12-29-2018, 01:48 PM | #45 | |||
Rep 2,060
I'm not an expert though so might be looking through rose tinted glasses but assuming that the e46 was in fact better set up and they can evidently still produce a highly competent M Car I'm not sure why BMW seemed to lose their way so much with the F series. |
12-29-2018, 02:07 PM | #46 | ||||
Rep 19,982
rich100874.50 |
12-29-2018, 03:55 PM | #47 | |
Rep 1,303
Tbh i only ever use my car anywhere near a supermarket with my 3 year old! |
12-29-2018, 05:29 PM | #48 | |
Rep 665
I've found the pedal responds to how quickly you kick it.. and how far you kick it.. With some practice you'll be able to drop straight into 3rd be flying! |
12-30-2018, 12:58 AM | #49 |
Rep 19
I agree with op, nothing mind-blowing about the 4. Although I only have a 435i so I can't say anything about the 440i. Only reason I stick to them is not because of what you get from BMW but what you can get for your buck in mods. I honestly can't think of other cars that for so little you can get so much out of them. My E92 335i was a complete beast with fbo and some e85 and the 4 series is no slouch with fbo. Also the fuel economy is nothing to complain about, I have a e70 x5m and no matter how you drive that thing in the city, good luck getting anything over 12mpg and 16mpg highway. Overall I'm sticking with these cars because the pros just keep me hooked.
12-30-2018, 02:04 AM | #50 | |
Rep 1,470
Also you are rather contradicting yourself there, you say you can't complain about fuel consumption then state you can't get over 16mpg in your car. |
12-30-2018, 03:04 AM | #51 | |
Rep 289
12-30-2018, 03:08 AM | #52 |
Rep 289
Great no holes barred review from 'gippy'. Totally agree about the brake squeal its always on the last few feet of braking. Irritating when pedestrians turn round to see who's 'squeaking'
12-30-2018, 04:08 AM | #53 | |
Rep 4,935
Drives: 340i MPPSK
Power is nothing without control as they say
Life is a state of mind |
12-30-2018, 04:50 AM | #54 |
Rep 310
I came from 430dx GC to my 440i GC and I would say that the throttle is definitely more sensitive that the 430d but this is simply down to the different nature of the engines. If you want drive on the torque of the petrol low you would the diesel then eco pro or manual changes is the way to go.
The 440i has quite a lot more power up the Rev band and because of that it's delivery when combined with the shift in gears is a bit more aggressive. The 430d is fast in a very relaxed way but doesn't give the final thrill that the 440i does as that engine really gets j to its stride. And to be honest on my LCi I find the suspension a big improvement (adaptive) and I haven't had the issues with the brakes yet. Had that with the standard brakes though and comes down to the dealer cleaning, greasing and using the correct shims. |
Quantox308.50 |
12-30-2018, 06:08 AM | #55 |
Rep 525
well thought i'd leave this thread for a bit and come back. Fantastic debate and discussion, and i've picked up a few tips in the process which was the whole idea, so thanks.
On the whole kickdown throttle control issue - well, i had a play about yesterday on the way to the shops, and i still wasn't impressed. I do stress, I wasn't trying kickdown - i'll leave that for the motorway journey i've got on Monday. So this is not my final opinion. but just leaving it in sport and experimenting with different rates at which i apply throttle, really did not seem to make much difference. Maybe it'll be a different story if i select kickdown. Very difficult to be scientific about these things without being able to measure the throttle % applied over time, but from a subjective point of view, and trying to consciously push throttle down at a medium/slowish rate, all the car did was jerk down a gear or two (fine) and take its time to do it. But my biggest grip was it just holds onto gears. The car revs out in this slow and wheezy way to 5k+rpm, and i'm like.....'ffs shift up...shift UP'. There were definitely instances last night where i was purposelly lifting off, as the revs rose, thinking that would prompt it to change up....but it didn't. Now if you're 100% throttle, then i can understand the car holding to gears and shifting at the red line (as it did for me in the summer when i tried 0-60 runs) - but why is it doing it when you're not even half throttle? Anyway, i'll have a bit more of a play, i'm not sure if Torque Pro app measures throttle %, it certainly has revs - so i'll plug that in and start recording. Was probably worth mentioning that - as my description under my username states, my car is Aug 2016 - pre Lci. I did read in road test articles that the Lci had tweaks to suspension, so maybe that did