BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > UPDATED!! Oil Leak(picture included) where's it coming from?
proTUNING Freaks
      03-13-2019, 09:58 PM   #23
F30NFifty5
Drives: F30 335i XDrive 6mt / e83 X3
Originally Posted by SteelBlue46 View Post
Haha it did look interesting! I did really like the additional 17mm hex on the top that made getting the cap off so much easier just using a ratchet so that's a plus!
When you installed your ECS cap, did you have to swap the piece of the oem cap that the filter slides onto?
      03-13-2019, 10:00 PM   #24
SteelBlue46
Drives: Alpine White '13 335i XDrive
yep had to transfer the entire middle plastic pieces to the aluminum one. if I remember right it just pulls out and pops into the new one.
      03-13-2019, 10:02 PM   #25
F30NFifty5
hmm I can't get mine off the OEM piece...I'll mess around with it some more tomorrow. Thanks man
      03-15-2019, 02:26 AM   #26
TEST DRYVER
TEST DRYVER's Avatar
Drives: 2019 Porsche 718 Cayman GTS
I had my oil changed, along with the filter of course. I was leaking. It was collecting in the same spot yours was. I had the same tech order a new O ring, take off the cap, replaced the O ring, and re-tighten the cap. No problems since... I'd start there.
      03-15-2019, 09:22 PM   #27
F30NFifty5
Hose from pelican parts came in the mail today so I swapped the new one with the broken one. Super easy, they're held together by a tiny c clamp. Attempted to get the oil filter cage off the oem cap which was oddly difficult and I once again broke something.
Cracked the top of the cage where it connects with the spring. Filter cage was still able to fit with the ECS tuning cap so not really worried. I'll order a new one and just replace it.
Drove it around for a bit and no leak. Not sure if it was the cap or the gasket but it's gone.. for now
      03-19-2019, 01:36 PM   #28
DreamerJoe
Drives: 2017 340i M.G. w red interior
how is it holding up? any signs of leaking after the new parts?
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
      03-19-2019, 10:29 PM   #29
F30NFifty5
No leaks thus far... wish I did the oil cap and gasket separately to see where the leak was actually coming from.
oil did seep into the tensioner pulley tho so now im getting some squeaking and squealing. Going to have to swap that out soon.
      03-19-2019, 10:42 PM   #30
zinner
zinner's Avatar
559
Drives: `17 X5 35d/`15 335i/`18 M550IX
Looks like a bad cap o-ring seeping. I got a non Mann oil filter and the o-ring was the wrong dimensions and never sealed right the cap to housing. It should be quite tight to screw down the last few turns doable with to hands twisting however.
      08-27-2021, 07:43 AM   #31
ovo Dima
ovo Dima's Avatar
Drives: 2014 BMW 435xi
Following ! Just replaced my filter and Oil Cap O-ring. Pic below is after 100 miles.
https://share.icloud.com/photos/016H...5zXeZxDNwGY9Gg
gasket, oil, oil filter housing gasket, oil leak
