01-29-2018, 06:34 PM | #1 |
Rep 89
Wheel size question for F30 MSports.
Hi All,
I'm planning to purchase some rims for my F30 335i MSports, the sizes are 19x9.5 et22, 19x10.5 et34. Does anyone know if there would need to be modifications done to the car (fender rolling or camber) with these sizes? Thanks! |
01-29-2018, 06:49 PM | #2 |
Rep 495
Setup is a bit agressive. You will have to put negative camber to make it fit which mean, new tires every 6 months if you drive the car like the way it should be driven haha
Bmw 435M 2014 Convertible SOLD!
Bmw 340i X drive 2018 New orange sunset, Manual transmission, M performance I & II, M performance front lip, side extension rear diffuser, tinted windows. : SOLD Back in old N55 love! Bmw 335 EBII M performance edition : ER Downpipes, VRSF Chargepipe, VRSF HD 6.5 Intercooler, BM3 Stage 2 93 octane, MPPSK, H&R Spring |
01-29-2018, 08:30 PM | #3 |
Rep 89
01-29-2018, 10:49 PM | #4 |
Rep 89
Btw, do you happen to know what is a good size that wouldn't require camber or modifications?
01-31-2018, 01:45 AM | #6 |
Rep 89
Thanks for the info! Do you know if there is any way to get 19x9.5 et22, 19x10.5 et34 these sizing to fit on the car without rubbing?
01-31-2018, 02:33 AM | #7 | |
Rep 4,367
http://f30.bimmerpost.com/forums/sho...d.php?t=909786 |
beeyar16.00 |
01-31-2018, 06:20 PM | #8 | |
Rep 25,989
This is what 19x8.5 ET35 and 19x9.5 ET45 looks like. No modifications required.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
beeyar16.00 |
02-02-2018, 02:05 AM | #9 | |
Rep 89
19x8.5 +30 19x10 +45 I should be fine right? What tire size would you recommend with these wheels. I like the low profile look. |
02-02-2018, 02:54 AM | #10 |
Rep 4,367
235/40/19F, 265/35/19R is what I would get, however if your car is lowered, you could do 235 or 245/35/19F, 275/30/19R for "lower profile looks". your speedo will read higher than actual, if you care. if your car is not lowered the 1st set up is better for reducing fenderwell gap, whereas the 2nd setup will increase it.
beeyar16.00 |
02-03-2018, 12:15 AM | #11 | |
Rep 89
Ah okay, that makes sense, thanks for the advice! My car will be lowered with Dinan springs so it will only lower it about 3/4" in the front and back so pretty moderate. I tried your suggested tire size on the link below to get a feel for it and I think I like this setup 235/35/19F, 275/30/19R. But why would the speedometer read higher than actual with this setup? http://www.rimsntires.com/specspro.jsp |
02-03-2018, 12:27 AM | #12 |
Rep 4,367
from the factory F30,1,2,3,6 come with 26"ish diameter. running a smaller diameter causes the speedo to read higher than actual, conversely a larger diameter reads lower than actual. fyi bmw speedo has an error built in that reads higher than actual to begin with so running a smaller diameter than 26" will exacerbate the error. larger or smaller diameter tires than oem affect the odometer as well. these errors are small so most people dont care about it, but i do
02-03-2018, 06:26 AM | #13 |
Rep 89
Really? I would think BMW would be smart enough to calculate based on whatever setup you have instead of hard coded to only use factory as default. When you go a mile on your car it should know when you hit a mile, at least the GPS on the car knows...
02-03-2018, 08:00 AM | #15 |
Rep 495
I've run several tire setup. A good tire for me, daily driving, good performance but good life range, is the Toyo proxes 4.
02-03-2018, 08:31 AM | #16 |
Rep 4,367
if you do not want to break the bank the best bang for your buck summer tires
1) continental extremecontact sport 2) hankook ventus v12 evo2 if you can spend more 1) michelin pilot sport 4s 2) pirelli pzero pz4 http://f30.bimmerpost.com/forums/sho...x5+continental Last edited by alohasurftoad; 02-03-2018 at 09:10 AM.. |
02-03-2018, 02:03 PM | #17 |
Rep 89
Nice, let me do some research on each of them. Did you go with the run flats? Also, looking at the wheel and tire thread you posted lkstaack 10:59 PM 01-15-2018 is on Dinan spring as well with similar wheel size as you suggested that you would go with 235/40, 265/35 and like you said the fender to wheel gap is less, which I kind of like. Since my springs does not lower my car that much I think the low profile look will cause a greater wheel fender gap and might not be how I expect. I might have to go with the one Yu suggested above. There should be no rubbing issues correct ?
02-03-2018, 05:35 PM | #18 |
Rep 4,367
if you want performance and ride you'll have to omit runflat. i bought a scissors jack, 17mm lug socket and breaker bar, portable 12v air compressor and tire plug kit for an emergency. if you have a big rip in the tire i'm not sure how well a runflat works for that anyway.
no rubbing with 235/40 265/35, fill fenderwell gap, better ride & impact protection, fixes bmw factory speedo error. f30jetsfan has 235/40 265/35. kfc2 has 235/35 275/30. lstaack has 245/35 265/35, 25.8" 26.3", staggered diameters causing slight forward rake if you don't mind it |
beeyar16.00 |
02-03-2018, 06:27 PM | #19 | |
Rep 89
Also, with the 235/40 in the front, since the tire diameter is larger this will also create less fender gap in the front compared to Istaack's setup (245/35) right? Because after looking at his fender gap between the front and back some more, I feel like his rear is slightly less than his front. Or it could just be all in my head Last edited by beeyar; 02-03-2018 at 06:40 PM.. |
02-03-2018, 07:31 PM | #20 | |
Rep 4,367
re lstaack, front gap is more than the rear gap. if he had adjustable coils, lowered the front only, reducing the front gap to match the rear it'd prolly look more even. from a profile view 235/40 has less gap than 245/35, however the 245/35 shoulder is 5mm closer(to the fender arch) and sidewall more vertical which helps to close the gap difference somewhat. |
02-04-2018, 12:23 AM | #21 |
Rep 89
Interesting. I think I get what you mean. So basically you’re saying the Istaack setup for the front wheels will have less of a fender gap than the 235/40 even though the diameter is larger for the 235/40?
02-04-2018, 12:47 AM | #22 | |
Rep 4,367
the more flush the shoulder of the tire is to the fender arch, vertically as well as laterally, via being taller, wider, bulging "flusher", etc reduces fenderwell gap. conversely the if the tire is narrower, shorter, stretched, tucked, etc increases it. http://f30.bimmerpost.com/forums/sho...light=lkstaack |
