08-24-2019, 11:21 AM | #1 |
Rep 5,316
Drives: G80 M3 6MT
Need help ASAP!! From anyone who has done a b58 XDrive downpipe
Need help ASAP from anyone who has done a b58 ER downpipe on XDrive. How are the spacers installed? Is it the 10 small ones on the pan and the 2 large ones on the DP bracket?
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
08-24-2019, 11:38 AM | #2 |
Rep 308
I used 4 washers from Home Depot on the belly pan. Buy a few extra since they are so cheap and see what it takes
08-24-2019, 11:39 AM | #3 | |
Rep 5,316
Drives: G80 M3 6MT
Scott, Partner
08-24-2019, 01:36 PM | #4 | ||
Rep 308
08-26-2019, 11:52 AM | #5 | |
Rep 190,750
Did you manage to install it? we spoke in the weekend so i could not be much help and i apologize for that.
08-29-2019, 07:24 PM | #6 |
Rep 4,876
I did that pipe on a 2016 340 B58, and no spacers were required. I just pried the DP a bit so when it all tightened up there was nothing touching (first attempt I knew better but didn't check and it was rubbing on the pan/mounts).
09-08-2019, 02:18 PM | #7 |
Rep 5
Would anyone happen to know a part number or a comparable replacement for the vband clamp, bolt, and nut that attaches to the turbo? I'm having to cut the bolt because it and the nut are stripped. For a job that was supposed to be somewhat simple and take about 2 hours has been a HUGE pain.
09-08-2019, 03:13 PM | #8 | |
Rep 1,454
07-22-2020, 06:17 PM | #9 |
Rep 124
Did you get resolution? I just received my spacers from ER, same deal two large, ten small? :
07-24-2020, 06:19 AM | #11 |
Rep 215
07-25-2020, 07:03 PM | #12 | |
Rep 124
I shammed the large one in there first to see if it was still vibrating, and it was. I then used the second large washer to really try and give it some space - and I'm still getting some vibration. There's now about 2 inches of clearance. The only other contact point I can see is on the top of the midpipe, there's a nut making contact? I really thought these spacers would do the trick :/ FYI, the zip tie was temporary so I could run to Home Depot to pick up another M10x1.5 10.9 grade nut, because the original wasn't log enough to reach the threads on the other side of the washers. |
07-26-2020, 04:09 PM | #15 |
Rep 124
I still have a small vibration, but it only happens after the car has heated up some. Very strange. I may try and take it to an Indy shop to see if they can isolate where the noise is coming from.
When I have the car in neutral and rev it up, it doesn't happen, it's only while driving and around 2k rpm |
07-26-2020, 05:32 PM | #16 |
Rep 1,154
You shouldn't have to use both of those washers. Loosen the 2 bolts on the downpipe bracket and the try and push it up a little. You should have a little wiggle room, maybe 1/8"-1/4" which will give you enough clearance to run 1 washer and hopefully take care of your vibration.
2016 340i xdrive
2009 335i |
07-26-2020, 05:45 PM | #17 | |
Rep 124
Now that I have some more clearance I may try and bring it down a scooch (real word?), so the midpipe isn't as high. It may be vibrating against the heat shield that is right at the DP/MP clamp. |
07-26-2020, 09:05 PM | #18 | |
Rep 274
07-27-2020, 06:27 AM | #19 | |
Rep 215
07-28-2020, 09:42 AM | #20 | |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
My work here is done [flies away]
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
M4-CPA63.50 |
07-28-2020, 10:50 AM | #21 | ||
Rep 124
