02-26-2015, 05:23 PM | #89 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
so, im doing the rears right now, there isnt an instruction manual for our car is there? because the top spring perch just doesnt fit in the mount on the car.....it moves around and stuff. is it supposed to?
and rubber piece for the bottom fits on the mount, but the surface under the rubber piece isnt flat, so wont that cause the spring to eventually rub a hole through the rubber piece?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
02-26-2015, 06:20 PM | #91 |
515
Rep 1,063
Well on the top part, it doesn't sit flush against anything, or fit in the hole at the top.
02-26-2015, 06:55 PM | #92 |
e92 - 335i
179
Rep 743
Be sure to remove #10,11,12,13 in illustration.
I accidentally left mine in at first but everything still fit. Last edited by f30luxline; 02-26-2015 at 07:25 PM.. |
02-26-2015, 07:01 PM | #94 |
Rep 10,277
Sean@PSI,
Could use your assistance. As mentioned previously, I have 2013 BMW 335i xDrive and want to maintain the same OEM height. Another dealer selling BC Racing BR Coilovers indicated that even at a maximum height setting BR Coilovers would still lower the vehicle by 1 inch. Local BMW tuning shop indicated the same. What's the best way to confirm prior to purchasing that the same OEM height can or cannot be maintained with BR Coilovers? Appreciate your help. |
02-27-2015, 12:26 AM | #95 | |
2145
Rep 5,011
02-27-2015, 12:27 AM | #96 |
2145
Rep 5,011
02-27-2015, 08:42 AM | #97 |
Rep 3,089
Unrelated question here guys but where are you putting your floor jack to lift the car? I assume you are using the recommended "slotted" positions for the jack stands? Or did you put the car on ramps?
02-27-2015, 08:57 AM | #98 | |
e92 - 335i
179
Rep 743
#2 shown here is almost the exact location where the jack is to be placed. |
Operator Mo64.50 |
02-27-2015, 09:49 AM | #99 |
Rep 3,089
Thank you! So to make sure I understand you, you have to first put your car on blocks to create enough clearance for your floor jack to be able to get under the rear diff?
Another dumb question...how stable is it jacking the car up under these center points? Does it make sense to put a wide piece of wood on the floor jack lift point to create more stability?
02-27-2015, 11:07 AM | #100 |
515
Rep 1,063
I use my low pro jack and place it on the front edge right before the wheel well starts and jack it up, it raises the other side high enough to fit my regar jack under and then jack up the other side. I have jack stands with tips that fit in the BMW jack points, and I place wheel chocks behind the front tires.
02-27-2015, 05:55 PM | #101 |
Rep 3,089
Did you get er done???? Pics please!
02-27-2015, 06:02 PM | #102 |
515
Rep 1,063
03-04-2015, 08:14 AM | #104 |
Rep 3,089
Inquiry minds want to know....
03-04-2015, 09:39 AM | #107 |
Rep 1,029
Drives: 2019 440xi Gran Coupe
03-04-2015, 10:09 AM | #108 |
e92 - 335i
179
Rep 743
03-04-2015, 10:35 AM | #109 |
Rep 1,035
lol.. tell me about it
I don't even consider myself slammed, but its still a royal PITA when i had to figure out how to jack the first time. I had to create a special 4-step ramp out of 2x12's to allow my lip to clear each next step before the wheels hit. At the top of the 4-step ramp, the car still only had barely enough space for me to slip a low-profile jack under the front. I only have a couple of inches of vertical jacking room when i first start to jack, so it takes me like 30 tiny pumps to start the car going up When there's a will, theres a way... |
03-04-2015, 10:42 AM | #110 | |
Rep 577
For jacking I got an Aluminum low profile racing jack from Harbour Freight for like $80. Works a treat. I can get both sides on jack stands in no time. |
