02-11-2020, 05:21 PM | #23 |
Rep 1,105
02-11-2020, 05:51 PM | #24 |
Rep 7,591
02-11-2020, 06:21 PM | #25 | |
Gettin It Figured Out
1820
Rep 2,669
As of Jan 1st. However, 2nd MAP is $299 .
02-14-2020, 09:17 AM | #27 |
Rep 1,105
More boost but timing still needs some work.
I might add 1 gallon of E85 this weekend to see if logs improve but overall power is crazy and my butt dyno is very happy! https://datazap.me/u/munchi/pureboost-v4a https://datazap.me/u/munchi/pureboost-v4b https://datazap.me/u/munchi/pureboost-v4c https://datazap.me/u/munchi/pureboost-v4d https://datazap.me/u/munchi/pureboost-v4e |
02-15-2020, 01:49 AM | #28 |
Rep 1,105
So I was a bit bored and didn't want to wait for another map revision so I added 2 gallons of E85 and topped off with 93 octane.
Its amazing how much my timing was cleaned up and felt so much more power mid to high rpms. Also, IAT were consistently low, although it was a cool night here in Florida. Mind you I've requested solely a pump 93 octane custom tune but DAMN its amazing what a couple of gallons of E85 will do! Now I'm considering just tuning for a higher E-mix!!!!! https://datazap.me/u/munchi/pureboost-v4e85a https://datazap.me/u/munchi/pureboost-v4e85b https://datazap.me/u/munchi/pureboost-v4e85c |
02-16-2020, 07:03 AM | #29 | |
1820
Rep 2,669
Think you found your sweet spot on your octane! GREAT looking log .
02-17-2020, 01:13 PM | #30 | |
Rep 1,105
In reference to my 93 octane revisions I was advised by PUREBOOST to check my spark plug gaps and that they should be set to .018 instead of the .022 that I currently have them set to. My question to that is if I'm running an E-mix, should I still regap to .018? |
02-17-2020, 01:32 PM | #31 | |
1820
Rep 2,669
I’ve been running e30 Map gapped @ .22 since 2015 with zero issues. I’ll be re-tuning for e50 by April, if I need to gap down to .18 or maybe split the difference at .20 I’ll do it then. Just need to watch timing/misfires and adjust accordingly .
02-18-2020, 05:03 PM | #32 | |
Rep 7,591
n55david1295.50 |
02-18-2020, 06:30 PM | #33 | |
Rep 1,105
02-18-2020, 07:48 PM | #34 | |
Rep 7,591
What i have found running MHD 2+ with CA 91 octane (no added ethanol) is that power can be inconsistent due to timing being pulled in some situations but not others. I have some 4th gear logs with perfect timing (zero corrections), but others with up to -6 on one or more cylinders. That results in a very noticeable difference in power. I guess what i am saying is you dont necessarily want to be tuned to the limit of your octane. Not quite sure what the LPFP limit is, but some say its not needed unless you are running port injection. With the XDI 35 being +35% increase in capacity and E85 (assuming its actually 85% ethanol) being about 30% lower energy density than pump gas, you would basically be cancelling out the benefit in terms of pushing beyond the limits of the stock HP capability of the stock HPFP with full E85. With a PS2 and custom tune, you probably wouldnt want that as you would be leaving power on the table compared to a mix. The mixing can be a little annoying if you drive the car long distances frequently, especially if access to E85 is limited. In my 3000gt, which is no longer my daily, i just add equal amounts of pump 91 and E85 at every fillup. Of course this means i never go to a completely full tank - usually just 5 gallons of each so i know i am keeping 50/50 ratio. Adding _X_ gallons of each is usually easier than trying to guess how much total fuel you need to reach a full tank and allows you to keep the ratio consistent. For a F30 this would probably mean going down to maybe 1/8 tank and then adding 6 gallons of each at the next fillup. Finally, not sure where you are located, put check out the pearson fuels app for E85 station locations. They claim to be 83.3% E85 consistently. |
