BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Valve Cover Gasket Replacement on a F30 335i N55 DIY
      11-09-2018, 08:29 AM   #1
endlesss
Enthusiast
endlesss's Avatar
50
Drives: 2008 M3 Sedan
Hey all,
I have seen a lot of valve cover gasket DIY from older E90 N54 cars, but I couldn't find anything complete for our F30 generation N55 motors. Mine was leaking recently so I decided to replace it and document the process along the way. When I had my N52 a video like this helped a lot, so hopefully this helps some of you as our cars get to that BMW age where gaskets start leaking..
Appreciate 18
Logicoeur992.50
jh_f301307.00
bkdore103.00
Seba77W401.00
BashShah296.00
nickf3078.00
Polo088161610.00
atlguy25.50
spencers199.00
kern4174449.50
ali820271.50
dougt.ah3137.00
BWbimmer276.50
Tchao333.50
      11-09-2018, 09:15 AM   #2
Korvo
Respect My Authoritah
Korvo's Avatar
Drives: 2014 335i M-Sport
Thanks for this!!
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
      11-09-2018, 12:28 PM   #3
jh_f30
jh_f30's Avatar
1307
Amazing! I was just looking for this DIY last week. Thanks man!
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~
      11-10-2018, 01:23 PM   #4
endlesss
Enthusiast
endlesss's Avatar
50
Originally Posted by pdegene View Post
Thanks for this!!
Glad it helped!
      11-10-2018, 01:59 PM   #5
phat8186
phat8186's Avatar
Drives: G20 M340i F30 EBII E92 AW
Your a boss for this one, mods should def sticky this here even though it can be found now in youtube.
      11-10-2018, 03:35 PM   #6
Seba77W
Seba77W's Avatar
401
Drives: BMW 435i Xdrive Coupe
Very nice
2014 435i xDrive M-Sport, Fabspeed cat, Active Autowerke axle back, CTS Turbo intake, ER charge pipe, ER Competition Intercooler, MHD Tuning Stage 2+
      11-10-2018, 03:46 PM   #7
perryo91
perryo91's Avatar
Uganda
373
Drives: 335
Thank you very much for posting this, I just got this done under warranty (thank jesus) because this looks like a decent 3 hour job for me. I was smelling oil and seeing smoke coming from my cat area just like you described too. After getting down and looking through the underpan of my car I saw fresh email way up in the engine through a little gap through the underpan.
Hi
      11-11-2018, 05:38 PM   #8
47Straight
Drives: 2013 BMW 335i Sportline
Awesome timing. I need to do this job soon. Much thanks!
      11-11-2018, 09:57 PM   #9
Sea-Tac
Sea-Tac's Avatar
Drives: 2108 X3 xDrive30i
Good clip. Thanks.
      11-12-2018, 09:15 AM   #10
atlguy
atlguy's Avatar
26
Drives: 2014 335I MPPK
Thank you!!
      11-18-2019, 11:43 PM   #11
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
When are you guys seeing valve cover gasket failures? Mileage-wise?
      11-19-2019, 12:29 AM   #12
jh_f30
jh_f30's Avatar
1307
I did mine at 113k. Probably could've done it sooner, but at about 110k is when I started really noticing the burning oil smell after a drive.
exE36M3487.50
      12-04-2019, 01:54 PM   #13
dougt.ah3
dougt.ah3's Avatar
Drives: AH3 Msport; F150 XLT
Noticed the smell today and appears to be the valve cover gasket. Car has 113,500 miles.
Thanks for creating the video ... very helpful and easy to follow.
Recommendation to those replacing their VCG. Highly suggest removing the coolant expansion tank hose as it is very brittle and will break if you happen to put pressure on the line. Mine did break at the expansion tank.
2013 Active Hybrid 3 | M Sport | Alpine White | Coral Red | BM3 Stage 2 | ER FMIC | FabSpeed Catted DP | ER CP |
2016 F150
2021 RnineT
2022 K1600B
exE36M3487.50
      12-06-2019, 02:47 PM   #14
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Thanks guys, super appreciate the feedback. I was warned by a local shop that this was coming and it's not as easy as the E36/S5X block - more stuff to unhook/onbolt. I'm at 60k so looks like there's some time to go.
