BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Bootmod3 91 ACN on N26
      10-29-2019, 11:35 PM   #1
staticcornflake
Drives: BMW 228i
Hi,
Is anyone successfully running Stage 1 OTS 91 in California (usually Costco 91 for me) without issues? Or should I go right to the 91 ACN map? Wondering if it's worth trying the main map first or if ACN is the way to go (but obviously a bit weaker).
Thanks!
      10-29-2019, 11:37 PM   #2
andino
Drives: F31 328i xdrive
I was running stage 1 on ACN91 and now run stage2. Stage 1 was fine with costco fuel but stage 2 is a bit more picky. I also don't think there's an ACN91 specific tune for n20/26; only for the n5x motors.
2016 328ix F31 - SOLD!
2006 997.1 C4S
      10-30-2019, 12:15 AM   #3
Gen13 F36
Gen13 F36's Avatar
Drives: 428i Gran Coupe
I have F36 with N26, Bm3 stage1 ots 91 map here... been running it for 10 month now. I don't have any problem with it. I live in socal, use any 91 fuel I can get nearby.. arco, Chevron, 76 and shell but I run mostly arco and Costco.
      10-30-2019, 10:47 AM   #4
staticcornflake
Drives: BMW 228i
Awesome - I had been reading bunch of threads where people were having timing pulled/knocks and ultimately went to ACN maps. I'll try the regular first and see how it runs and then downgrade if available/needed. Just waiting for warranty to expire next month before flashing
      10-30-2019, 02:44 PM   #5
Gen13 F36
Gen13 F36's Avatar
Just want to add... during very hot summer days...it did pull timing a little, only because I did to many hard pull back to back to back. Its probably from intake temp. After my warranty is over I'll change my intercooler.
But normal driving around, a hard pull here and there is not a problem.
      12-09-2019, 07:24 PM   #6
staticcornflake
Drives: BMW 228i
Just to close this out, I ran a few tanks of Shell 91 through the car and flashed Stage 1 OTS 91, did a few logs, and it all looks good. So seems Costco gas (at least from Culver City) can't keep up with the OTS maps, but was ok with the ACN map with reduced boost.
      12-09-2019, 08:28 PM   #7
Gen13 F36
Gen13 F36's Avatar
Seriously costco.... I pump that gas once in a while. I have to check my log. Damn costco
