05-30-2019, 07:44 AM | #199 |
Rep 928
Standing by for someone to max out the B58 pump. Just talked to the turbo engineers over in Germany and they are all using the B58 pump on their high hp cars. I think it will do quite a bit better than 5% on the n55 pump.
2015 335i 6sp manual with MPK and sport pack
GPlus intercooler and CP. Stage 1. CG precision dp. Staggered 19?s. 275/35/19, 245/40/19 ps4s. |
06-01-2019, 08:19 PM | #200 |
Rep 472
I bought a B58 Pump and now sold the car before installing it....
If anyone wants one, hit me up. Im in Australia and can ship it. $350 USD/$500 AUD |
06-03-2019, 01:35 AM | #203 | |
Rep 33
Has anyone tried making a 2 teeth smaller gear for the N55? This would make more RPM on the cam, the tensioner should have enough room for a slightly smaller gear. |
06-03-2019, 02:54 PM | #206 | |
Boost Addict
334
Rep 349
S55 M2C | Three Pedal Club | E30TU
06-03-2019, 09:56 PM | #208 |
Rep 1,105
Correct the XDI pump requires software either through MHD or BM3 to work. The B58 pump does not but in order to maximize performance you should have a tune.
06-03-2019, 11:30 PM | #209 | |
Rep 103
yes, a map with more power for the new pump b58, but if one day I need to return to the stock map to go to the official dealer, there is no problem and with xdi if ... |
06-04-2019, 04:25 AM | #210 |
Rep 389
Drives: 18 BMW M2LPower
13 BMW 335ix Full Weight 10.64 @129mph N55 WR SOLD
15 BMW M4 Full Weight 10.69@133mph stock turbos SOLD 18 BMW M2LPower 9.69@147.4mph 1.66 60ft michelin 4s tires instagram @luchocampusano YouTube Lucho Campusano |
06-04-2019, 10:11 PM | #211 |
Rep 316
lucho, are you using meth for cooling IAts mainly? It is cool to see E45 with the b58 if so....especially on a stage 3 turbo. I think some of us are wondering about the ability of the b58 to help out PS2 users....
06-05-2019, 03:59 AM | #214 | |
Rep 389
B58 hpfp is better than oem N55 hpfp for sure. When I got PS2 on my car I did not see hpfp drops and max out 23.5psi so I can not confirm you will see any benefit unless you are having HPFP drops at WOT.
06-05-2019, 05:13 AM | #215 | |
Rep 316
Also, did you upgrade or re-inforce your transfer case and or differential at all since you are xdrive? All that power scares me still as I am xdrive. Thanks |
06-05-2019, 07:30 AM | #216 |
Rep 282
there are no upgrades for the transfer case, just replacement kits .
ATC 300 case is being used in diesel xdrives too
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
06-05-2019, 09:53 AM | #217 |
Rep 1,105
If im not mistaken, luchocamp had the PWG turbo and if so, they are able to run more E85 mixes than the stock EWG turbo.
stock HPFP is more of a concern when pushing past 18psi in the upper RPM band around 5500 rpms. From my understanding if you are wanting more than 20psi mid to upper rpm band, then get the XDI pump. But if you are targeting 18-20psi, the B58 should perform better than the stock HPFP.
06-05-2019, 10:10 AM | #218 |
Rep 282
or contact RRahmani on facebook , he has a B58 upgrade pump , claims 38 percent extra . its also a bosch model , so normally no extra programming required
06-05-2019, 11:18 AM | #219 |
Rep 928
