01-09-2019, 03:01 AM | #23 |
Rep 112
Drives: BMW 1M Coupe + M2 + 330e
Ok, something new here...
The 2 USB ports of my car are not working (both of them, the one in the armrest and the one on the front panel). They don't charge my iPhone and nothing happens when I plug a USB stick with music files (can't see it in the Media\USB). I tested with a USB stick who has a red led on it. It flashes when it's plugged in my colleague's Passat but nothing when it's plugged into my car. Several weeks ago, I had to replace the fuse because the front cigarette lighter (12v) socket wasn't working. But at the moment, it's working. Is there a separate USB fuse for USB's ?
BMW 1M Coupe - AW - 2012
BMW M2 DCT - BSM - 2017 BMW 330e iPerformance - GSM - 2016 |
01-16-2019, 06:40 PM | #24 |
Rep 14
I was able to get the maps on a 64 GB stick that was Fat32. It started the update but after an HOUR it's still only at 12%.....any idea how.long this update takes??
I had the 2018-1 on there (2015 X6) and I dont remember it taking this long. Last question, does the car have to be running or can it do it off the battery with the car off?? Except at current rate it will take like 7 hours..... Any ideas?? |
Riordo0.00 |
01-16-2019, 06:46 PM | #25 | |
Rep 32,881
01-16-2019, 07:10 PM | #26 | |
Rep 32,881
01-16-2019, 08:11 PM | #27 | |
Rep 440
Drives: 2013 335i xDrive
I'm not completely useless, I can be used as a bad example.
03-16-2019, 01:18 PM | #28 | |
Rep 228
F30 335d xDrive M Sport + 2014 |Birds B3 Dynamic Suspension Kit Springs and Dampers |Pro Media Pack | Visibilty Pack | Interior Comfort Pack | Electric Adjustable Heated Front Seats + Driver Memory
07-01-2019, 08:41 AM | #29 | |
Rep 4
Next I connected the drive to the USB port in the central armrest before powering on the car. Upon powering up the car detected the update immediately and I just had to confirm that I wanted to update. Update was done in about 20 minutes I think. |
09-28-2020, 06:28 PM | #30 |
Rep 5
G30 (530e) Map Update
Updated from Europe Evo 2017-1 to 2020 - 2. This worked for me without a hitch:
128GB USB Drive Formatted exFat with Allocation Unit Size = 32768 (max size possible) Unpacked Zip download to USB root directory Plugged USB into car, ignition on, installation started immediately. Finished in about 40 mins elapsed time with several interruptions of about an hour each when car was not running |
09-28-2020, 06:34 PM | #31 |
Rep 5
11-27-2020, 03:59 PM | #32 | |
Rep 1
08-08-2022, 08:28 AM | #33 |
Rep 271
After a lot of hassle trying to format a 2TB SSD drive to FAT32, I went for the manual unzipping of the Evo File.
Download manager could see any usable USB drive to unpack to. Tried everything.. Some tips; Location: C:/Users/YOURNAME/bmw-dlm/dl/Road_Map_EUROPE_EVO_2022-1 The file which I've downloaded had no extension. I just renamed the file and put ".zip" behind the filename. Et voilá, I could unzipp it to my flashdrive. Which was NTFS... Worked like a charm in my car..
"It ain't much, if it ain't Dutch "
LikeNo18.50 |
08-26-2022, 06:06 AM | #34 |
Rep 79
As I read seem ExFat or NTFS both works on USB pendrive greater then 32gb.
I've downloaded the EVO 2022-1 version from a torrent, unpacked on my exfat 128gb pendrive but with no result; think the file I downloaded is corrupted. |
09-04-2022, 03:49 AM | #35 | |
Rep 79
Any idea? SOLVED Problem was the USB pen drive: it won't to be recognized by the car. On the pc it seems ok, but "chkdsk" command start but won't finish. deleted all, created new partition FAT32 on 128gb usb drive, copied all (FSC dir included), chkdsk worked and boom: update made. Last edited by LikeNo1; 10-17-2022 at 10:35 AM.. |
07-11-2023, 04:48 PM | #36 | |
Rep 139
