BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Possible to have cold starts with closed wastegate instead of open?
      11-16-2019, 05:39 PM   #1
Zabiz
Zabiz's Avatar
Drives: 2014 BMW 328i
My mom has a 2014 gl550 with the 4.7 L twin turbo v-8 and when it goes through its cold start you can hear the turbos spool which I am assuming means that the wastegates are closed (pneumatic)
now is that possible to get a turbo spool when we start up our cars (close EWG)
I have catless downpipes and a custom axleback so I can hear it when in sport + but cold start turbo spool would be nice
(if you listen closely you can hear the distinct turbo spool)
      11-19-2019, 02:12 PM   #2
CandyRedRC46
CandyRedRC46's Avatar
201
Drives: 2013 328i
I dont think that has anything to do with the wastegate. I don't see why the waste gate would open before reaching target boost.
      11-19-2019, 09:23 PM   #3
paimon.soror
paimon.soror's Avatar
Drives: 2016 F36 435x MSport
To heat up the cats. Stock tune opens the WG on cold start for emissions compliance
      11-20-2019, 08:30 AM   #4
CandyRedRC46
201
Drives: 2013 328i
interesting. well that would be a cool feature to have.
      11-20-2019, 12:35 PM   #5
Zabiz
Zabiz's Avatar
right!! Hear that turbo spool on cold start, I have bootmod3 so I might ask them if they have any plans on doing something like that
      11-21-2019, 02:56 AM   #6
ProjektAutoScott
ProjektAutoScott's Avatar
Drives: ‘16 340ix |‘11 X5M
BM3 should have a provision for a “cold start delete” if I recall. That may keep the waste gate shut, or it may not. Worth a shot if you are catless. Otherwise there may be slight risk of damage to your cat. Not sure how much open WG matters, but it definitely has a purpose.
      11-23-2019, 11:28 AM   #7
rjdnyy224
rjdnyy224's Avatar
Drives: 2013 328i xDrive
The cold start delete only lowers the rpm on startup so the car just starts right to idle speed. Doesn't do anything with the waste gates.
2013 328i xDrive N20 8AT | Bootmod3 Stage 2 OTS 93oct | Bootmod3 8AT TCU flash | VRSF Street 5" HD Front-Mount Intercooler | VRSF Catless Downpipe | 2.5" custom exhaust cutout | M Performance Exhaust | NGK L/I Spark Plugs | Dinan 20" Wheels Wearing Michelin PS4S's | Dinan Springs and Bumpstops | F80 Style Decklid Spoiler | Debadged | F80 Style Grille | Various Interior Bits |
      11-25-2019, 09:53 AM   #8
CandyRedRC46
201
Drives: 2013 328i
It does a little more than just idle RPM. The factory cold start setting actually retards the ignition timing a lot, to put an artificial load on the engine to raise EGTs enough to heat the cat up quickly. The timing is pulled so far back that a lot of combustion is occurring outside of the engine (to heat the cat up), hence why cold start is so obnoxiously loud. It is probably doing some adjusting to the vanos and valvetronic as well.
rjdnyy2241539.50
Zabiz5.50
      11-26-2019, 02:36 AM   #9
rjdnyy224
rjdnyy224's Avatar
Did not know that. Thanks for making me a bit smarter
However, in the context of the waste gates opening or closing, the BM3 cold start delete is still irrelevant.
      Today, 09:56 AM   #10
Zabiz
Zabiz's Avatar
That is so cool hahaah, thank you for that info! I'm just guessing that bmw uses a different cold start route compared to the Mercedes to heat up the cats, also the benz is twin turbo so I'm not sure, also could be that the injectors are too loud to hear any spool