      12-06-2019, 03:58 PM   #15
fuse27
Driver
fuse27's Avatar
Drives: 2020 M2 Competition
I'm at just short of 80k miles and I'm due. And there's another gasket issue (oil filter?) that made my Indy shop quote $2500 for all of it. At least that includes a new valve cover.
Current: '20 M2 Comp | Black Sapphire Metallic | Stock AF
Former: 2013 BMW 335i xDrive | Mineral Gray Metallic | DINAN Stage 3 [traded] - 2000 BMW 323Ci | Jet Black [RIP]
      12-07-2019, 10:51 AM   #16
jh_f30
jh_f30's Avatar
1307
Oil filter housing gasket is a common weak point (along with the oil cooler gasket). Not too difficult if you want to take a crack at it yourself. Gaskets alone are only about $20-30. A handful of tools and a couple hours and you could save upwards of $1000. My local dealership quoted me around $1200, did it myself for under $100 all in.
VCG is substantially more complex. But with some research, still very DIY-able. Guess it comes down to your ability, willingness, and desire to do your own wrenching. If you do, you could trade some of your time to save about $2000.
Wgosma806.00
fuse2710.00
      12-07-2019, 07:26 PM   #17
Fredo
Drives: 2012 335i
My mechanic replaced the valve cover on my 2012 F30 335i at 85k miles. FYI, this is the list of parts he replaced:
11127570292 N55 valve cover
11367609963 Valvetronic screw (2)
11127599753 Vent hose
11377502022 Valvetronic seal
      12-08-2019, 09:59 AM   #18
fuse27
Driver
fuse27's Avatar
Good to know. I researched VCG replacement, and with how involved and time consuming it is for an experienced tech, I think it's just outside of my comfort zone. I hadn't yet looked into what the oil gasket repair would take, but perhaps that's more my speed. I replaced the spark plugs in the B8 S4 I had prior to the F30, so I'm not completely inept. And saving myself $1k would definitely be worth it. Thanks for the suggestion.
      12-08-2019, 10:32 AM   #19
Wgosma
Drives: 2012 F25 X3 28i (N52)
Just did both gaskets on N52 (no turbo); OFH gasket easy, VC another issue...after doing it I think $750 for Mr Mechanic labor would have been more enjoyable idea 😉
Look at the OFH DIY stuff, there is one bolt under intake manifold that requires removal - think it can be removed w/o touching manifold, but double check on that point.
      01-13-2021, 08:02 AM   #20
XxThe_RemedyXx
XxThe_RemedyXx's Avatar
967
Drives: 2016 340i xDrive
Hey all... I'm going to tackle this myself and I see FCP Euro has a kit on sale. It comes with three different bolt types and sizes for the job. Anyone know where specifically these replacement bolts go?
https://www.fcpeuro.com/products/bmw...92#description
(8) 11127544369 ASA bolts, (14) 11127576310 ASA bolts, (2) 11127584156 ASA bolts
      01-31-2021, 12:40 PM   #21
Tchao
Boost Addict
Tchao's Avatar
334
Drives: E30, E82, F30, F87
They should come preinstalled onto the VC itself. All you need to do is screw it down to the head.
Also, thanks for the video OP!!! Just starting my VCG replacement now.
S55 M2C | Three Pedal Club | E30TU
      01-31-2021, 12:54 PM   #22
dmaxdmax
dmaxdmax's Avatar
Drives: 2016 M235i 6-spd
...my understanding is that the valve cover on my b58 has an integral pcv and does need to be replaced.
But, I'm hoping, by the time I need my vcg done, someone will have made a replacement diaphragm to save us the cost of a whole cover. Not sure on your engine, but according to fcp euro, you only need the cover if it's cracked. Just saying.
'92 325i, '99 328i, '16 340i, '16 M235i all manuals
dmax on FB
My last pre-covid standup set
