06-06-2019, 12:09 AM | #794 | |
Rep 345
06-06-2019, 06:19 AM | #795 |
Cheapskate
4447
Rep 4,993
There are no hardware differences with MPPSK that would allow the car to make more power. So no.
06-08-2019, 08:03 AM | #796 |
Rep 9,709
BM3 stage 1 93 vs JB+ (on M240i base map)
Had my 240i on the dyno today. Plot 1 (blue) is JB+ with settings at 3 o clock (not maxed). Plot 2 (green) is BM3 93 Stage 1. This is the same car, I previously had JB+ on it and now have BM3 flash. Conclusion: JB+ has significantly stronger mid range. BM3 needs to be above 5500rpm where it definitely takes the upper hand. Car is stock otherwise, stock DP. Just a point to note, JB+ on max settings records between 405-410hp on this dyno. As it happens, last weekend I ran the 1/4 mile against a JB+ (max setting, 407hp dyno) M140i. My car was 2/10ths faster with a 12.2. @ 114. One run we both did a (less than ideal launch on my part) 12.5 , and our cars were almost identical the whole way down the strip. Very close. I feel this verifies what I'm seeing on the dyno plot. Which do I prefer? On balance I have to say the BM3 is the better solution. The softer / more progressive mid range makes it easier to drive drive, I guess. Although not really a good point, less power is never more Throttle progression is smoother on BM3, and this must not be underestimated. Thirdly, BM3 seems to pull cleanly all the time, every gear. JB+ can have the occasional hiccup. Oh and AFR is richer on BM3. Some people will be pleased with that. |
06-08-2019, 04:08 PM | #797 | |
Rep 285
NISFAN3487.00 |
06-08-2019, 05:57 PM | #798 | |
Rep 1,334
But I digress...I suppose if you're happy with it then that's all that matters in the end.
X3 M40i G01, M235i F22, 335 F30 MSport, 135 DCT, 335 E92, Audi A3
340ix1743.00 |
06-08-2019, 07:42 PM | #799 | ||
Rep 216
06-08-2019, 08:16 PM | #800 |
Rep 63
These are pretty good numbers for a stock stage1. Does that dyno run a little high?
2018 440i GC xDrive | M Sport | AA Catted DP | AP Intake | B58TU HPFP | Pure800 Turbo | BM3 Flex Fuel Kit | E50 Tune by Performance Eurowerks
06-10-2019, 01:55 AM | #802 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
06-10-2019, 09:40 AM | #803 |
Rep 36
Is BM3 limiting midrange torque due to 8AT limits
Since BM3 does not offer a transmission reprogramming option I am wondering if they are limiting the midrange torque of their tunes due to the torque limits of the 8AT.
if that is the case I wonder if they would create an OTS specifically for the 6MT without the torque limits |
06-10-2019, 05:08 PM | #805 | |
Rep 1,219
What's the curb weight?
X3M Alpine White - SOLD
Fastest Tune Only Record - Mission Performance 10.84@127.43 / +1912 DA NH Dragway | 10.6@130 Dragy / +820 DA The Streets | NOW: Tesla Model Y Performance |
06-10-2019, 06:50 PM | #806 |
Rep 385
Persuade me to downpipe and stage 2 map for the 340i. I'm simply happy where my car is at. But then again no body has tested me (on a safe enclosed cicuit) of course
06-11-2019, 01:59 AM | #808 | ||
Rep 9,709
06-11-2019, 09:47 AM | #809 |
Rep 458
06-11-2019, 12:39 PM | #810 | |
Rep 1,457
Who knows, but probably not that consistent. That Dragy user has very fast times if you go and look at his profile page and not just with this car, but every BMW he drives and does a Dragy run with including bone stock BMW's
2024 X3 M40i
2014 BMW M5 |
06-11-2019, 03:35 PM | #811 |
Rep 1,369
Yeah, that 124 mph trap is nuts. I've gotten a couple 118 mph runs on the Dragy, so it's tough to see how E30 could add 6 mph to that. What would E30 be good for over straight 93, maybe 20-25 whp?
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
06-11-2019, 06:01 PM | #812 | |||
IG @bmwF9xG80
3813
Rep 7,593
Dragy is the way to shut up all you downhill racers since there's no 1/4 mile track overseas. Quote:
I did 0-60 in 4.19s and 1/4 mile in 12.4@110 in my X4 M40i (N55) and with E30 it did 0-60 3.88 and 1/4 mile in 12.1@114 (mind you this is a 4495lbs beast I had previously) Anyways the B58 is a monster and it shows what a good solid OTS especially my favorite 'E30' will crush hearts! Great job on the hard work, time, sweat, dedication proTUNING Freaks and Halim@HCP are always putting out for every engine under BM3 support !
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 Last edited by FSociety; 06-11-2019 at 09:22 PM.. |
06-12-2019, 06:13 AM | #813 | ||
Cheapskate
4447
Rep 4,993
- A lot of us enjoy the ability to log, switch maps, get tune updates, etc. - Pretty much everyone sells their license/buys used so really it's $300 - A flash tune will always be safer than a boost controller, especially when it's spiking boost in the midrange vs. smooth boost onset with a flash tune. That's how you burn clutches and blow drivetrains (not that there's a huge risk with JB+, but still) Quote:
Same. I'm actually more interested in a Stage 1 E85 tune than a Stage 2 93 tune. I don't feel like spending another $500 to go from stage 1 to stage 2 will be as impressive as the $550 I spent to get to stage 1 with no other mods. |
FSociety3812.50 |
bm3, bootmod3 |
