12-02-2019, 12:42 AM | #1 |
Rep 43
Navi maps update for NBT2 id4 or higher
Hi all!
Guys, I’ve got a problem. Can not pull out FSC code from NBT2 2015 F33 US. Classic methods are non working (maybe, I’m doing something wrong with esys) Thanks for help! |
12-02-2019, 04:34 AM | #3 |
Rep 274
So what is the procedure for updating maps on these systems then? I see numerous websites offering EVO map updates for download, so surely it must be possible.
12-02-2019, 08:20 AM | #4 | |
Rep 2,302
Or you can download the maps yourself and buy the FSC on Ebay or numerous websites. |
12-02-2019, 04:57 PM | #5 |
Rep 274
I presume the commercially available FSC codes are sold by people having access to some BMW database.
Any work currently being done by anyone on a new FSC generator that will work for EVO? And what about the possibilities of hacking/reverse engineering USB stick activation or the firmware files? |
12-03-2019, 01:53 AM | #6 | |
Rep 43
Also, about keygen. I saw generator with checkbox id4. Few minutes, I’ll get the link. |
12-03-2019, 02:01 AM | #7 |
Rep 43
Jaeger 1.9 and higher have id4 support, but I hadn’t tried it, because hadn’t pulled out fsc
https://f30.bimmerpost.com/forums/sh....php?t=1456836 |
12-03-2019, 05:33 AM | #8 | |
Rep 274
I found this post by Jaeger himself illustrating the process: https://f30.bimmerpost.com/forums/sh....php?t=1529040 It seems he's pulling a 0xDE file in this example, but maybe you can change the Application Number-value to 0xF0 manually. Don't know it this helps you at all. The keygen is interesting, but keep in mind that Jaeger states that it currently only works for NBT EVOs that still use NEXT style maps. |
12-03-2019, 02:39 PM | #9 | |
Rep 43
12-19-2019, 04:33 AM | #12 |
Rep 43
it works! ID4 FSC got with https://f30.bimmerpost.com/forums/sh....php?t=1529040 manual and this latest generator https://f30.bimmerpost.com/forums/sh....php?t=1456836!
12-19-2019, 07:52 AM | #13 | |
Rep 2,302
07-22-2020, 08:44 AM | #15 |
Rep 2
@spuvdti: sorry for activating this thread again, which type of maps you have, EVO or something else?
I have F31 also MY2016 (Built 2015) with Europe Evo maps. FSC successfully extracted with esys (used 0xF0 for application number, Base variant identified as HU_NBT2). USB with Europe 2020-2 maps has been recognized by head unit, code requested by HU, but entered code, generated by latest BMW CIC FSC Generator (v1.9.19, is apparently wrong. Thanks in advance. |
01-16-2022, 03:57 AM | #16 |
Rep 8
Hi. I have car imported from USA to Eu. I lost navigation during cooding head unit. In this moment i can not open navigation - on the screen i have "Connect USB device with correct activation code to start navigation"
I nned to install new maps for Europe - how can i I do it? M4 - K709878 |
06-18-2022, 05:29 PM | #17 |
Rep 21
I cannot pull an FSC code as I have a G12 with ID5/6
I can generate a code with Jagaer's FSC 1.91, but his radio buttons do not list ID5. And, when I put in the USB stick with the 2021-2 NA map, it never asks to input a FSC. When I did this same process in 2019 with 2019-4, THAT map pulled the FSC code from the file on the USB already.
06-19-2022, 07:35 AM | #18 |
Rep 228
Drives: 2022 G20 330E
you need a actual FSC file in ID5 and higher EVOs, to get that file there are two ways:
1. official BMW map update 2. buy aftermarket patch to get that file.
| MGU Patching/Virginizing | ConnectedDrive activation for US cars in EU (Only MGU/ATM2) | Feature Installer codes | Map Updates | CarPlay activations. | NBT EVO GPS Connector installs. | NBT EVO repairs | Remote BMW Coding |
