BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Knocking sound when turning left when driving at speed
      12-18-2021, 08:03 AM   #1
Amazinjoey
Drives: BMW 320Dx 2013
Hi!
So i've gotten a really weird issue where my car is knocking sound when driving down the road and seems to happend when driving straight and turning to the left. This is a constant knocking sound that sound abit hallow
Any ideas?
F30 320D Sport Xdrive, 2013/01
lcs195636.00
      12-18-2021, 11:37 AM   #2
weehe126
Drives: 2017 340i
Have you inspected anything?
      12-18-2021, 12:12 PM   #3
johnung
Originally Posted by Amazinjoey View Post
Hi!
Any ideas?
Get under and visually inspect. Look for fluid coming from the inner bushings on the Upper Control Arms. Look for any loose bolts in the suspension. Find a local Indy mechanic to go over it thoroughly. See BimmerShops website
      12-18-2021, 01:15 PM   #4
Amazinjoey
That's the plan on Monday! I only done an external look and check the CV joint and they don't look ripped in anyway, also seems dry from what I could see. Planning to raise it tomorrow and look myself.
Just afraid that it would be the Steering rack...
      12-19-2021, 01:16 AM   #5
johnung
Upper Control Arm bushing
      12-19-2021, 11:32 AM   #6
cfm56d7b
Hi!
Any ideas?
How many miles does your car have? When did the symptoms start? Any recent events, i.e. encountering a pot hole?
      12-19-2021, 01:12 PM   #7
Amazinjoey
Last Wednesday, Came out of the blue when I was driving. No pot holes or anything that I can Remember
It has gone 124K miles(200 000km)
      12-19-2021, 01:29 PM   #8
cfm56d7b
In this case and considering the mileage, a thorough inspection of all suspension components by an experienced shop would be recommended.
johnung4528.00
      12-20-2021, 12:37 PM   #9
Amazinjoey
Visited three mechanics, two BMW shops and one indy(a friend)
1.First shop (BMW), had no idea what It could be and told me to live with it. recommended shop nr 2
2. Second BMW shop looked and believed it was the Steering rack, quoted the job and labor abit under 6000 USD. This was a new rack and installing it.
3. Third shop, an indy and friend lifted it and we look through all the bushings front and rear, Thrust arm bushing in both sides are rotting(might be the wrong word) but no fluid, but we think it is the u join in the steering column. as wiggling the steering wheel back in forward made about the same sound and it pretty loud. Is the U join going bad a common problem ?
      12-21-2021, 09:33 AM   #10
kilogram
Drives: 340i xDrive
xDrive? Adaptive suspension?
I have the same sound I think, and mine has always done it. Kind of sounds like hollow popcorn driving on any sort of uneven pavement?
I've got millway spherical bearings in my tension rods (with new balljoints), new end links and camber plates. I've checked whether the sound changes depending on loading and it doesn't. It knocks with the suspension loaded in every direction, with the steering loaded, with the engine under torque to load the engine mounts.
Only things I can think of at this point are LCA ball joints since those are original, axles knocking the end of their travel, and damper internals. I don't think it's the steering (which is a known issue on F30s) because the noise is much duller than the back and forth knocking when the car is off, and it still does it even when the steering rack is loaded.
Makes the car feel pretty jank, honestly.
      12-21-2021, 05:14 PM   #11
Amazinjoey
XDrive, standard suspension!
It seems to happen on every kind of road, most are bad here in Sweden due to taxes going to the wrong thing
We tried that but it all seems normal, even went to a alignment shop and asked them to look, and they also found it weird
Tried to record the sound but this the best I can do
https://youtube.com/shorts/Z_M-tR_HLZ4?feature=share
      12-25-2021, 12:45 AM   #12
Amazinjoey
Got a better recording, seems to be coming from the rear(?)
      12-26-2021, 07:50 AM   #13
Amazinjoey
Found the problem! Loose wheel lugs!
How did I find that out? Well caught the guy parking next to me in the act trying too loose them on my backup car…
      01-13-2022, 10:53 PM   #14
Onizukachan
Great Teacher
Onizukachan's Avatar
1086
Drives: 06 e91 325ix
2006 E91 325ix  [10.00]
2006 Mini r53 JCW  [0.00]
2005 Mini r53  [0.00]
Did you beat him with a large claw hammer in the orbital socket?
over Terra (one of 1), Nav, Sport, L7
A few OEM+ mods:
MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come…
