BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 EWG-L-P and EWG-L-9 map updates are out!
      02-11-2020, 11:36 PM   #23
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
I just got back home... it's available, I just flash the v4.5 91 Oct stage 1 OTS.
      02-12-2020, 12:56 AM   #24
jan31
jan31's Avatar
Drives: 2014 F32 428I Xdrive (N26)
Originally Posted by Halim@HCP View Post
Originally Posted by jan31 View Post
This apply to N26? I'm on Hawaii, gas here is 92oct. Also, I'm looking on getting stage 1, what I need to upgrade for that?
Yes for N26, for stage 1 you don't need any hardware changes.
Thanks for the info
      02-12-2020, 11:24 AM   #25
Snoopy8
Snoopy8's Avatar
Drives: 2014 bmw328i xdrive
Does it depend on the dme that you get acn91 map and just regular 91 map? I got MY14 F31 and the first map i see is stg1 91 oct map.
      02-12-2020, 11:35 AM   #26
Big.Al
Instagram @F82_Al
Big.Al's Avatar
33
Drives: 2017 F82 M4
Gonna clear up this confusion there is no 91 ACN map for n20/n26 model vehicles there is however for n55 from my knowledge. When I said acn 91 I was referring to the type of 91 being used on the log not the map as a whole.
Insta @f82_al
      02-12-2020, 11:37 AM   #27
sspade
sspade's Avatar
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Why is it that an N55 would require a special ACN map when the N20 does not... when both are running the same quality fuel?
(both in Arizona California Nevada or "ACN" / 91 fuel)
Can someone explain, its a bit confusing.
ex. a friend and I meet up at Shell to fill up with VPower 91 (in California)... He has the N55 and needs to run an ACN91 map and I have an N20 and can run a regular 91 map. Why?
      02-12-2020, 01:21 PM   #28
wesmeister
wesmeister's Avatar
Drives: 2016 F31 M Sport
Please get me a log on the ACN91 and send logs to support@protuningfreaks.com and I will correct and make ACN maps asap.
I will do that this weekend. We are heading into even crappier "summer mixture" territory here in California, so it's super important we get an ACN version of this.
Anything in particular you want me to log beyond the standard parameters? What kind of pulls would you like to see?
      02-12-2020, 01:27 PM   #29
wesmeister
wesmeister's Avatar
California, Arizona and Nevada 91 will work. BUT, the actual quality of our states gasoline and it's RON numbers are suspect. We even have different mixtures depending on the time of year. But in short, it's way safer to run a ACN tune if available.
Based on what Halim said, he just needs logs from one us to make the minor adjustments to the tune. I'm going to try and get these logs for him this weekend.
      02-12-2020, 02:54 PM   #30
Big.Al
Instagram @F82_Al
Big.Al's Avatar
33
Drives: 2017 F82 M4
I sent over a few logs to him through support and posted on here as well I'm from California as well so hopefully he can do something with them
Insta @f82_al
      02-12-2020, 03:08 PM   #31
wesmeister
wesmeister's Avatar
Awesome. I'll still send him some also, as I have the stock Stage 1 tune with no mods, so that might help him with that specific tune. The more data he has, the better!
      02-12-2020, 05:59 PM   #32
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
You can see pretty clearly by the frequency with which they update and features that they are more concerned with the N55/B58 than N20/B48, and for good reason: they're far more popular as far as tuning goes. I would imagine this is another thing like startup roar: bigger engines get it and the N20 doesn't, even though it could work on N20.
sspade2475.50
      02-12-2020, 06:22 PM   #33
sspade
sspade's Avatar
So... this essentially means that the 4cyl tunes are slightly less safe than their 6cyl counterpart? This makes me glad I havent flashed stage 2 yet.
      02-12-2020, 08:02 PM   #34
andino
Drives: F31 328i xdrive
Not necessarily less safe, just less tested. They probably get a lot more data from 6cyl cars to work with than with the 4cyl. I don't see anything suspect with my logs other than one cylinder with lazy timing compared to the rest but nothing that indicates the car isn't healthy. Whether its Stage 1 or 2, less data would be equally impactful to each tune so staging stage 1 doesn't really mitigate any risk imo.
