08-15-2018, 02:05 PM | #45 | |
Rep 4,935
Drives: 340i MPPSK
Only time I've ever had anything like was when I ran a 2005 Aldi A3 2.0 TDi with the DSG box - that used to do exactly what you describe, and yes it was bloody dangerous.
Life is a state of mind |
08-15-2018, 02:09 PM | #46 | |
Rep 3,967
It does seem to only be a problem with certain cars and not all, so I wonder what the exact cause is. |
08-15-2018, 02:30 PM | #47 |
Rep 280
If I come to a dead stop it's fine, pulls away almost instantly.
It's when you don't quite come to a stop that it occurs. It's almost like the car is preparing itself to idle, but instead you jump on the throttle and catch it out. My 330d was exactly the same so I assumed it was a "feature". Somebody mentioned about the revs flaring akin to a clutch slipping, but both mine don't do that, I just get a long pause where the car does nothing. I'd estimate it can be over a second at times.
Current thing: Mk7.5 Golf GTI Performance Isaac Blue
Old thing: F31 340i M Sport Silver/Red |
08-15-2018, 02:35 PM | #48 | |
Rep 3,967
08-15-2018, 03:03 PM | #49 |
Rep 280
I must have got two shitters in a row. Lucky me. Actually the M135i was fine so just 2 out of 3
Not too bothered now, it's become second nature to slip into Sport at certain roundabouts/junctions.
08-15-2018, 03:14 PM | #50 |
Rep 280
08-15-2018, 03:27 PM | #51 | |
Rep 15,858
If this is the case, it makes sense to why a throttle reset works in some cases. A default setting may work better than once it adapts. |
08-16-2018, 04:16 AM | #53 | |
Barge driver
8647
Rep 12,421
730d/Z4C
08-16-2018, 06:11 AM | #54 | ||
Rep 15,858
I have always suspected this is a key reason some drivetrains have the issues reported. Whether it is tolerances of components, the combination of the build stack and sensitivities to driving environment and/or driver influences, limitations of software and computing power, is hard to quantify. My 330d with the ZF 6-speed AT had one quirk, which I could repeat every day if I wanted to. Pulling out of my lane on a cold transmission, triggered if I almost needed to stop. Simply how I applied the throttle, either caused a jolt, or was a smooth pull away. As another poster has commented... Quote:
I look at it this way, remember the AT is reactive, needs commands. Some drivers are too erratic, "on-off" drivers, are giving mixed inputs. To get the smoothest drive, give clear and precise instructions. |
08-16-2018, 06:28 AM | #55 | |
Barge driver
8647
Rep 12,421
I've never driven a ZF6/8 or any automatic that didn't have it's own foibles and limitations whereby the gearbox for whatever reason doesn't respond to a command input in a timely manner.
730d/Z4C
08-16-2018, 06:40 AM | #56 | |
Rep 15,858
I agree we will find the foibles and limitations. I'd say for the 8-speed, when driving in hilly terrain it does test the ability to interpret all the inputs. What I do find, drivers can definitely influence how smooth AT works across varied situations. Same applies for DSG. Plus there is big difference with driving a faulty gearbox/software combination, than learning to drive an AT smoothly, to accommodate any limitations we find. |
08-16-2018, 08:33 AM | #57 | |
Barge driver
8647
Rep 12,421
I do find that no matter how many miles I drive (many, too many) no matter what the engine and gearbox combination (DCT or ZF) they will often put in a random occurrence, whether that be a hesitation/latent reaction/harsh shift down/clunk/judder etc.... and that's in addition to driver input induced issues. Ghosts the in the machine.
730d/Z4C
HighlandPete6658.50 hudson012003168.50 |
08-16-2018, 01:03 PM | #58 |
yes....spelt with J's
55
Rep 963
Super responses here guys.....certainly an education. It could very well be me given that I am used to the terrier like reactions of my Clio 172 daily steed.
If, using some of the suggestions, I can work around this with my driving habit then I most certainly will. I do still think I will ask BMW to let me know what they think as the workshop manager is going to be taking the helm of ours for a bit to see what he thinks of the steering and I do trust him Will report back of anything is deemed amiss. Cheers J |
08-16-2018, 02:28 PM | #59 |
Old Fart
361
Rep 693
AFAIK this sounds more like software getting caught out than a mechanical problem.....
If however you get a jump in revs then drive takes up with a thump after a delay then it's most likely a sticking valve in the gearbox, was common on the Volvo's I've just left. FYI, the easiest way to fix or improve that was to do a couple of gearbox oil changes a thousand miles apart.
The doctors said it's OK to listen to the voices..... just don't do what they tell me
08-17-2018, 12:59 PM | #60 |
Rep 1,066
Okay - so everyone who buys an AUC should be made to reset the throttle. Mine reset has absolutely transformed the car - no weird mid bend shifting, no notable travel without response. The lag has gone and I am only annoyed that its taken me 6 months to discover it needed it.
Really pleased, now off to thank those who suggested it! |
08-17-2018, 04:52 PM | #62 | |
Rep 2,376
Current - X3m Comp
Gone but not forgotten - F80 m3 Comp, F30 340i, F30 - 320i |
08-18-2018, 08:00 AM | #63 |
55
Rep 963
That is good news Speed..........so my question is, if i do the pedal reset, am i going to make a shit of my car?
I had always assumed that an AUC BMW would have had everything reset before we got it.......my car was almost like a factory reset had been done to iDrive etc. Perhaps that doesn't go as far as these pedal settings etc Thoughts? J |
08-18-2018, 08:12 AM | #64 | |
Rep 1,066
If you are happy with how it is then leave it be - it seems to learn early and not change (I have done 6k in it and it wasn't any different from the first mile I drove it). Now though, much happier |
