04-30-2020, 06:58 AM | #1 |
Rep 296
120408 and 123432 after spark plugs change/engine cleanup
Hi guys, I have stage 3 car on BM3 custom tune (pure 800, dp, chargepipe, wmi, BMS CAI, TU HPFP) and had spark plugs changed for the supra ones and also the engine and fuel injectors cleaned for carbon deposits. The cleaning guys gave me some additive to put in 1 fuel tank to finish it. Of course me being me I went to test the car and low and behold it was slower .
Made logs which indicate more pulled timings down low (same top-up, but more pulls down low across more cylinders). At the end of the drive, I got drivetrain malufunction and reduced power. I checked the codes and among the ones i know of, I found 2 key ones: Engine (DME) 123432 Electric Wastegate, Stop Learning: Stop position (weastegate closed) outside tolerance Engine (DME) 120408 Change pressure control, shutdown: pressure build-locked My question is - can these be tied to the spark plugs change or the engine cleanup? I found thread here that mentioned a suggestion which solved their problem and they also had spark plugs changed: "The vacuum lines to the pressure converter were installed backwards" -> can this be it? THANKS! |
04-30-2020, 10:05 AM | #2 | |
Rep 232
YT: Conrad B
IG: conradb_93 |
04-30-2020, 11:12 AM | #4 |
Rep 296
Hey guys -> its these plugs part#: 12122455258. It is no questions if you can run them - I know people can - many do. Question is what went wrong in my case
04-30-2020, 11:56 AM | #5 | |
Rep 467
05-02-2020, 07:59 AM | #7 | |
Cheapskate
4450
Rep 4,993
luke1990132.50 |
05-02-2020, 08:03 AM | #8 | ||
Rep 296
Either way. How would I go about doing that? Can a shop do it? |
07-14-2021, 11:00 PM | #9 |
Rep 9
How did you solve it? i am having the same issue with my 328i xDrive
07-15-2021, 07:55 AM | #10 |
Rep 282
why the change to tu plugs ?? oem's are just fine , like many threads in this section , they change plugs and after a while they ran into codes or other problems
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
04-06-2024, 06:31 PM | #12 |
Rep 3
Hey guys
My 2015 bmw x6 is having exactly the same error codes as some of you here. The screen shows the drivetrain malfunction Note that the spark plugs were replaced 4 months ago. Can anyone explain how it was to fix it? Did you take it to a dealer? And how much it was? Any info will be appreciated 123401 electric wastegate, learning stop: malfunction during catalyc converter heating 123432 electric wastegate, learning stop: stop position (wastegate closed) outside valid range 120408 chargin pressure control, deactivation: pressure build-up blocked Last edited by viktorbaffil; 04-06-2024 at 06:37 PM.. |
04-07-2024, 03:43 PM | #13 | |
Rep 1,456
2022 CT4-V Blackwing 6-speed
