01-24-2022, 12:36 PM | #23 | |
Bobafet7
Rep 16
Front 984Kg Rear 1170Kg Total GVWR 2093Kg Once again this is for a 328d Xdrive with F30 with N47 engine which is 2.0L Turbo Diesel. |
01-24-2022, 09:10 PM | #24 | ||
Rep 5,392
Just to be sure I would suggest looking around at local dealer or used car lots to find any 320d XDrives to see if the axle weights on their door jams are similar to yours. I saw that the 320dx uses four different power levels of the N47 or B47 engine so their axle weights may vary a little. But they all use the Eibach -04 spring kit. So if their axle weights are in the same range as your 328dx, then the -04 kit should be a good fit for your car. |
01-25-2022, 06:22 AM | #25 | |
Rep 72
The plot has thickened on this for mine. A company that replied to my Koni enquiry have now confirmed that they don’t advise them for the F36 due to weight, not sure why if some of the 335d’s can be heavy enough to require the 06-22 spring set.
01-27-2022, 04:47 AM | #26 | ||
Rep 5,392
I know guys who have installed adjustable Koni Sport Yellow dampers and love them. If Koni has them listed for your car then you can't go wrong. |
01-27-2022, 06:28 AM | #27 | |
Rep 72
I’ve ordered the sports anyway so should have them in a week or 2 then get everything built up ready to fit. |
alohasurftoad3076.50 johnung4528.00 |
02-04-2022, 12:07 PM | #28 |
Rep 72
Almost got all of the bits together now, just waiting on a few deliveries before I can get them built up ready to fit.
johnung can you tell me what your axle weight figures are for your car please, obviously you got the states drops with the 06 kit didn’t you. I opted for the 05 kit so will see how it is when fitted. |
02-04-2022, 07:50 PM | #29 | |
Rep 5,392
I would be curious to hear from someone with the European version of the same car because I would expect the front axle load rating to be less. Eibach specs the -06 spring kit for the US model and the -05 spring kit for the European model. And Eibach estimates the exact same drop in both cars of Front 0.8"/20mm and Rear 0.6"/15mm. According to EibachUS, the spring rates of both kits are identical and the rear springs themselves are identical in both kits. But according to Eibach, the Front spring from the -05 kit would have a lower installed height in my car by 15mm. That would mean a total front drop of 35mm or about 1.2"-1.4". I'm curious to try it. But I will make sure to take very exact before and after measurements to find out exactly how much the difference is. |
asbrr543.00 |
03-10-2022, 08:00 PM | #30 |
Rep 89
Hi all - new to the forum and this is my first post. I’ve been lurking here for quite a while and just now joined. The very helpful information of others helped me to make decisions like this so I hope to return the favor.
I was debating between the 02-22 and the 05-22 for my 340i XDrive. The 06-22 ones were not really on the table as I felt like the effort to lower the car wouldn’t be worth how subtle the drop was. Ultimately I chose the 05-22 springs for 2 reasons: 1. Comfort. I previously had Rwd springs on my E90 335i XDrive and while it looked incredible, I had to be very strategic when driving to avoid specific areas on my commute with bumps or dips in the road as they could be very jarring. With the 05-22 springs this is not an issue. 2. Longevity of the stock adaptive dampers. I felt like the higher ride height won’t wear the OEM dampers out as fast. I could be completely wrong in this assumption. The look of the car with the 05-22 springs is still only subtly lower than factory. Unfortunately I forgot to take measurements before installation. I prefer the look of the 02-22 rwd springs but that comes with compromises and I much prefer the ride of the car a little higher when driving over imperfect surfaces. I’ll post pictures if anybody has interest but figured I’d add my $.02 in case anybody else is out there debating like I was. |
03-10-2022, 11:02 PM | #31 | |
Rep 3,368
https://f30.bimmerpost.com/forums/sh....php?t=1901058 |
asbrr543.00 |
03-11-2022, 08:08 AM | #32 | |||
Rep 89
07-23-2022, 10:00 PM | #34 | |
Rep 706
07-23-2022, 10:38 PM | #35 | ||
Rep 5,392
07-24-2022, 12:29 AM | #36 |
Rep 706
Is it number 10 and 11 for the rear?
Number 4 and 6 for the front? Also if buying a coilover, is it still necessary to replace the rubber bits? Or only with koni & eibach combo to replace the rubber bits? Thanks. |
