12-04-2019, 12:11 PM | #1 |
Rep 582
What camber for 340xi ?
Hi, I am about to get new tires installed on 2016 340xi with track handling package. On a stock car for road use, what are the recommended specs for the 4 wheel alignment?
Important - I will be using larger front tires than OEM (245/40/18 vs stock 225/45/18) Does everyone use stock factory alignment spec? Or is there some adjustment? |
12-04-2019, 12:45 PM | #2 |
Rep 463
No adjustments in the front. Use factory spec for the rear.
There is no need for an alignment if just changing tires by the way. Suspension geometry is not affected. |
12-05-2019, 11:54 AM | #3 |
Rep 582
Thanks. I need an alignment anyway, based on wear patterns on current tires...just wanted to see if anything different needed based on new tire size to be used with new tire package.
Thanks! |
