08-12-2019, 03:42 PM | #2686 | |
Rep 2
I only struggle with the volume settings of my device. The navigation output from the left speaker is now very loud and when I get a call (it also only comes from the left speaker) the volume is very low although I set the volume in the audio settings to max for calls. Do you have any idea how to set all the volumes correctly? |
08-13-2019, 01:19 AM | #2687 |
Rep 11
08-13-2019, 06:25 AM | #2688 |
Rep 237
any way to enter the recovery of these unit? I need to do a full wipe, it doesnt recognize my screenlock pin anymore... The back reset button does only a soft reset
08-13-2019, 07:30 AM | #2689 | |
Rep 1,048
only way would be via ADB, has usb debugging been activated at some time by you ? Chri |
08-13-2019, 09:40 AM | #2690 | |
Rep 219
Drives: MINI Cooper, 2020 X1
px6.zip: hxxps://mega.nz/#!VRkSCSpT!1TiqSoyrnT0DBrj52lilb3GRcv3yH3tIlQsbrfE Uz1Y px3.img: hxxps://drive.google.com/drive/folders/1mWtI61GU8GReGQ-PjwcjBjFXM34EGaoE |
Kri1083.50 |
08-13-2019, 11:16 AM | #2691 | |
Rep 80
08-13-2019, 11:31 AM | #2692 |
Rep 219
In my opinion it has nothing to do with MCU, it's an android daugther board thing: hxxps://github.com/chinesebmwheadunits/chinesebmwheadunits.github.io/wiki/Hardware
however, each android daugther board has its own firmware, eg you cannot use px3 for px6 and vice versa, even if they are mounted on the same MCU !!! Last edited by smahel; 08-13-2019 at 11:39 AM.. |
Pondaire37.00 |
08-13-2019, 02:26 PM | #2693 |
Rep 237
once in recovery, scroll should be brief press of reset, select long press.
Anyway, my platform is NOT px3 nor px6, it's a "newer" snapdragon 625 , not a rockchip. So no way for me with the well known zip in the wild, I need the recovery to format and do a full wipe, or do anyone have the correct zip for snap 625 android 9 headunit? It happened I set the screenlock pin (my google account is under mdm so I need it) and now the unit doesnt recognize it :/ Last edited by floc; 08-13-2019 at 02:52 PM.. |
08-16-2019, 04:06 PM | #2696 |
Rep 1,048
08-17-2019, 02:21 AM | #2698 |
Rep 1,048
Yep it is, i also have a Snapdragon HU now, and There are still Bugs at 2.0.5 Chri Last edited by Kri; 08-17-2019 at 08:15 AM.. |
08-17-2019, 03:21 AM | #2699 |
Rep 237
any chance to get these files for snapdragon headunit?
08-18-2019, 08:23 AM | #2700 |
Rep 45
I just received and installed unit, don't have any update files.
For now I have problem with - not working simcard - bluetooth can't connect with my iphone - I can't choose any custom navigation app to make a "navigation" shortcut (except googlemaps.. but I am not using it) - My usb DAC is not working with this unit... sound is dissapearing after connecting do USB port EDIT. I have fixed problems with USB DAC by removing internal AUX connection between android and CCC. Last edited by Kuj0n; 08-18-2019 at 12:26 PM.. |
08-21-2019, 02:46 PM | #2701 | |
Rep 32
Any clues of what may cause this kind of behaviour ? I have check the LVDS connector which is correctly plugged. Thanks |
08-21-2019, 02:50 PM | #2702 |
Rep 153
On BMW interface? Long press MENU on idrive, see if it switch to BMW side.
08-21-2019, 04:20 PM | #2703 |
Rep 32
08-22-2019, 02:27 AM | #2704 |
Rep 153
08-22-2019, 04:05 AM | #2705 |
Rep 32
Ok I will try to this, in the meantime, I have seem somewhere that may be the car type is not well configured in the android settings menu ?
08-22-2019, 09:34 AM | #2706 |
Rep 6
Hoping someone can help here as google has let me down.
A firmware update has left by 7.1 AVIN unit dead. MCU is fine but SOM has lost its image and when I swap to the android screen, I get "No Signal" Reversing screen is working away fine, as is the idrive, so the underlying MCU looks ok. I have tried bootable USB, booting SD, renaming PX3.img to PX3_reset.img, format etc I have concluded that the SOM is wiped completely. Does anyone know a source for a replacement SOM? Mine is a ZXW_870 and Ver_03 with 2 rows of pins on both the top and bottom of the module. Any pointers would be much appreciated. |
