02-01-2021, 02:02 PM | #1 |
Cheapskate
4455
Rep 4,995
***Common B58 Issues***
Making this thread to hold a series of videos I'm making in regards to common B58 issues. Click on the respective links to go straight to the post with the video. If you have any particular requests, please list them below
Youtube Playlist: https://www.youtube.com/playlist?lis...aDh_Jmy5UAHeOn 20A201 Charge air, cooling system: Dry-running detected - Post 20E120 Crankcase Ventilation Hose Disconnected - Post CDB309 - Post A/C Blowing Warm - Post Cam Ledge Broken - Post "HPFP Crashing" - Post Injectors - Post Low Coolant Warning - Post O2 Sensor Issues - Post Hope this helps!
PeterWT253.50 les anderson147.00 kianf2264.00 WolfGTI716.00 B50AteYourRide70.00 john_f3016.50 TravisBGolf132.50 squaredphoto373.50 sdbwisc66.00 DreamerJoe243.50 Doctor X78.00 BeyondAddiction3.00 |
02-01-2021, 02:04 PM | #2 |
Cheapskate
4455
Rep 4,995
02-26-2021, 03:27 PM | #3 |
Cheapskate
4455
Rep 4,995
Low Coolant Warning
cfm56d7b5911.00 B50AteYourRide70.00 |
02-26-2021, 07:22 PM | #4 |
Rep 276
Subscribed 👍🏽 is it a common issue to get the emergency call malfunction code or is that only me?
Instagram- f30_luca
Modifications: Custom E50 Tune by David Shoup, B58TU Fuel Pump, Armytrix Exhaust, VRSF downpipe, Big Boost Charge pipe/bov kit, CTS intake, H&R Springs/B8 Struts, 335is Clutch Upgrade |
kern4174454.50 |
03-01-2021, 01:46 PM | #9 |
Cheapskate
4455
Rep 4,995
Not something I'll be covering in this group of videos but I've heard of it on BMW before. Search around, even on e-series forums to see how people are fixing it.
03-01-2021, 03:57 PM | #10 | |
Rep 276
Instagram- f30_luca
03-05-2021, 02:07 PM | #11 |
Cheapskate
4455
Rep 4,995
03-08-2021, 09:41 AM | #12 |
Rep 1,597
It looks like the flimsy diaphragm is the control valve and also governs the non-return to the intake and combustion chamber. I don't see any other part which could be the non-return valves. So if you replace it with a breather, aren't you introducing lean conditions into combustion?
03-09-2021, 10:33 AM | #13 | |
Cheapskate
4455
Rep 4,995
05-14-2021, 12:09 PM | #14 |
Cheapskate
4455
Rep 4,995
"HPFP Crashing" or Rail Pressure Dipping
08-16-2021, 09:33 AM | #16 |
Cheapskate
4455
Rep 4,995
Failed O2 sensors
08-16-2021, 10:31 AM | #17 |
Rep 1,597
08-17-2021, 07:06 AM | #18 | |
Cheapskate
4455
Rep 4,995
If you have a catless downpipe then it's not typically an issue, because the car can adjust accordingly. But it can still throw a CEL if you're not tuned. |
08-18-2021, 10:57 AM | #19 | |
Rep 1,597
08-18-2021, 11:36 AM | #20 | |
Cheapskate
4455
Rep 4,995
08-22-2021, 04:05 PM | #21 |
Rep 3,885
The secondary O2 is typically just a cat-function check and therefore often a simplified (cheaper) variant.
It should NOT have any effect on the engine, although it throws a CEL (bad emissions or lack of emissions control is per definition a CEL event). Not every CEL event has an impact on the engine.
08-23-2021, 02:10 PM | #22 | |
Cheapskate
4455
Rep 4,995
https://www.e90post.com/forums/showthread.php?t=930267 https://www.bimmerforums.com/forum/s...fect-fuel-trim https://www.m5board.com/threads/func...ensors.162711/ |
