03-19-2019, 12:58 AM | #24 |
Rep 5,392
Wow, looks very cool! Curious about your mods...wheels, tires, shocks, and others. For comparison, here's a photo of my 2015 335i x-Drive but with the AWD Eibach Spring kit that only lowers about 0.8" in the front and 0.6" in the rear. Stock 18" wheels and tires. Please keep us posted on how you like your new setup!
03-19-2019, 05:41 PM | #25 | |
Rep 1,064
New springs should also be paired with matched dampers. New setup will be Dinan springs, bump stops + Koni Sport yellow (Bilstein B8 still backordered and I don’t want to wait months) |
03-21-2019, 09:50 AM | #26 | |
Dustin335i
50
Rep 80
Drives: Mineral Grey M235i M/T
Hey man, You have a fantastic ride! I'm in your exact boat, and wanted to get your feedback. I'm lowering my '16 340 X-drive next week. I had already ordered Eibach springs for AWD, but your post is making me pretty sure I should return them and order the RWD version, as you did. Are you happy with the drop? I've lowered my last (5) 3 series "sport pkg" sedans, and understand there is a reasonably small, but noticeable, difference in ride quality. OVERALL, is the RWD spring kit working out well on your AWD car, and would you do it again??
03-21-2019, 10:20 AM | #27 |
Dustin335i
50
Rep 80
to clarify: my car I'm considering your same RWD Eibach springs on is a:
2016 340i xdrive, M-sport, adaptive suspension, staggered wheel setup
03-21-2019, 05:26 PM | #28 | ||||
Rep 52
03-22-2019, 10:47 AM | #30 | |
Rep 122
03-30-2019, 07:45 PM | #31 |
Rep 132
Eibach or Dinan shocks on 335Xi WITH adaptive suspention
Any info on this? I am surprised the Eibachs are less firm than the Dinan and wonder if this holds true for the magnetorheological adaptive shocks on my car. The Dinan spring rates are 225 F; 668 R---but I do not know what the adaptive suspension OEM spring rates are.
03-30-2019, 08:39 PM | #32 | |
Rep 5,392
Eibach RWD springs are different but I do not know the specs on them. I suggest calling Eibach to ask your questions. |
04-02-2019, 05:03 AM | #33 |
Rep 9
I recently bought Eibach ProKit Springs for my 435d xDrive (F33) with Adaptive Suspension.
I had to opt for the springs with a slightly higher load tolerance (due to the extra axle weight of the convertible), the part number I was provided was: E10-20-031-06-22. The drop is 20mm front, 15mm rear - with OEM 19" wheels and no spacers. Looks about the height of an M-Sport non-xDrive, body roll has reduced significantly and there is still plenty of road comfort, quite pleased! |
04-02-2019, 02:23 PM | #34 |
Rep 132
adaptive suspension settings with Eibach
SO I also have adaptive suspension on my 2014 MT 335Xi (with Dinan stage 1 and ER charge Pipe as well). Now that I have Michelin AS3+s replacing the Run Flats it is a pretty nice ride on my 18 inch square wheel setup.
Do you still have the RFs? if not, what suspension settings do you prefer now? Thanks. |
04-02-2019, 03:59 PM | #35 |
Rep 132
Interesting that Dinan does not offer spring set for F33 Conv.
I see you are in Manchester (hence UK). Why did you go with Eibach on your 435d Xi conv? Progressive springs?
Thanks. |
04-03-2019, 03:48 AM | #37 | |
Rep 9
I'm yet to have the geometry set up, but I find comfort mode to still be relatively comfortable, sport mode can be a little jarring on these awful roads around the UK, but it really does feel planted now with plenty more road-feel - which is what I was after, best of both worlds really. Eibach don't officially support the 435d xDrive 'Vert with their springs, but they were highly recommended by my tuner as long as I got the springs with higher axle load tolerances, and were cheaper than all other competing brands here. As said above - they are linear and not progressive. |
04-03-2019, 09:44 PM | #38 |
Dustin335i
50
Rep 80
Hey X-drive owners; Mark_tdot and Alec.sharp have figured out the formula for a very good riding suspension, that will also carve up turns and ride on rails! I followed their lead and had great results today. I just got my ‘16 340i X-drive, M-Sport, adaptive suspension back from my local tuning shop. I ran their recommended RWD-designated Eibach springs, part no. E10-20-031-02-22. The ride quality is barely different at all from my previous M-Sport suspension driving on city roads in traffic, but has 911-like handling when pushed on backroad turns. Plus, it looks like an M-car now, not an Audi AllRoad.
04-03-2019, 10:52 PM | #39 |
Rep 5,392
Awesome! Photos please?
04-04-2019, 01:10 AM | #40 | |
Rep 3,540
On the front spring, the recommended springs for your car (340xi) both have a spring rate of 34N/mm (194lbs/in), but one is 15mm longer than the other uncompressed. The spring that you chose has a spring rate of 29N/mm (165.5lbs/in) and splits the difference in length between the two recommended for your car. The difference between the xDrive and RWD rear springs is that the RWD spring has a spring rate of 86N/mm (491lbs/in) and the xDrive spring is 95N/mm (542.5lbs/in). The RWD spring is also 6mm shorter uncompressed. I went kind of the opposite direction as you. I REALLY enjoyed the ride quality moving up from the front spring you're running now, to the taller spring recommended for the 340xi w/ the adaptive dampers. The stiffer spring rate improved handling and body control over the softer spring IMO. Unfortunately that made the wheel gap a bit too large, so I moved to the shorter spring for the 340xi. Front end handling is still excellent, but there's a bit earlier bump stop engagement which doesn't make things quite as comfortable. Given how the rear EDC dampers operate (a decent bit more rebound than compression) I'm surprised you like the ride better as it forces you on your bump stops more. My next round of spring tweaking will be boosting the rear rates some, since Eibach's rear springs don't change the rate too much. Last edited by FaRKle!; 04-04-2019 at 01:15 AM.. |
04-04-2019, 01:36 AM | #41 | ||
Dustin335i
50
Rep 80
Thanks for your response. It certainly sounds like you've done your research, and I respect the hell out of that! In thinking about your last thought regarding bumpstops; which brand or measurement bumpstops have you had the most success with? I did have my bumpstops carefully cut down slightly. The Indy shop who did my suspension work is a drift-car/Nissan specialist, who prides himself on his suspension work.... so I trusted him to cut mine to where he felt they would ride best for me.
04-04-2019, 01:39 AM | #42 |
Dustin335i
50
Rep 80
Hey, sorry about that, man. Let me know what your thoughts are. I wanted to go low, without scraping much over speed bumps, and on the nasty roads here in the Philly area.
04-04-2019, 05:57 AM | #43 | |
Rep 5,392
04-04-2019, 06:06 AM | #44 | |||||
Rep 5,392
I'm curious where I can find the Eibach spring specs? I've got a 2015 335i xDrive with non-adaptive suspension. I've got Eibach xDrive spring kit installed which I really like. But the only specs I've heard is that they are 10% stiffer than stock as opposed to my second choice which would have been the Dinan xDrive spring kit which is supposedly 30% stiffer than stock. Curious if you have actual numbers comparing stock vs Eibach, and maybe even Dinan? Thanks in advance! |
Collins_F314.50 |
