06-24-2019, 11:30 AM | #1 |
Rep 458
Custom Tune - Stock Turbo
Would a custom BM3 tune be worth it for the stock turbo with FBO. It would be a 93 and E30 tune or should I just stick with the OTS versions?
06-24-2019, 02:58 PM | #3 |
Rep 458
Yes! BM3 is really just a flash tool, so when you go to purchase it you get one free map with it. If you spend another $50, you get access to all the OTS maps. However, you could skip paying the $50 and get a custom tune done from a BM3 tuner either at their facility or remotely.
06-28-2019, 12:55 AM | #5 |
Rep 190,633
You will see noticeable gains with a custom tune, that being said i only recommend it once you are FBO or have upgraded turbo
06-28-2019, 02:08 PM | #6 |
Rep 126
06-28-2019, 06:40 PM | #7 |
Cheapskate
4445
Rep 4,993
The two top tuners I see are cary jordan and f80paul. They both offer tunes for E85, meth, and bigger turbos. If you're on stock turbos and pump gas then I don't see you getting a huge improvement with a custom file. It's only worth it if you have additional hardware that the OTS maps can't take advantage of.
j1980mac262.50 |
06-28-2019, 11:46 PM | #9 |
Cheapskate
4445
Rep 4,993
pretty much all we need is a downpipe. intake has little to no gains and no real intercooler upgrades outside of the upgraded heat exchangers, but those aren't needed.
06-29-2019, 12:47 AM | #10 |
Rep 154
that's what I thought too, so unlike our N55 days, with the B58 there really isn't any FBO so to speak...other than a DP. Not like we are blowing out intake pipes or anything HA.
06-29-2019, 07:18 AM | #11 | |
Cheapskate
4445
Rep 4,993
Personally, I'm pretty satisfied with my stage 1 93oct tune. I'm more interested in switching to stage 1 E85 and running that with everything else stock. |
06-29-2019, 08:16 AM | #12 | |
Rep 458
06-29-2019, 03:37 PM | #13 | |
Rep 1,452
Personally, the math on the BMS intake means that although it might be an initial higher IAT, it's flowing way more air and the air-to-water intercooler takes care of those few degrees higher difference. Plus the sound. |
06-29-2019, 03:47 PM | #14 | |
Rep 458
https://f30.bimmerpost.com/forums/sh...6&postcount=35 So the BMS will flow more air than the stock airbox with a drop in performance filter? |
06-29-2019, 04:01 PM | #15 |
Rep 458
Okay so I remember capturing an IG story from F80Paul the other day and it is a dragy slip for an m240i 93 + meth custom tune. The 100-200kmh time is 7.10 seconds. Halim's 100-200kmh in his m140i running the Stage 2 E30 OTS - Version 2.0 was 7.85 seconds. Seems like there is definitely some power left in the car.
06-29-2019, 06:34 PM | #16 | |
Rep 1,368
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ Pure 800 cast/ DS2/ E40 Doug Newton tuned/ ER catless DP/ Remus axle back/ BMS intake/ FTP CP/ M Performance LSD
06-29-2019, 10:41 PM | #18 |
Rep 1,368
.68 degrees is not significant at all. That's why the Dragy reads anything under 1.00 degree as "Valid".
06-29-2019, 11:50 PM | #19 | |
Rep 1
Hi Sorry but Halim's 100-200 time are in 6.xx seconds On E30 + WMI |
06-29-2019, 11:54 PM | #20 |
Rep 458
That's on a custom E30 tune using E30 and WMI. The numbers I was referencing were on Stage 2 E30 OTS Version 2.0 (the video is on facebook in the Bootmod3 Enthusiast page). Also, the guy who got tuned by F80Paul is on 93 + meth.
06-30-2019, 04:26 AM | #21 | |
Cheapskate
4445
Rep 4,993
Also, Halim's car has a drop-in filter If you're running WMI then yes a custom tune would help. But if you're just stage 2 93 oct wondering if another tuner will take tenths off of your times, it won't happen. Maybe worth it if you're trying to set stock turbo records but won't be a noticeable difference for regular users. |
06-30-2019, 10:50 AM | #22 | |
Rep 458
