06-07-2020, 05:40 PM | #1 |
Rep 57
18x9.5 +38 Square setup F30 *TIRES?*
Hey everyone, just purchased a new set of rims for my F30 335i xDrive.. the new setup is 18x9.5 +38 squared..
I'm on Billstein Coilovers, I'm looking for input on what size of tires I should run?.. was thinking 255/35/18 and also what tires you guys recommend have had a few people direct me to the Firestone Indy 500's. Thanks a lot!! |
06-07-2020, 06:27 PM | #2 | |
Rep 870
06-07-2020, 06:29 PM | #3 | ||
Rep 57
https://www.turnermotorsport.com/p-3...f32-428i-435i/ Unfortunately I had to pay quite a bit more cause I'm in Canada 😂 |
06-07-2020, 06:29 PM | #4 | |
Rep 870
06-07-2020, 06:31 PM | #5 | |||
Rep 57
06-07-2020, 06:32 PM | #6 | ||||
Rep 870
06-07-2020, 06:34 PM | #7 | |||||
Rep 57
06-07-2020, 06:42 PM | #9 |
Rep 57
06-07-2020, 06:53 PM | #11 |
Rep 57
Yeah forsure, just didn't know it was forsure 100% mandatory needed to clear the strut.
06-07-2020, 09:51 PM | #12 |
Rep 4,329
oem diameter for 3/4 series is 26".
255/35/18 is 25". your car will be 1/2" lower due to sidewall height and you'll have to lower your car 1/2" more to have the same gap. you'll also be accruing 400more miles every 10000 and your speedo will read 5mph high. indicating 65 but going 60. your acceleration from a dig should be better since you're shortening the gearing. if you're happy with all of this, have at it. i'd just stick with oem size 255/40/18 |
johnung4528.00 BoostedGirlDad1.50 |
06-07-2020, 09:53 PM | #13 | |
Rep 57
Yeah I'm fine with all that relatively.. will take some dialling in of fitment etc. You would say 255/40/18 over 35 sidewall? I'll still clear fine with the 40? Thank you! |
alohasurftoad3079.50 |
06-07-2020, 10:04 PM | #14 | |
Rep 4,329
slicer has 19x9.5" ET35 with 255/35/19(26") https://f30.bimmerpost.com/forums/sh...8&postcount=16 i think the problem you'll have is not the tire but the wheel lip touching the strut. yours will be approximately 3mm closer than slicers. does it look like there's over 3mm of space on slicers? i think you may need a 3mm spacer up front. 255/40/18 ET38 will not contact the spring perch or strut. a 3mm front spacer will put your wheel lip where slicers is |
06-07-2020, 10:06 PM | #15 | ||
Rep 57
06-07-2020, 10:18 PM | #16 | ||
Rep 870
06-07-2020, 10:28 PM | #17 | |
Rep 4,329
what is the offset (also called ET) of your wheels? |
06-07-2020, 10:48 PM | #18 | |
M Enthusiast
438
Rep 626
Drives: 2018 F80 M3 ZCP
Run 255/40 And you'll for sure need a 5mm spacer up front at least. I barely have enough space even with a 5mm. Im on ST coils. For tires, it depends on your budget but I personally run Michelin PS4S. Lmk if you need a pic for reference.
2018 F80 M3 ZCP - CCB - MPE - BBS RI-D - Pure Turbos Stage 2+ - 3D Design Bumper - KW Clubsport 3 Way - Cary Jordan E85 Tuned
2021 F97 X3MC 2017 F30 340i (SOLD) 2015 F82 M4 (SOLD) |
06-07-2020, 10:50 PM | #19 | ||
Rep 57
06-07-2020, 10:59 PM | #20 | |
M Enthusiast
438
Rep 626
And sure, here are some pics of my current set up.
CitrinF3022.50 alohasurftoad3079.50 |
06-07-2020, 11:01 PM | #21 | ||
Rep 57
06-07-2020, 11:04 PM | #22 | |
M Enthusiast
438
Rep 626
So yeah, 255/40 will work best IMO. That's also what majority of the people run anyways.
Polo088161610.00 |