transform the car? i also did mention that mine is passive so maybe the active does give a better degree of body control. i personally didn't want adaptive as i know that down the line i'd want to change it all out and get something trick anyway and set up to my liking. i think people ignored my intro and outro and just read the bad stuff i wrote in bold......i did specifically say that i do love the car....and that for me there's nothing better for the money. The engine and transmission (in manual mode anyway) are brilliant, and that's the most important thing. i'm personally waiting till the warranty runs out before the remap, exhaust, suspension and diff upgrades.... then i'll have nothing to complain about. bit worried about my fuel economy though, if others are saying they are getting 30+ even in urban......not sure what it could be or if the dealer would pick up anything? i mean if a car is sipping more fuel than it should....it could be anything? i've been putting shell v power in it from day 1. Last edited by gippy; 12-30-2018 at 06:14 AM.. |
12-30-2018, 06:25 AM | #56 | |
Rep 1,094
Summer with no heating and a warm engine will see low 50`s in eco mode and a very light foot at around 50 mph. Why wait for the warranty to expire for the exhaust as the MPPSK are getting thin on the ground at the moment plus it keeps the factory warranty intact. Kenny |
12-30-2018, 06:39 AM | #57 |
Rep 1,162
12-30-2018, 08:59 AM | #58 |
Rep 525
12-30-2018, 09:01 AM | #59 | |
Rep 525
much rather have a 400+bhp remap and exhaust for the same money. Happy to wait till then. |
12-30-2018, 09:11 AM | #60 | |
Rep 15,858
Rapid throttle lift off will supress an up change, that is a feature/function of the box, prevents up-shifts if you were intending to brake. It will then wait for your next command, like accelerating again before an up-shift. I see you are using Sport. What if you try it in Comfort. See how the different base program and a less sensitive throttle handles the change points and responses.'D', |
Quantox308.50 |
12-30-2018, 12:08 PM | #61 |
Rep 1,162
I had read your full post, this I thought was a worthy soundbite.
I appreciate the context, in a nutshell it's the effect of having an automatic gearbox tuned slightly for comfort and a turbocharged engine which while powerful has been mapped by BMW for emissions compliance and economy. Without going back to naturally aspirated engines this slight hole in throttle response is being filled by light hybrids where a very small electric motor provides the instantaneous torque before the turbo spools up. I not sure what BMW have planned in this area however other manufacturers already have cars on sale with this sort of technology. |
12-30-2018, 03:15 PM | #62 | ||
Rep 525
i guess when we're talking about throttle mappings and shift patterns and power curves it helps to be as precise as possible. what i meant was when i apply say....i don't know - 25-40% throttle, from a standing start, the gears still hang and it won't upshift. So 1st, to 2nd especially, it's just revving out, even though i'm hovering around 30% throttle - so it feels like the car is 'wheezy' or running out of power - simply because i'm applying little throttle but its still revving out. Quote:
one thing i've realised from all this is i really haven't actually spent much time in auto modes with sport - mainly coz i didn't know how kickdown worked properly so every time i've been in sport mode i've been also in full manual mode. i'll spend the next few weeks leaving it in auto + sport and also trying comfort and make an effort to adjust my throttle inputs from lights, or overtaking etc.. and see how it all behaves. |
12-30-2018, 04:45 PM | #63 | ||||
Rep 19
12-30-2018, 05:39 PM | #64 |
Rep 11,292
gippy with regards your fuel consumption, a bit of a long shot but check your oil level.
Was reading about a guy on another car forum that he experiencing really poor fuel consumption, far less than anyone else was getting. Then he realized his dealer way over filled his oil by well over a litre above max. He had the excess oil empted and the fuel consumption picked up a fair bit. So worth a check?
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
12-31-2018, 03:40 AM | #65 | |
Rep 2,113
I paid £1740 for mine with carbon tips, a remus exhaust only with carbon tips is c. £1600. Plus you keep your warranty, which could be worth thousands if you are unfortunate. If something goes bang with a 400bhp map on the car you are in trouble.... |
12-31-2018, 04:15 AM | #66 | |
Rep 1,094
£1640 , fully fitted with the carbon tips , an extra 40+ hp , warranty intact meaning no waiting around , for me, for 30 months until the car was three years old. Kenny |
