09-19-2018, 04:22 AM | #1277 |
Rep 206
First impressions using Google Maps via carplay on iphone8.
Very very fast and responsive, great integration. You can do anything without touching the screen (select saved routes, select alternative routes, zoom etc etc). Great great great. The bad: a lot of disconnects with carplay dongle and autoplay app. I have informed developer. Have not tried yet with external usb power. If this solution works, then we have a killer feature!!! Only this can be a very strong reason to buy ugode screen. Any feedback from others? |
09-19-2018, 04:46 AM | #1278 | |
Rep 116
Mh, I can't understand a thing.. Yesterday lots of people wrote that Autoplay App does not work with ios 12, but you can't have Google Maps without ios 12.. Does ios 12 work with autoplay in your HU? |
09-19-2018, 04:49 AM | #1279 |
Rep 206
Where did you see those posts?
I was able to use autoplay even from ios12 beta7. But today that I tested with google maps, I had a lot of disconnects... |
09-19-2018, 04:52 AM | #1280 |
Rep 206
I just saw some post on other forums, that say that battery must be >70% and autoplay developer said we must try the external usb splitter. I will try to buy today and test.
09-19-2018, 05:33 AM | #1281 | |
Rep 48
Which connectors was needed; two females and one male? |
09-19-2018, 05:57 AM | #1283 |
Rep 93
Also guys if you want to make your Autoplay icon look like the proper official one, download Apk editor from google playstore and you can change name to CarPlay also change the icon picture to the apple one.
09-20-2018, 12:04 AM | #1284 | |
Rep 206
The solution to autoplay disconnects with white CarPlay dongle is to connect a usb male to 2 usb female and 1 usb male to 1 usb male cable.
But be careful: 1) the dongle must connected directly to ugode screen 2) the usb splitter is between your iphone and dongle 3) 1 female connects to iphone and the other to car lighter usb charger via a usb male to usb male cable 4) !!! CAUTION !!! Do not connect 2nd female usb to usb charger during ugode screen boot cause you will experience NO SIGNAL. Do not disconnect iphone with 2nd female connected to usb charger because ugode will hang!! If you follow these strange rules you will have a very stable and ultra super experience. Google maps on CarPlay is a killer feature! Hope ugode and CarPlay dongle some day in 2030 will solve the extra power requirements. If you would like to take advantage of the extra charger port that is hidden under compartment you must select a very small (in height) usb car charger. I have not tried that port yet. More feedback will come after more road testing! Hope others can provide also feedback about this. Mike Quote:
09-20-2018, 01:17 AM | #1285 | |
Rep 48
Regarding the 4th caution; Is it not possible to have the power cable attached at all times and then connect the phone during startup of the car? (must be plugged in before start?) It is not possible to remove the Iphone from the adapter when the car is running if the power is connected, or ugode will hang? Thanks for testing! |
09-20-2018, 02:45 AM | #1286 | |
Rep 206
Pure cable.
I connect the extra power cable to car charge after android has finished booting. If the cable is connected before car start and android boot then ---> no signal / no boot at all. During use (with extra power connected) when car is running I removed iphone and ugode hang. Will try more to see if this happens every time... Today I tested concurrent use of google maps, spotify and iphone calls and everything went perfect. Still cannot use microphone in carplay. Dont know what the exact setup must be... Quote:
09-20-2018, 02:47 AM | #1287 | |
Rep 206
Also, today autoplay has a new version. I have not tested it yet. You will see it by clicking autoplay settings, and check for updates.
09-20-2018, 02:52 AM | #1288 |
Rep 116
Hi all,
Another thing I would like to enhance on CarPlay, let's see if anyone is able to help me: When I start using it, Siri does not hear me.. The only way to make it work is to receive/make a call, and in the iPhone screen select the "BMW original microphone" for that call.. Then, also after the call, the default audio input is the bmw microphone and Siri works really good.. Is there any way to make it as a default input for audio? Otherwise we have to receive/make a call in order to fix it each time we open CarPlay app.. |
09-20-2018, 03:47 AM | #1289 | |
Rep 206
Very useful finding. Thank you!
Will try to reproduce. can you try if the following fixes the issue? "Simply went to Siri and turned on "Listen for "Hey Siri"" Quote:
09-20-2018, 03:54 AM | #1290 |
Rep 116
"Listen for Hey Siri" is already on.. but when it's plugged in the Andorid HU it doesn't work (Siri doesn't hear me) until I do that trick with the calls..
09-20-2018, 06:30 AM | #1291 | |
Rep 48
Nice troubleshooting, a hazzle then to have to plug in the power jack every time and also first after android has booted up, would have been preferable to always have it plugged in via the glove compartment usb. |
09-20-2018, 03:55 PM | #1292 |
Rep 32
Looking at getting one of these Android HUs but been waiting few days for a response from Ugode with a price
Can someone just explain the AUX In setup for me. I assume the connection is made under the dash rather than a cable trailing to the armrest? Do you have to select AUX each time you switch between OEM and Android unit? If AUX is selected, does that then mean the OEM radio can't be played whilst using say Waze on the Android side? Thanks in advance |
09-20-2018, 05:18 PM | #1293 | |
Rep 201
09-21-2018, 02:09 AM | #1294 |
Rep 32
09-22-2018, 11:48 AM | #1295 |
Rep 48
Hi,
I just installed my unit now. Seems I didnt need the AUX-input. However, I have an issue with "No Signal". I experienced it when I was using the OEM-screen where it would intermittantly show "No Signal" and then show "BMW Connected Drive", to come back to the menu to revert to "No Signal" again. Tried to read about the no signal issues experienced in the forums but uncertain of a clear solution? Please advice See example here: https://vimeo.com/user64395771/revie...529/0a3cd1e744 UPD: Tried again now 3h later and the "no signal" didnt appear, might perhaps been a temporary upstart bug. I did however try to change the screen size in factory settings from [1]NBT_F48/F49(6.5",HalfScreen) to [3]NBT_F48/F49(8.8",10.25"), but got the error message "SD Card or U disk OEM directory did not find the cartype.xml file"? Tried all 10.25 options and all were the same. Advice? Havent gotten the cable to re-program the BMW yet but that comes later. Last edited by lindstroem; 09-22-2018 at 03:40 PM.. |
09-22-2018, 07:50 PM | #1296 | |
Rep 201
09-23-2018, 07:08 AM | #1298 | |
Rep 48
Regarding sound which has been a frequent issue on the forum. I've read that people suggest reducing the AUX-sound to 10 (from Druw in the latest post i think) in OEM-settings and then increasing the sound in Android (I've tried to increase it to max in Android). However when i then try to increase the volume to a fairly high level there is still high amounts of static/hissing coming from the speakers. Can I only play music on lower levels for the Ugode unit to be able to produce reasonable sound? Or are you able to play on high volume without static/hissing? I did not have to reroute the AUX to the armrest but only use the already present connectors. If thats the case I believe I will stick with the OEM-bluetooth sound and then only use the android-side for the navgiation Thanks! |
