01-06-2019, 07:39 PM | #1 |
Rep 307
Bimmercode Error
Need some help. I coded my car, 1-2 small things first time and everything worked fine. I tried to code is again after few days and this time while writing data I got an error saying some of the data is faulty. After that message I saw the FCU is showing up as RED and also ECU was greyed out. I tried to restore it from the last backup but still got the same message.
What can I do, I am not getting any error on the car itself. I sent a message to bimmercode and they are telling me to restart the phone and take out and put back the adaptor again and then try to restore. I have not tried to restore from the original backup yet. Anybody else faced the problem while coding using bimmercode. I am now worried to try it out again.
2014 BMW 335i - M-Sports, 19inch 403 Wheels, M-Sports Brakes, Tech pkg, Prem pkg, HK, SunShades, Auto, Driver Assist...
01-06-2019, 07:57 PM | #2 |
Rep 202
Drives: 2011 M3 6sp
Someone else chime in but I think you might need esys and a enet cable dude :/ but before that try to restore from original backup, also what ecu were you trying to code
01-06-2019, 09:32 PM | #3 |
Rep 537
Definitely restore every module back to factory settings and re-code after that. I've run into this in the past and restoring to the backup and retrying always seems to do the trick.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
01-06-2019, 11:27 PM | #4 |
Rep 297
I had this when the connection between the phone and adapter wasn't stable.
Put phone in to airplane mode then switch on WiFi or Bluetooth whichever you are using and try again. |
01-09-2019, 07:46 PM | #5 |
Rep 307
Thanks. Will try that this weekend
01-09-2019, 08:04 PM | #6 |
Rep 14,107
Drives: G82 M4C X-Drive
What kind of adapter do you have? Wifi or Blutooth?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
01-09-2019, 08:23 PM | #7 |
Rep 307
01-09-2019, 08:37 PM | #8 |
Rep 14,107
That might explain it. The wifi models seems to experience more errors because of the stability of the connection.
01-10-2019, 12:47 AM | #9 |
Rep 1,827
I use a WiFi adapter and have never had issues coding with Bimmercode. 🤷🏻*♂️
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
01-10-2019, 02:35 AM | #10 |
Monobloc
331
Rep 447
Drives: '02 M Coupe - '19 F31 330ix
The Bimmercode developer seems to recommend BT adapters over their wifi counterparts for a reason. Go to his website and ye shall see. BT -I'm assuming- provides a more stable connection?
-2023 Honda Odyssey Elite - Sonic Gray Pearl / Black
-2019 F31 330ix Individual - Champagne Quartz / Coral Red (M-sport, Exec, Premium, Track) -2004 Honda CRV AWD - Silver / Black -2002 S54 M Coupé - Steel Gray / Dark Gray/Black |
01-10-2019, 08:49 PM | #11 | |
Rep 201
The adapter shouldn’t know the difference between one and the other. They are sending and receiving identical data over the same protocol. Last edited by les anderson; 01-10-2019 at 09:02 PM.. |
01-11-2019, 05:20 PM | #12 | |
Rep 21
A phone can only have one Wi-Fi connection active at one time. If for some reason the phone decides to pick up your home Wi-Fi or a hotspot somewhere nearby, it will drop your OBD connection in an instant and possibly during a sensitive code write. A phone can have many simultaneous BT connections. And since you are sitting in the car 2 feet away from the OBD adaptor, range is never an issue. So the connection is less likely to drop during a sensitive code write. So being near your BT watch and headphones won't matter there.
2018 440i X-Drive Coupe | Alpine White/Coral Red | M performance | Track Handling
2016 Audi A7 2013 Audi Allroad 2013 Audi A3 "clean " TDI bought back at full purchase price after 50k miles |
03-18-2021, 06:25 PM | #13 | |
Rep 3
I have to go to the dealership and I want to restore everything since I am dreading that I may have the n20 timing chain issue . I have a 2013 F30 MY 2012. |
