06-23-2021, 06:39 PM | #1 |
Rep 19
Searching for new Exhaust
Hello everyone hope you're doing well,
I currently have a Borla ATAK catback exhaust on my car "I bought it that way" but my problem is that it's too loud all the time and it drones sometimes, so I am looking for a replacement and I really don't have much of a clue about which Exhausts won't affect my tune in a negative way and still aren't as loud and I'm a bit limited at the moment to the reselling value of my current Exhaust , I heard about valved exhausts but idk if they would stay around my price range. what I need in short: -neither too loud nor too quiet sounding Exhaust. -and no drone. The car currently has a catless Downpipe, a charge pipe and a stage 2 tune p.s. Any additional info that could help me in my search would be appreciated Last edited by carsforlife; 06-24-2021 at 01:07 PM.. |
06-23-2021, 07:25 PM | #2 | |
Rep 7,606
My recommendation and the cheapest option is to go into the classifieds or another used part marketplace and find a stock exhaust for sale, ideally locally due to size. They are extremely cheap, especially if you are talking about only the axleback (you didnt specify if you have catback or axleback). Install the stock exhaust with catless DP (a common setup and good sound, subjectively). Then if you want a little more from there, delete the resonator from the OEM midpipe for <100$. If you go the new option, you are likely going to spend >$1,000 EDIT: You could also consider having a shop add an additional resonator to your midpipe. |
carsforlife4.00 |
06-24-2021, 01:57 PM | #3 | |
Rep 19
06-25-2021, 09:16 AM | #4 |
Rep 166
I have the borla atak with a Catted downpipe and there is like zero drone. A high flow downpipe shouldn't affect the tune that much if you want to go with a new downpipe instead of buy a whole new exhaust
06-25-2021, 09:32 AM | #5 | |
Rep 7,606
Getting a catted DP as mentioned above is another option. The amount that it will change the exhaust sounds/volume/drone depends on the DP really. The thing is most aftermarket exhausts are made to pair with OEM DP which significantly mutes the exhaust, and any aftermarket can make them "too loud" |
SC435i9.00 |
06-26-2021, 06:20 PM | #6 |
Rep 4,921
Adding a quality resonator to your mid pipe sounds like your cheapest and best option if your happy with the looks of your exhaust.
06-26-2021, 10:31 PM | #7 |
Rep 1,934
Go catted. Any of the non cel guaranteed will work. You already have it tuned so the cel will be suppressed.
06-28-2021, 09:22 AM | #8 |
Rep 190,805
+1 on replacing the downpipe for a catted one. I recommend the Active Autowerke since it does not throw a check engine light
435GranC13.50 |
