12-18-2017, 07:53 AM | #23 | |
Rep 247
12-18-2017, 03:02 PM | #24 | |
Curmudgeon and Pedant
690
Rep 3,489
12-18-2017, 06:14 PM | #25 | |
Head Fry Cook at McBurgertown
507
Rep 1,005
The distance to work (and the beer store ) didn't change. I changed the wheels back to the originals when I traded it back in; a five-hour drive to the dealership to trade it in registered slightly over 200 miles. With the 19" wheel & tire combo, it registered 50 miles on in-town commutes. Regardless, the F32 I picked up registered the same 200-ish miles on the trip home. I'm happy now. |
12-20-2017, 08:45 AM | #26 |
Rep 247
So, I ended up ordering Michelin PS4S 245/35x19 tires for the front and 264/35x19 in the rear. I chose not to get the 255s for the front as my analysis suggested because: 1) I learned that matching diameter sizes isn't as important in the front (the speedometer gets its information from the left rear), and 2) I don't want to risk rubbing during turns. I'll report back in a few weeks after I've driven on them awhile.
12-20-2017, 08:11 PM | #27 | |
507
Rep 1,005
01-01-2018, 11:50 AM | #28 | |
507
Rep 1,005
Pics? |
01-05-2018, 01:58 PM | #29 | |
507
Rep 1,005
Could you link to the sources you've researched? |
01-05-2018, 04:28 PM | #30 | |
690
Rep 3,489
But even though I believe it's an average, I don't really care too much. I have much more problems with the built-in inaccuracy due to crazy regulations. |
01-06-2018, 09:44 AM | #31 | ||
Rep 196
Why is everyone so concerned with speedometer? With all the sizes mentioned you?ll only be off a couple MPH at highway speeds... |
01-06-2018, 10:23 AM | #32 | |
690
Rep 3,489
1) 225/45R18 (that's an F3x size - E3x is 225/40R18) of Blizzak WS80. The speedometer is almost dead-on the real speed with those tires on - perhaps 1/2 mph fast. 2) 225/45R17 Michelin Primacy RFT's. That is an OEM size, comes on basic 325i/328i E9x (wheels are OEM BMW). With those tires on, the speedo is 4-5 mph fast at 70-80 mph. So, from the "standard 2-3 mph fast with OEM-size tires, the actual range of measured offsets from true is substantially bigger than your "couple MPH": 4-5 versus 2-3 (Primacy vs. Michelin Pilot PS2 ZP). Both factory sizes for E9x. Different manufacturers give different results. |
01-06-2018, 11:09 AM | #33 | |
507
Rep 1,005
If your speedometer is reading too fast, your odometer is accumulating miles at a rate faster than it should (and devaluing your car at an artificially higher rate in the process). |
01-06-2018, 11:59 AM | #34 | ||
Rep 196
01-11-2018, 10:55 PM | #36 |
507
Rep 1,005
02-10-2018, 08:22 AM | #38 |
Rep 832
Drives: 2019 G01 X3
Can you confirm if the OEM center caps fit in the FT101?
06-19-2019, 08:21 PM | #40 |
Rep 385
purchasing same spec wheels as the OP. 19's 8.5 et 32 and 9.5 et 40 on an xdrive f30 with coilovers
but for tires.... 235/40 and 265/35 OR 245/40 and 275/35 is the difference that noticeable between the two? more concerned with speedo error. trying to eliminate wheel/fender gap and protection to the wheels because the roads are usually bumpy with random potholes. BUT i like the wider look of the tires. help a first time wheel/tire buyer out. Last edited by Mkswoosh; 06-19-2019 at 08:53 PM.. |
