i GC Alpine White
2016 BMW 428i  [0.00]
Interesting.... If I upgrade to the LED fog lights, do they still work correctly with Adaptive Headlights? Appreciate any input.
2016 428i GC
      02-21-2019, 12:58 PM   #11
Astone22
Anyone have the exact coding I need to use with bimmer code ?
