01-23-2022, 06:23 PM | #1 |
Rep 1,148
Alright so the time has come. Oil pan drain striped
So today was great, oil levels sensor has been down for atleast a month, car hasn't moved, did oil change today and as always I inspect everything with cover off and clean everything. Turbo oil drain line is leaking. Cool no worries, appears there's some oil sweating from the oil pan (80500 miles) cool no worries wasn't bad, did a small snug up on all bolts to hold it over.
Oil level sensor had rodent damage, never had a rat around my house so that was odd, missing about 3" of wire. Cut, extended and soldered. Cool that works again. Oil drain plug was leaking, It never felt right threading it in before, so I assumed it was gonna happen. Drain oil, go to tighten plug up, hand tight all good, go to put any pressure on it, pop. That was it, remove plug, threads come with it, blew out the middle section of threads. That being said. Today has sucked but that's life. I can timesert it. They seem to be reliable enough, I want to look into a rivnut as a solution, I feel that can be even stronger, but maybe I'm wrong. I don't want to buy a pan as I know I can repair it, pan is weeping a few drops of oil, it's going to need a gasket within the next oil change. I figure now is the time to drop it all down. Really dreading this job, maybe it won't be so bad once I dig in. The list is mmr baffle, pan gasket obviously, engine mounts (anyone use the vtt plates that can chime in?), and possible rod bearings and arp bolts. I got a minute to think about it. Anyone who has done this job please chime in with your experience lol. Anyone that changed rod bearings I would like to talk. |
01-23-2022, 09:44 PM | #2 |
Rep 10,351
"Drive more, worry less. "
Pussiwillow521.00 |
01-23-2022, 10:40 PM | #3 | |
Rep 1,148
I'm going to remove the pan and do a timesert to oem size I think. Pan is coming off for sure Acl bearings and arp rod bolts are likely going to happen while I'm in there to. Mmr baffle may take too long to get here so I may skip that unfortunately |
F32Fleet3570.00 |
01-23-2022, 11:12 PM | #4 | |
Rep 79
01-23-2022, 11:32 PM | #5 | ||
Rep 1,148
Almost no reason to use oem bolts |
01-24-2022, 12:48 PM | #6 | ||
Rep 1,148
Many people running arp no issues when done correctly. Hmmm I believe the s65 guys required 50# I'm wondering I'm going to get in touch with some n54/s55 engine builders soon and see if anyone is willing to talk I have no reason to believe the bearings are going to be an issue in this car, but I would like the piece of mind if I'm going through all this trouble I'll see what I can gather before making a positive commitment to messing with the bearings I used arp on my old m52 engine builds and always went well. One ran for 5 years trouble free before selling the car |
02-07-2022, 05:01 PM | #7 |
Rep 1,148
Baffle ordered
M3 comp engine mounts delivered, oil lines for turbo, oil pan gasket, pickup and o rings, oil pump bolt kit, bearings and rod bolts ordered |
02-08-2022, 04:53 AM | #8 |
Rep 220
Subbed
Pussiwillow521.00 |
02-08-2022, 01:34 PM | #9 |
Rep 1,148
02-08-2022, 08:51 PM | #10 |
Rep 183
whoismorggan553.00 |
02-09-2022, 03:08 AM | #11 |
Rep 220
Yeah my plan is to pull the subframe, replace the gasket, I think I may have a slight leak from the dump bolt and then while at it redo the bearings, mmr baffle and a front sway bar. So very interested in this
Pussiwillow521.00 |
02-09-2022, 08:16 AM | #12 | |
Rep 1,148
So I went with an m motor mount, I know they fit, anyone who makes after market mounts fits all n55/s55 f chassis |
el_couzin39.00 |
02-10-2022, 11:38 AM | #13 |
Rep 1,148
Hopefully they actually ship
Some vendors are out awhile but Turner said they reached out to h&r and confirmed they're available ready to go List keeps going! Haha 😂 wife will kill me but new car who dis Baffle shipped and has a delivery date of February 17 I'll update for those who end up wanting one so they can gauge how fast it comes |
Polo088161610.00 |
02-10-2022, 07:46 PM | #15 |
Rep 220
My wife has been working from home this week. And unfortunately my oil cooler, intake, downpipe, race intercooler and some other bits and bobs all arrived in one day..... She was very suspicious of all the parcels and wondering how regular the deliveries are!!!
Pussiwillow521.00 F32Fleet3570.00 |
02-10-2022, 08:02 PM | #16 | |
Rep 1,148
Lol 😂 |
terryd5150507.00 |
02-10-2022, 08:17 PM | #17 |
Rep 1,148
So my tow hook doesn't thread into the block. Someone said an e90 one does.
I don't really know, looks nicely threaded, sort of want a nice bolt instead and hook a chain to it, dunno, anyone confirm?? Either way good ole harbor freight got an engine brace, looks solid enough. I'm not too scared |
02-10-2022, 08:20 PM | #18 |
Rep 220
Yep have to get an E series tow hook, FCP sell it for $30 bucks i think. Dont go after market as SOME dont clear on parts of the engine.
Pussiwillow521.00 |
02-10-2022, 08:26 PM | #19 |
Rep 1,148
02-10-2022, 10:25 PM | #21 |
Rep 1,148
02-11-2022, 12:09 AM | #22 |
Rep 220
Did you end up picking new rod bearings?
I’m ordering my parts now (mmr baffle, genuine Rod bolts, oil pan gasket and bolts and hard race sway bar) I’m thinking of getting the king rod bearings in std size Also interested to know if you are going to completely remove the subframe or just drop it slightly? Last edited by Tobz_au; 02-11-2022 at 05:26 AM.. |
