03-18-2020, 11:28 PM | #111 | |
Rep 5,392
They both are designed with internal piston travel meant for lowered springs. Since ride quality/comfort are priorities the Koni Yellows should be perfect since they are adjustable for comfort, right while on the car. B8's have only the fixed factory setting. Hope this helps! |
Genericf305.50 |
03-22-2020, 10:41 PM | #112 |
Rep 17
Thanks anyone have Koni Yellows with E10-20-031-02-22 that can provide feedback on the comfort? I assume this is a common setup?
I went out to look at some pricing online for both the springs and koni yellows and it seems to be around the 1k range which was higher than I thought. That seems to be around same cost of the BC Racing coilover so wondering which setup is better in terms of comfort? I don't know much about the BC Racing coilovers and the reviews for it seem all over the place. It seems to have adjustable dampers similar to the koni yellows, not sure how the springs compare to the eibachs and the advantage is the ability raising and lowering of the car. Anyone know how these would compare? |
03-23-2020, 04:53 AM | #113 | |
Rep 5,392
Genericf305.50 |
05-15-2020, 03:16 PM | #114 | |
Rep 167
05-16-2020, 11:57 PM | #115 | ||
Rep 290
09-09-2020, 02:17 PM | #116 |
Rep 134
I am considering the Eibach E10-20-031-06-22 spring set and the Bilstein B8s. I have a 335x drive and the drop is about what I want.
Do I need to replace the bump stops too? I see Dinan makes bump stops, should I use those? |
09-09-2020, 03:14 PM | #118 |
Rep 4,333
matching dampers and spring rates is the essence of a damper/spring setup. in general...bilstein, stiffer, less compliant but handles certain frequencies better than koni. koni is more compliant on the street and handles some frequencies better than bilstein.
since koni yellow sport has a better ride on the street and adjustable rebound, i would do koni yellow sport over bilstein. the other reason i'd do koni is because bilstein uses internal bumpstops and after reading through many threads and post about it, i prefer typical damper design. https://f30.bimmerpost.com/forums/sh...8&postcount=26 https://f30.bimmerpost.com/forums/sh...uss+bump+stops Koni and Eibach also work together offering damper/spring combos. |
09-09-2020, 03:24 PM | #119 |
Rep 134
Thanks for the reply. So do I not need new bump stops if I went with the Koni/Eibach setup?
Is this the setup you recommend? https://www.tirerack.com/suspension/...After+3%2F2014 |
alohasurftoad3081.50 |
09-09-2020, 04:08 PM | #120 | |
Rep 4,333
eibach has two different spring options. 5-22 is lower than 6-22. the tirerack link is koni yellow sport with eibach 6-22, not real low but reduces the wheel gap to more than acceptable. that tirerack setup is what i'd get for myself*, however tbh, i think you should read through more threads, posts and obtain more opinions and information, so you can be sure that setup is what YOU want and not what I (or others) want or like. *fwiw, i have a M-Performance suspension but frequent and have some knowledge in some of the various sub-forums. |
09-10-2020, 12:45 PM | #121 | |
Rep 5,392
I've got the same car and same springs. If yours is a daily driver, you may want to avoid the B8's which will be a lot stiffer. I got Koni Special Actives. They have technology developed with McLaren. It works with two frequency valves so it's a sport shock on curves and a comfort shock on rough roads. It really works as advertised. Perfect with those Eibach springs. Koni tested the combination on an xDrive and you just reuse your stock bumpstops. |
09-10-2020, 01:41 PM | #122 | |
Rep 134
09-10-2020, 03:24 PM | #123 | |
Rep 472
I installed a set of the "dinan" shortened bump stops on my Koni Special Active and Eibach Pro Kit setup and it fixed the bottoming out problem I was having. The "dinan" bump stops are nothing but marked up OEM bump stops from older vehicles. The part numbers are: Front: 31331138814 Rear: 33536762722 |
rlesko232.50 WhiteCollarMetalHead32.50 |
09-10-2020, 04:00 PM | #124 | |
Rep 134
Thanks for the info! I am worried I made a mistake getting the Koni Yellow Sports vs the Koni Special Active. Anyone have input on this one? I did get the higher Eibach springs 06-22s. |
rcaso26331.00 |
09-10-2020, 04:32 PM | #125 | |
Rep 177
https://www.tirerack.com/tires/tiret...jsp?techid=293 |
09-10-2020, 06:19 PM | #126 | |
Rep 4,333
What is the difference between KONI Special (red) and KONI Sport (yellow)? The KONI Special (red) has been engineered to maximize the ride comfort with good handling performance for each vehicle application. The KONI Sport (yellow) typically starts at a higher initial valving baseline to give a sportier feel and work on vehicles with higher performance parts. In some instances, KONI will only offer a Special or Sport valving and not both. Some modern cars come from the factory with higher tech suspension systems and wheel/tire packages so they would move directly into the Sport range, however they are still valved to give a comfortable ride with very good handling capabilities. i knew about the Koni SA but suggested the Yellow because you mentioned tracking and were initially getting Bilstein which is stiffer than Koni. in retrospect i should've suggested both Koni options and let you decide what was best for you. fwiw, i think you'll be fine. this thread has good info on both...https://f30.bimmerpost.com/forums/sh....php?t=1662711 Last edited by alohasurftoad; 09-10-2020 at 06:33 PM.. |
09-10-2020, 07:48 PM | #127 | ||
Rep 5,392
All this assumes that the lowering springs are mild (<1") like the -06 Eibachs being discussed. The Koni Special Actives aren't designed to lower more that that. As soon, as someone says that they want a bigger drop such as H&R, then Yellows are the Koni option, and B8's from Bilstein. I prefer Yellows because they are adjustable while B8's are not. Farkle! actually did some great comparison posts using data actually provided by Koni. The conclusion was that there is a lot of overlap between SA's and Yellows, with the SA's having more capacity into the comfort range and Yellows more range into the sport area. Of course, springs and shocks are only some of the components involved in the suspension. A track-oriented guy would assume that my car with Koni Special Actives and mild Eibach springs wouldn't perform. But I purposely chose them because I didn't want a teeth rattling track car as a daily or when I drove it on trips. But my car would surprise a track guy because it also has H&R sway bars, a Weicher strut brace, VAC Monoball Thrust Arms, wider 245/40-18 Michelin PS4S tires (courtesy of a Hawaiian surfer dude) and M Performance Brakes with StopTech Crossdrilled free floating rotors and Hawk 5.0 pads (incredible bite combination). A couple of my tracking friends have driven my car on the street and told me that they were amazed. It's all about matching the components for the driver's goals. |
alohasurftoad3081.50 exE36M3487.50 |
09-10-2020, 07:55 PM | #128 | ||
Rep 5,392
I've got a 2015 335i xDrive with Koni Special Actives and the mild drop -06 Eibachs. (Drops F0.8"/R0.6") I kept the stock bump stops based on recommendations from Koni North America tech support. Wondering what the difference is that you were bottoming? |
09-10-2020, 08:00 PM | #129 | ||
Rep 5,392
09-11-2020, 08:14 AM | #130 | |
Rep 134
johnung4528.00 |
09-11-2020, 09:14 AM | #131 | |
Rep 472
johnung4528.00 |
09-11-2020, 11:04 AM | #132 | ||
Rep 5,392
rcaso26331.00 |
