03-14-2019, 04:05 PM | #1 |
Rep 188
Precision Raceworks Ignition Kit - DIY
I recently purchased the igniton kit from Precision Raceworks and installed them on my car. When i was searching the web, I found a lot of DIY's for the N54 platform but none for the F series N55 platform, so i figured why not make my own and share it on this forum. This is my first time making a DIY on a forum so i apologize if i miss some things during the install. This took me about an hour to install.
Tools needed: - 11mm Socket - T25 Torx or 4mm allen (I think) - Sawzall (or heavy duty knife to cut through thick plastic) 1. Start by removing your engine cover if you have it installed. Unbox the kit and lay everything out. You should have: - 6 PR blocks - 6 Coils - 6 Wire Adapters - 10 Allen Screws - 5 brackets total, 2 of them will be used to mount the blocks on the fuel rail. View post on imgur.com 2. Locate the screws that hold the fuel rail in place. There are (4) 11mm bolts and they sit right above the intake manifold studs. You will only be using the 2 outer bolts to mount the brackets. 3. Loosen the first fuel rail bolt closest to the front of the car. Next, take 2 of the blue blocks, 2 of the allen head screws, and one of the mounting brackets supplied in the kit and connect them together (I did not have this allen head size so I used a T25 Torx bit). It should look like this when you're done: View post on imgur.com **NOTE: I had the bracket flipped the wrong way when i took this picture, the tab should be facing downwards** After those two are connected, insert the bracket behind the fuel rail bolt and re-tighten it. If you have trouble, loosen the bolt some more or take it completely out and align the bracket that way, just be careful and don't drop the bolt. 4. Next, you're going to need to remove this piece that sits on the manifold. I used a sawzall with a metal blade to cut mine. https://imgur.com/a/ic7VgSp Be careful not to cut too deep or damage anything while doing this!! The result should look similar to thi">https://imgur.com/a/ic7VgSp Be careful not to cut too deep or damage anything while doing this!! The result should look similar to thi">View post on imgur.com 5. Use the other (3) flat brackets supplied in the kit to connect the rest of the blue blocks until you get to block #5. Once you reach the 5th block, you will repeat the same process you did for the 1st and 2nd blocks. After they are all connected and mounted, they should sit like this: View post on imgur.com 6. Remove your old coil packs from the engine and grab the harness supplied in the kit. View post on imgur.com Take the blue end of the harness and connect it to the 1st coil pack connector, then connect the green end to the 1st PR block you just installed. Repeat this until you have all 6 installed and it will look like this: View post on imgur.com 7. Next, install the coil into the 1st cylinder and push down until you feel it click in place. Take the coil connector and install it in the 1st block. Repeat this for all 6 cylinders. View post on imgur.com After you finish this install, you can go into MHD and check off "Precision Raceworks ignition kit", and re-flash your map. |
03-23-2019, 07:38 AM | #3 |
Rep 188
03-23-2019, 08:08 AM | #4 |
Rep 340
http://www.precisionraceworks.com/in...&product_id=89
Is this the one you got.. It look different from the pic so I'm just making sure |
03-23-2019, 09:27 AM | #5 | |
Rep 188
03-25-2019, 12:26 PM | #7 | |
Rep 503
06-18-2019, 07:07 PM | #8 |
Rep 53
Drives: 2012 335i
After you install I am guessing you are unable to use engine cover anymore correct?
06-25-2019, 06:29 PM | #9 |
Rep 188
06-27-2019, 09:37 AM | #10 |
Rep 106
Drives: 2014 428i F32
07-11-2019, 05:27 PM | #11 | |
Rep 279
i hack the engine cover to fit it https://ibb.co/N7jC623 |
09-03-2019, 06:42 PM | #12 |
BMW Fanatic
331
Rep 1,076
Can this not be installed without trimming that engine cover piece?
18 BMW M2 | ER DP | ER CP | Wagner Evo 2 Comp Intercooler | Aquamist HFS4 | BM3 | CSF Oil Cooler | AFE Drop-in Filter | Bilstein B16 PSS10 |
09-15-2019, 10:37 PM | #14 |
Great Teacher
1076
Rep 1,303
Drives: 06 e91 325ix
why not just mount your gm coils on the fender instead of having to lose the engine covers?
09-17-2019, 01:02 PM | #15 |
Rep 2
10-16-2019, 03:21 PM | #17 | |
Rep 188
If a coil does break though I think you just email the company and they'll send you a new one. |
10-17-2019, 10:00 AM | #18 | |
No 55mph
1619
Rep 8,476
10-17-2019, 10:03 AM | #19 | ||
Rep 188
04-06-2021, 11:11 PM | #20 |
Rep 41
kewl,,,finally a PR coil install on an F chassis...
335i F30 PWG, PS2, XDI-35, ER DP, CSF FMIC, MST AI, BM3, Snow Perf WMI
