06-03-2019, 04:46 PM | #1 |
Rep 21
Bimmercode Launch Control Confusion
Hey guys, I've read tirelessly through threads and I just can't figure out how to get launch control on my car. I have a 435i M Sport with the sport transmission (why doesn't this damn car come with launch control from the factory??). Anyway, I just cant figure out which options to enable in expert mode since a lot of the posts on here are pertinent to people with base models or different models altogether.
TL;DR Which options in which modules in bimmercode for someone with a 435i & sport transmission? |
06-03-2019, 08:44 PM | #2 |
Rep 5,457
Drives: F30
What year?
Not available until model year 2014 as far as I know... |
06-04-2019, 10:02 AM | #3 |
Rep 21
Its a 2016. Whats strange is everything is showing enabled. LC is aktiv in bimmercode from factory and a few other things I was told to change are already aktiv. Would a 435i M sport with the sport trans come with launch control?
06-04-2019, 10:08 AM | #4 | |
Rep 5,457
Drives: F30
It can be a bit finicky to actually engage though... My car did not come with LC from factory but I can confirm BimmerCode definitely works and have tried it twice now and it works perfectly. Also swapped the 2TB shifter in as well but that is purely cosmetic. I believe there is a correlation between paddles and the Sport Trans package. My sport steering wheel does not have paddles... guessing yours does? |
Silverlining_m21731.50 |
06-04-2019, 10:23 AM | #5 | |
Rep 21
Guess I'll give it a go! I must have been doing it wrong this whole time. But yes, from what I've heard the paddles come with the sport trans package and is the only tangible benefit of the package, the rest can be coded in or flashed onto the trans itself. I like the paddles, but when the wheel is inverted, like while turning, they're almost useless and I have to use the drive select shifter. Wish they stayed in place.
2016 435i M Sport - Sport Auto Trans - M Sports Suspension - HarmanKardon - Comfort Access - Driver Assist - Surround View
sspade2464.50 |
06-04-2019, 04:39 PM | #6 |
Rep 2,808
Drives: F33 430 and F39 M35i
silly question for you (I'm guilty of this when I first got my car).
Are you letting your car warm up first? drive it like 7-10 miles before trying launch control? I tried it right after starting the car up one night after work and it didn't work. Had to look it up. |
jeffc83725.00 |
06-05-2019, 05:23 PM | #7 | ||
Rep 21
06-06-2019, 12:28 AM | #8 |
Rep 43
my 320d msport has the sports trans with the paddles but when i go into expert mode in bimmercode no LC option to turn on...oh well such is life
06-14-2019, 02:48 AM | #9 |
Rep 3,566
A clue to whether or not your car has LC is to navigate through the owner's manual on the car's computer to see if it shows how to setup LC.
If it doesn't show up on the screen, your car isn't coded for it to be 'aktiv' or it's just not available on your car.
328i M-Sport, Estoril Blue, Carbon XP 35 Tint, front heated seats, black Dakota, Sports Suspension, Anthracite Headliner, HUD, Pro Nav, Sunroof, hk 600w, Bi-Xenon, 19" 403M wheels, Reversing Camera, DAB+, Xenon, BT Ext Connect, MST turbo intake pipe, MST Cold Air Intake, JB4 on Map 2 with Catless DP produces awesome performance in Sport.
05-17-2020, 01:38 PM | #10 | ||
Rep 1,235
2023 M2. ZB. Manual.
2024 m235i |
bimmercode, expert mode, launch control, m sport, sport transmission |