ronanz1819.50 |
02-18-2020, 08:19 PM | #35 | |
Rep 1,105
Always appreciate your in depth advice and process thinking. I'll be regapping my plugs to see if that helps clear up my timing as well. From what I've read and researched about the stock LPFP, it's only necessary when using port injection. Also, I figured running full E85 might not render much gain compared to e40-e50, so if i go further down the rabbit hole of higher emix, then e50 might be my max! |
ronanz1819.50 |
02-19-2020, 10:44 PM | #36 |
Rep 1,105
02-20-2020, 11:23 AM | #37 | |
Rep 7,591
02-20-2020, 11:43 AM | #38 | |
Rep 1,105
So I was looking at my OTS logs for PS2 and my STFT have always gone negative and that was with no timing corrections https://datazap.me/u/munchi/1112020-...-octane-part-2 https://datazap.me/u/munchi/1112020-...-octane-part-1 Last edited by Munchi435i; 02-22-2020 at 06:23 AM.. |
02-22-2020, 06:19 AM | #39 |
Rep 1,105
UPDATE: changes to timing and fueling
https://datazap.me/u/munchi/pureboost-v6ae85 https://datazap.me/u/munchi/pureboost-v6be85 https://datazap.me/u/munchi/pureboost-v6ce85 Still haven't had a chance to regap plugs and using the remaining tank of 2 gallons E85+pump 93. Logs are showing that more timing was added and very slight timing corrections in 2nd log only! The car just runs like a beast in the mid to high rpm. So I'm at a crossroad with my tuner asking if going to keep tuning for pump 93 or E85 blends. I was very adamant about just going with pump 93 but seeing the results just 2 gallons of E85 has me tempted! It's been a great experience working with PureBoost for this custom map and feel there methods of tuning come from many years of tuning experience. I'd highly advise anyone looking for a custom tune to seek them out! |
02-22-2020, 11:29 AM | #40 | |
1820
Rep 2,669
Have you considered scaling back to JUST a refined "daily" 93oct map, no ethanol....then have a e20-e30 map done? No reason why you couldn't have a "daily driver" map AND performance map .
02-22-2020, 01:07 PM | #41 | |
Rep 7,591
I suspect you will probably end up running the Exx map 90% of the time, but if you find yourself in a situation where you only have pump 93 you can flash to that. The alternative is to make your custom map the Exx map, and then just flash a OTS 93 map if you are in that situation. |
ZM22810.50 |
02-22-2020, 04:03 PM | #42 |
Rep 164
This was the route I took. When I want to drive "easy", I just use the 2H 93 map or a different less aggressive map I have. When I know I want to drive spiritedly, I have my custom E85 map and know I am getting max power for my car.
2014 F30 335i xDrive 6MT - Pure Stage 2 GFB DV / Inlet | XDI-35 HPFP | Fuel-It PI w/ AIC and LPFP Upgrade | BM3 | Fabspeed Catted DP | Dinan axle back | VRSF Race FMIC/CP | Dinan CAI | KW V3 | Wiechers CF strut bar | Dinan ARB | Spec stage 2+ clutch SMFW | Full M Performance Interior | M Performance BBK | Vorsteiner VFF107 MPS4S | Jordan Tuned Full E85 - 558WHP/520TQ on Mustang Dyno
ZM22810.50 |
02-22-2020, 08:28 PM | #43 | ||
Rep 1,105
I've had enough revisions to have a custom pump 93 tune that goes beyond OTS. I'll just start moving towards the E85 mixes. From my research I believe E50 might be the max ratio for maximum power with PS2 and upgraded HPFP.
ZM22810.50 |
02-22-2020, 10:10 PM | #44 |
Rep 77
e85
Just worth noting
Once you get used to an E85 mix it is easy I don't think twice nice now about going to the petrol station and doing the mix I know exactly how much of each fuel to put in even with partial filling It really doesn't feel like any extra effort |