2016 328ix F31 - SOLD!
2006 997.1 C4S
      02-12-2020, 08:38 PM   #35
sspade
sspade's Avatar
Considering stage 2 is more aggressive and requires hardware modifications, I beg to differ. This is just common sense. Not really worth debating. More aggressive tunes definitely stress certain parts of the engine more than less aggressive tunes.
But... on the development side, less data to work with would be equally impactful for both stage 1 and stage 2. Agreed.
      02-12-2020, 08:42 PM   #36
sspade
sspade's Avatar
According to Bootmod3 FB group... 91 ACN tunes are now available for flash...
      02-12-2020, 10:23 PM   #37
rjd_F30
rjd_F30's Avatar
As stated above, I would not interpret that as less safe, though I would see why you may be inclined to do that. It comes down to a matter of popularity. More people are tuning the 6 cyl cars than the 4 cyl ones, so PTF devotes more time and resources to 6 cyl tunes. If something is wrong with a 4 cyl tune making it unsafe, they'll jump right on it, but they'll be less likely to add features like startup roar, or an ACN specific tune for instance.
      02-12-2020, 11:53 PM   #38
andino
I ACN91 only for PWG it looks like. Nothing for EWG maps it looks like.
2006 997.1 C4S
      02-13-2020, 01:47 AM   #39
MilanF30
Drives: BMW F30 328i
My car is PWG and I can see new ACN maps for Stage 1 and Stage 2 v4.3 from February 12 2020.
      02-13-2020, 07:28 AM   #40
GreenF30N26
GreenF30N26's Avatar
153
Drives: F30 328ix N26
What’s the expected increase on the stage 2 maps now that these tweaks have been made testing on stage 1? Is there a rough % between the stages knowing Stg2 has DP/FMIC upgrades. Wondering if I should just move from Stg2 map 4.3 to Stg1 map 4.5 if they will be about the same gains. Starting to get really nervous too much power for our engines.
Also, would any changes to the trans tune be necessary to compliment these new tweaks?
      02-15-2020, 11:19 AM   #41
GreenF30N26
153
Found the answer to my own question on the PTF website. Stage 2 isn’t a huge jump from stage 1 in power as people have suggested but here are the official gain estimates to validate against. I see why the 20i engines are popping on stage 2.
N20 20i
Stage 1 91 octane: 48%HP / 54%TQ
Stage 1 93 octane: 52%HP / 56%TQ
Stage 2 91 octane: 54%HP / 58%TQ
Stage 2 93 octane: 56%HP / 60%TQ
N20 28i
Stage 1 91 octane: 16%HP / 26%TQ
Stage 1 93 octane: 18%HP / 28%TQ
Stage 2 91 octane: 24%HP / 35%TQ
Stage 2 93 octane: 26%HP / 38%TQ
      02-15-2020, 11:34 AM   #42
Gen13 F36
Gen13 F36's Avatar
N20 20i
N20 28i
Wait... what is this?
First post on this thread comes with a dyno for 283HP / 324 LBTQ from a n20 28i 93oct ots s1. That can't be 18% HP / 28% TQ.
On a side note... N20 20i gain according to this is mind boggling. (I thought the n20 20i have weaker internals). This is probably why they blowing up.
      02-15-2020, 12:06 PM   #43
anotheran
Sedan Driver
Drives: A nice car
It’s 19.6% compare to their baseline stock of 236.8 so pretty inline with their % estimates
Slapping on M Performance parts, ZHP, badges, and stickers does not ///M car make
ZCP | ZHP | ZTR | ZE0 | MSport | ZMP | DHP | MStickerPack | THP | MPPSK | MPPK
BMW MSP Lightweight Jacket | DTM Motorsport Team Cap| BMW M Drift Cat 5 | BMW M Thermo Mug
sspade2475.50
      02-16-2020, 06:02 AM   #44
bgalakazam
bgalakazam's Avatar
Drives: 2015 328i
2015 BMW 328i  [0.00]
I found more of a jump stage1->2 than going stock->1. But adding a downpipe probably did help. I already had the intercooler in stage 1.
