01-22-2019, 03:20 PM | #1 |
Rep 36
328i xDrive transfer case fail.. due to staggered wheels?
So I've been hearing a grinding noise in my car for a couple weeks now. I brought it to the dealer last night and after a talk on the phone today, I found out my transfer case went bad. In the summer and fall I ran a staggered set of 18 inch wheels before switching back to the stock 17s for the winter. 8.5 in front and 9.5 in the rear, 225/40/18 x 255/35/18. This is in between the 1% rotational diameter. I've been told that if I stay in between 1% its fine to run staggered on xdrive. Is it possible that this was the cause of the transfer case failure?
01-22-2019, 03:41 PM | #2 |
Rep 3,538
We have a thread going on in the diesel section about transfer case failures with a database of events. In my opinion, the data doesn't suggest that a staggered setup causes it.
02-03-2019, 02:36 PM | #5 |
No 55mph
1619
Rep 8,476
Staggered setup with proper size tires does not cause transfer case failure
BMW sells the xdrive cars with OEM staggered setup Ran staggered on my 09 328ix for 9 yrs and no problem, run staggered now on my 2015 435ix with no problems
02-03-2019, 04:59 PM | #6 | |
Rep 10,255
The only caveat: if your specific xDrive model was never with staggered wheels / tires, BMW can claim that non OEM wheels could be the reason for xDrive failure, EVEN if the same wheels / tires are offered in another F3x model. It's the most unusual position. There is another forum member dealing with the same problem. His F3x wagon came only with square wheels / tires with no optional staggered wheels / tires. Did the dealer indicate how the problem will be corrected? |
02-04-2019, 06:24 AM | #7 |
A family of bimmers
2745
Rep 7,741
i had metal shavings in my transfer case at 40kmi. replaced under warranty and i had factory staggered wheels.
02-28-2019, 05:28 PM | #8 | ||
Rep 36
02-28-2019, 05:57 PM | #9 |
Rep 10,255
Thanks for sharing an update. Very glad to learn the problem was resolved to your satisfaction.
Still - this entire dialog with BMW is both illogical and makes very little sense. |
