04-08-2019, 07:26 AM | #23 |
Rep 4
Can't turn off climate control after coding bimmer code
Hi all, need some help, i have a bmw f30 2014 i coded the Air conditioning but now cannot turn off the climate control all together, AC and everything else work fine just cannot turn it off,i have loaded the backups that i had on the app but still with not joy, i also left the engine running for 10-15mins but no lights flashed or anything
can someone please HELP PLEASE!!! |
04-08-2019, 09:26 AM | #24 | |
Rep 31
04-08-2019, 11:05 AM | #25 | ||
Rep 4
04-09-2019, 01:35 AM | #27 | |
Rep 4
Do i need to drive the car with the max AC on or just the AC on normal mode?? |
04-09-2019, 02:29 AM | #28 |
Rep 153
Have you tried to drive like 10-15 min ?
I had this problem after coding my A/C, can't turn it off. I think it's an auto calibration that need to be done, I was able to disable it after driving. |
04-11-2019, 03:51 AM | #29 |
Rep 4
I will try another codi g session today n then drive around hopefully it works
07-29-2019, 11:33 PM | #30 |
Rep 18
hey not sure if you guys figured it out but i followed the steps to code memory_off to aktiv, and let the car run for about 5 minutes and the A/C button stopped flashing and became solid on. Then i was able to turn off the ac and it worked and remembered it was off when i restarted the car. So there is definately a cycle that must be completed after coding.
11-25-2019, 05:04 PM | #31 | ||
Rep 27
This worked perfect for me. Thanks! |
11-29-2019, 04:17 PM | #34 | |
Rep 1
12-01-2019, 10:29 PM | #35 | ||||
Rep 27
