BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Bm3 for B48 F30 Datalogs
Studio RSR
      09-29-2019, 08:34 AM   #1
chenzhuops2
China
Drives: F30
Is it stable?
The 98 gasoline I come from to china
http://www.bootmod3.net/log?id=5d8889c3ae729b67235ff4ca
http://www.bootmod3.net/log?id=5d8889c6ae729b67235ff4cb
      09-29-2019, 09:14 AM   #2
chenzhuops2
China
Drives: F30
lgnl too low?
      09-29-2019, 09:16 AM   #3
chenzhuops2
China
Drives: F30
It's just an OCT program. I bought the acn91 program, datalogs has test not yet.
      09-30-2019, 07:59 AM   #4
Works
Works's Avatar
30
Drives: G30 530e B48 + E82 135i N54
Next time, do a full throttle run on a single gear from 2500rpm until redline. And several of them using the same part of the road. Partial throttle logs don't tell much as the only diagnostic device.
E82 N54 hobby project - FlexFuel by Motiv/MHD - Stage1 turbos + FBO - ST XTA w/ AD08R
      09-30-2019, 09:44 AM   #5
chenzhuops2
China
Drives: F30
Ok, I will run again logs tomorrow. I hope it can help me check it thx bro
      10-01-2019, 11:05 AM   #6
chenzhuops2
China
Drives: F30
stock log 98 gasoil
http://www.bootmod3.net/log?id=5d92b356ae729b2cae3138bf
bm3 stage1 98 gasoil
http://www.bootmod3.net/log?id=5d92b051ae729b2cae3138a5
low rpm knock again?
whats happen?
      10-02-2019, 03:44 AM   #7
Works
Works's Avatar
30
I might have been unclear. In order for any of us to give you proper tips we need a rather specific log:
Car already moving, on 3rd gear, rpms 2000-2500 -> open throttle fully (pedal all the way down, if you have AT, don't activate kickdown) and go from ~2000rpm on 3rd until you need to change to 4th at full throttle and give it few more seconds of full throttle on 4th gear.
Be sure that you have safe surroundings, level and dry road with no traffic. For comparable data, use the same stretch of road for all of your logs if at all possible.
Remember to fully deactivate ESP by holding down the DTC button for 5+ seconds so that it will not interfere and skew the log.
Check one of my logs as a reference: Datazap
      10-02-2019, 08:16 AM   #8
chenzhuops2
China
Drives: F30
ok datalogs again tomorrow
      10-22-2019, 11:35 AM   #9
chenzhuops2
China
Drives: F30
http://www.bootmod3.net/log?id=5da6d01cc090c64ea9e1603e
low rpm knock?again again
      10-22-2019, 12:25 PM   #10
hybris
hybris's Avatar
Norway
205
Drives: BMW 330e F30 M-sport
Still not a perfect run. As the previous poster stated: Go to around 2500rpm in 3rd gear and keep the throttle steady, then smoothly increase throttle (1-2 seconds from 2500rpm to your pedal is all the way down) to full throttle without triggering kickdown, then if you have space, shift to 4th and go as far as you can there as well.
Timing seems low, but perhaps that's how it intentionally is on the ACN map? I can't see any knock.
Why are you running 91 ACN if you have 98 octane fuel? I assume this is a 320i?
Thorbjorn
16 BMW F30 330e M-sport
Bootmod3 Stage2 / BMS Intake / RM Motors high flow catted downpipe & custom exhaust / BBS CH 19" / H&R Sport springs
      10-22-2019, 12:35 PM   #11
chenzhuops2
China
Drives: F30
Poor fuel quality to china so get acn91
      10-22-2019, 12:39 PM   #12
chenzhuops2
China
Drives: F30
do you saw the pic?
      10-22-2019, 12:45 PM   #13
chenzhuops2
China
Drives: F30
yep bmw 320Li model F35 B48 184p 320nm
      10-22-2019, 01:03 PM   #14
hybris
hybris's Avatar
Norway
205
do you saw the pic?
I don't think you need to worry about knock events at low rpm and with low throttle. What you want to avoid is knock events during acceleration.
Thorbjorn
      10-22-2019, 01:26 PM   #15
chenzhuops2
China
Drives: F30
do you saw the pic?
ok isee
my log look at the health?
      10-22-2019, 01:27 PM   #16
chenzhuops2
China
Drives: F30
do you saw the pic?
ok isee
lgn1 timing too low?
      10-24-2019, 02:02 AM   #17
hybris
hybris's Avatar
Norway
205
Timing is a bit low but seems reasonably stable during WOT. Again I'm no expert. You should submit your log to PTF.
Thorbjorn
      10-24-2019, 02:20 AM   #18
chenzhuops2
China
Drives: F30
It's been sent but they say it's safe and healthy but I think the ignition is low and the PTF tells me that the oil here is of poor quality
      10-24-2019, 10:24 AM   #19
hybris
hybris's Avatar
Norway
205
Then they're probably right. That the ignition is low isn't a problem in itself as long as it's stable, it's just your car correcting for the fuel quality. Have you tried logging stock to compare?
Thorbjorn
      10-24-2019, 12:59 PM   #20
chenzhuops2
China
Drives: F30
the stock 98gasoil
The ignition has improved a lot?
      10-25-2019, 05:05 AM   #21
hybris
hybris's Avatar
Norway
205
the stock 98gasoil
Yes. But also lower power, so.. You won't get that high timing on a tune. Depends on ambient temps too.
For comparison here's a couple of mine (also B48) on 91 stage 2 beta tune, running 98 octane fuel.
June (high ambient temperature):
http://www.bootmod3.net/log?id=5d0df5c0c090c611aedbcfde
Recent (only +5c):
http://www.bootmod3.net/log?id=5d9b2951c090c61ab1d89b59
Thorbjorn
      10-25-2019, 08:16 AM   #22
chenzhuops2
China
Drives: F30
the stock 98gasoil
Recent (only +5c):
Is the normal value 5-10?
yours log look at the healthy
